RTEMS 6.3
#include <bsp/irq-generic.h>
#include <rtems/irq-extension.h>
#include "tx-support.h"
#include <rtems/test.h>
struct  RtemsIntrReqEntryInstall_Entry
struct  RtemsIntrReqEntryInstall_Context
 Test context for spec:/rtems/intr/req/entry-install test case. More...
typedef RtemsIntrReqEntryInstall_Context Context
enum  RtemsIntrReqEntryInstall_Pre_Vector { RtemsIntrReqEntryInstall_Pre_Vector_Valid , RtemsIntrReqEntryInstall_Pre_Vector_Invalid , RtemsIntrReqEntryInstall_Pre_Vector_NA }
enum  RtemsIntrReqEntryInstall_Pre_Options { RtemsIntrReqEntryInstall_Pre_Options_Unique , RtemsIntrReqEntryInstall_Pre_Options_Shared , RtemsIntrReqEntryInstall_Pre_Options_Replace , RtemsIntrReqEntryInstall_Pre_Options_NA }
enum  RtemsIntrReqEntryInstall_Pre_Entry { RtemsIntrReqEntryInstall_Pre_Entry_Obj , RtemsIntrReqEntryInstall_Pre_Entry_Null , RtemsIntrReqEntryInstall_Pre_Entry_NA }
enum  RtemsIntrReqEntryInstall_Pre_Routine { RtemsIntrReqEntryInstall_Pre_Routine_Valid , RtemsIntrReqEntryInstall_Pre_Routine_Null , RtemsIntrReqEntryInstall_Pre_Routine_NA }
enum  RtemsIntrReqEntryInstall_Pre_Init { RtemsIntrReqEntryInstall_Pre_Init_Yes , RtemsIntrReqEntryInstall_Pre_Init_No , RtemsIntrReqEntryInstall_Pre_Init_NA }
enum  RtemsIntrReqEntryInstall_Pre_ISR { RtemsIntrReqEntryInstall_Pre_ISR_Yes , RtemsIntrReqEntryInstall_Pre_ISR_No , RtemsIntrReqEntryInstall_Pre_ISR_NA }
enum  RtemsIntrReqEntryInstall_Pre_CanEnable { RtemsIntrReqEntryInstall_Pre_CanEnable_Yes , RtemsIntrReqEntryInstall_Pre_CanEnable_Maybe , RtemsIntrReqEntryInstall_Pre_CanEnable_No , RtemsIntrReqEntryInstall_Pre_CanEnable_NA }
enum  RtemsIntrReqEntryInstall_Pre_Installed {
  RtemsIntrReqEntryInstall_Pre_Installed_None , RtemsIntrReqEntryInstall_Pre_Installed_Unique , RtemsIntrReqEntryInstall_Pre_Installed_Other , RtemsIntrReqEntryInstall_Pre_Installed_EqRoutine ,
  RtemsIntrReqEntryInstall_Pre_Installed_EqArg , RtemsIntrReqEntryInstall_Pre_Installed_Match , RtemsIntrReqEntryInstall_Pre_Installed_NA
enum  RtemsIntrReqEntryInstall_Post_Status {
  RtemsIntrReqEntryInstall_Post_Status_Ok , RtemsIntrReqEntryInstall_Post_Status_InvAddr , RtemsIntrReqEntryInstall_Post_Status_IncStat , RtemsIntrReqEntryInstall_Post_Status_InvId ,
  RtemsIntrReqEntryInstall_Post_Status_InvNum , RtemsIntrReqEntryInstall_Post_Status_CalledFromISR , RtemsIntrReqEntryInstall_Post_Status_InUse , RtemsIntrReqEntryInstall_Post_Status_TooMany ,
  RtemsIntrReqEntryInstall_Post_Status_NA
enum  RtemsIntrReqEntryInstall_Post_Enable {
  RtemsIntrReqEntryInstall_Post_Enable_Nop , RtemsIntrReqEntryInstall_Post_Enable_Yes , RtemsIntrReqEntryInstall_Post_Enable_Maybe , RtemsIntrReqEntryInstall_Post_Enable_No ,
  RtemsIntrReqEntryInstall_Post_Enable_NA
enum  RtemsIntrReqEntryInstall_Post_Installed { RtemsIntrReqEntryInstall_Post_Installed_No , RtemsIntrReqEntryInstall_Post_Installed_Last , RtemsIntrReqEntryInstall_Post_Installed_NA }
 T_TEST_CASE_FIXTURE (RtemsIntrReqEntryInstall, &RtemsIntrReqEntryInstall_Fixture)
