RTEMS 6.3
tasksetup_bdtable.h
1#ifndef __TASK_API_TASKSETUP_BDTABLE_H
2#define __TASK_API_TASKSETUP_BDTABLE_H 1
3
4/******************************************************************************
5*
6* Copyright (c) 2004 Freescale Semiconductor, Inc.
7*
8* Permission is hereby granted, free of charge, to any person obtaining a
9* copy of this software and associated documentation files (the "Software"),
10* to deal in the Software without restriction, including without limitation
11* the rights to use, copy, modify, merge, publish, distribute, sublicense,
12* and/or sell copies of the Software, and to permit persons to whom the
13* Software is furnished to do so, subject to the following conditions:
14*
15* The above copyright notice and this permission notice shall be included
16* in all copies or substantial portions of the Software.
17*
18* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
19* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
20* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
21* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR
22* OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
23* ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
24* OTHER DEALINGS IN THE SOFTWARE.
25*
26******************************************************************************/
27
28/*
29 * Table of BD rings for all BestComm tasks indexed by task ID.
30 *
31 * +-----+------+--------------+ +------+-------+
32 * 0: |numBD|numPtr|BDTablePtr ---|--->|status|dataPtr|
33 * +-----+------+--------------+ +------+-------+
34 * 1: |numBD|numPtr|BDTablePtr | |status|dataPtr|
35 * +-----+------+--------------+ . . .
36 * 2: |numBD|numPtr|BDTablePtr ---|-+ . . .
37 * . . . | . . .
38 * . . . | |status|dataPtr|
39 * . . . | +------+-------+
40 * 15:|numBD|numPtr|BDTablePtr | |
41 * +-----+------+--------------+ |
42 * |
43 * V
44 * +------+--------+--------+
45 * |status|dataPtr0|dataPtr1|
46 * +------+--------+--------+
47 * |status|dataPtr0|dataPtr1|
48 * . . . .
49 * . . . .
50 * . . . .
51 * |status|dataPtr0|dataPtr1|
52 * +------+--------+--------+
53 */
54typedef struct {
55 uint16 numBD; /* Size of BD ring */
56 uint8 numPtr; /* Number of data buffer pointers per BD */
57 uint8 apiConfig; /* API configuration flags */
58 void *BDTablePtr; /* Pointer to BD tables, must be cast to TaskBD1_t */
59 /* or TaskBD2_t */
60 volatile uint32
61 *BDStartPtr; /* Task's current BD pointer. This pointer is
62 * used to set a task's BD pointer upon startup.
63 * It is only valid for BD tasks and only after
64 * TaskSetup() or TaskBDReset() are called. You
65 * cannot use this to track a task's BD pointer.
66 */
67 uint16 currBDInUse; /* Current number of buffer descriptors assigned but*/
68 /* not released yet. */
70
71typedef enum {
72 API_CONFIG_NONE = 0x00,
73 API_CONFIG_BD_FLAG = 0x01
74} ApiConfig_t;
75
76/*
77 * Allocates BD table if needed and updates the BD index table.
78 * Do we want to hide this from the C API since it operates on task API?
79 */
80void TaskSetup_BDTable(volatile uint32 *BasePtr,
81 volatile uint32 *LastPtr,
82 volatile uint32 *StartPtr,
83 int TaskNum, uint32 NumBD, uint16 MaxBD,
84 uint8 NumPtr, ApiConfig_t ApiConfig, uint32 Status );
85
86#endif /* __TASK_API_TASKSETUP_BDTABLE_H */
Definition tasksetup_bdtable.h:54
