RTEMS
6.3
Toggle main menu visibility
bsps
include
grlib
tlib.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* Timer Library (TLIB)
5
6
* The Library rely on timer drivers, the timer presented by the
7
* timer driver must look like a down-counter timer, which generates
8
* interrupt (if configured) when underflown.
9
10
* If Timer hardware is an up-counter the Timer driver must recalculate
11
* into values that would match as if it was a down-counter.
12
13
* COPYRIGHT (c) 2011.
14
* Cobham Gaisler AB.
15
16
17
* modification, are permitted provided that the following conditions
18
* are met:
19
* 1. Redistributions of source code must retain the above copyright
20
* notice, this list of conditions and the following disclaimer.
21
* 2. Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in the
23
* documentation and/or other materials provided with the distribution.
24
25
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
* POSSIBILITY OF SUCH DAMAGE.
36
37
38
#ifndef __TLIB_H__
39
#define __TLIB_H__
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
44
45
struct
tlib_dev
46
47
typedef
void (*tlib_isr_t)(
void
*data);
48
49
enum
50
TLIB_FLAGS_BROADCAST = 0x01
51
52
53
struct
tlib_drv
54
/*** Functions ***/
55
void (*reset)(
struct
tlib_dev
*hand);
56
void (*get_freq)(
57
struct
tlib_dev
*hand,
58
unsigned
int
*basefreq,
59
unsigned
int
*tickrate);
60
int (*set_freq)(
struct
tlib_dev
*hand,
unsigned
int
tickrate);
61
void (*irq_reg)(
struct
tlib_dev
*hand, tlib_isr_t func,
void
*data,
int
flags);
62
void (*irq_unreg)(
struct
tlib_dev
void
*data);
63
void (*start)(
struct
tlib_dev
*hand,
int
once);
64
void (*stop)(
struct
tlib_dev
*hand);
65
void (*restart)(
struct
tlib_dev
*hand);
66
void (*get_counter)(
struct
tlib_dev
*hand,
unsigned
int
*counter);
67
int (*custom)(
struct
tlib_dev
*hand,
int
cmd,
void
*arg);
68
int (*int_pend)(
struct
tlib_dev
*hand,
int
ack);
69
void (*get_widthmask)(
struct
tlib_dev
*hand,
unsigned
int
*widthmask);
70
71
72
struct
tlib_dev
73
struct
tlib_dev
*next;
74
char
status;
/* 0=closed, 1=open, 2=timer started */
75
char
index;
/* Timer Index */
76
tlib_isr_t isr_func;
77
void
*isr_data;
78
struct
tlib_drv
*drv;
79
80
81
#ifdef RTEMS_DRVMGR_STARTUP
82
/* Clock Driver Timer register function. Only used when the TLIB-Clock
83
* driver is used. A specific Timer is registered as the System Clock
84
* timer.
85
86
extern
void
Clock_timer_register(
int
timer_number);
87
#endif
88
89
/* Register Timer. Called by Timer Drivers in order to register
90
* a Timer to the Timer Library. The registration order determines
91
* the Timer Number used in tlib_open() to identify a specific
92
* Timer.
93
94
extern
int
tlib_dev_reg(
struct
tlib_dev
*newdev);
95
96
/* Allocate a Timer.
97
98
* A Timer handle is returned identifying the timer in later calls.
99
100
extern
void
*tlib_open(
int
timer_no);
101
102
/* Close Timer */
103
extern
void
tlib_close(
void
*hand);
104
105
/* Returns Number of Timers currently registered to Timer Library */
106
extern
int
tlib_ntimer(
void
107
108
static
inline
void
tlib_reset(
void
*hand)
109
110
struct
tlib_dev
*dev = hand;
111
112
dev->drv->reset(dev);
113
114
/* Get Frequencies:
115
* - Base Frequency (unchangable base freq rate of timer, prescaler, clkinput)
116
* - Current Tick Rate [in multiples of Base Frequency]
117
118
static
inline
void
tlib_get_freq(
119
void
*hand,
120
unsigned
int
*basefreq,
121
unsigned
int
*tickrate)
122
123
struct
tlib_dev
*dev = hand;
124
125
dev->drv->get_freq(dev, basefreq, tickrate);
126
127
128
/* Set current Tick Rate in number of "Base-Frequency ticks" */
129
static
inline
int
tlib_set_freq(
void
*hand,
unsigned
int
tickrate)
130
131
struct
tlib_dev
*dev = hand;
132
133
return
dev->drv->set_freq(dev, tickrate);
134
135
136
/* Register ISR at Timer ISR */
137
static
inline
void
tlib_irq_unregister(
void
*hand)
138
139
struct
tlib_dev
*dev = hand;
140
141
if
( dev->isr_func ) {
142
dev->drv->irq_unreg(dev, dev->isr_func, dev->isr_data);
143
dev->isr_func = NULL;
144
145
146
147
148
static
inline
void
tlib_irq_register(
void
void
*data,
int
flags)
149
150
struct
tlib_dev
*dev = hand;
151
152
/* Unregister previous ISR if installed */
153
tlib_irq_unregister(hand);
154
dev->isr_func = func;
155
dev->isr_data = data;
156
dev->drv->irq_reg(dev, func, data, flags);
157
158
159
/* Start Timer, ISRs will be generated if enabled.
160
161
* once determines if timer should restart (=0) on underflow automatically,
162
* or stop when underflow is reached (=1).
163
164
static
inline
void
tlib_start(
void
*hand,
int
once)
165
166
struct
tlib_dev
*dev = hand;
167
168
dev->drv->start(dev, once);
169
170
171
/* Stop Timer, no more ISRs will be generated */
172
static
inline
void
tlib_stop(
void
*hand)
173
174
struct
tlib_dev
*dev = hand;
175
176
dev->drv->stop(dev);
177
178
179
/* Restart/Reload Timer, may be usefull if a Watchdog Timer */
180
static
inline
void
tlib_restart(
void
*hand)
181
182
struct
tlib_dev
*dev = hand;
183
184
dev->drv->restart(dev);
185
186
187
/* Get current counter value (since last tick) */
188
static
inline
void
tlib_get_counter(
void
*hand,
unsigned
int
*counter)
189
190
struct
tlib_dev
*dev = hand;
191
192
dev->drv->get_counter(dev, counter);
193
194
195
/* Do a custom operation */
196
static
inline
void
tlib_custom(
void
*hand,
int
cmd,
void
*arg)
197
198
struct
tlib_dev
*dev = hand;
199
200
dev->drv->custom(dev, cmd, arg);
201
202
203
static
inline
int
tlib_interrupt_pending(
void
*hand,
int
ack)
204
205
struct
tlib_dev
*dev = hand;
206
207
return
dev->drv->int_pend(dev, ack);
208
209
210
static
inline
void
tlib_get_widthmask(
void
*hand,
unsigned
int
*widthmask)
211
212
struct
tlib_dev
*dev = hand;
213
214
dev->drv->get_widthmask(dev, widthmask);
215
216
217
#ifdef __cplusplus
218
219
#endif
220
221
#endif
tlib_dev
Definition
tlib.h:72
tlib_drv
Definition
tlib.h:53
