RTEMS
6.3
Toggle main menu visibility
bsps
arm
lm3s69xx
include
bsp
syscon.h
1
8
9
10
* Copyright (c) 2013 Eugeniy Meshcheryakov <eugen@debian.org>
11
12
* The license and distribution terms for this file may be
13
* found in the file LICENSE in this distribution or at
14
* http://www.rtems.org/license/LICENSE.
15
16
#ifndef LIBBSP_ARM_LM3S69XX_SYSCON_H
17
#define LIBBSP_ARM_LM3S69XX_SYSCON_H
18
#include <stdbool.h>
19
27
28
#ifdef __cplusplus
29
extern
"C"
30
#endif
31
32
void
lm3s69xx_syscon_enable_gpio_clock(
unsigned
int
port,
bool
enable);
33
void
lm3s69xx_syscon_enable_uart_clock(
unsigned
int
port,
bool
enable);
34
void
lm3s69xx_syscon_enable_ssi_clock(
unsigned
int
port,
bool
enable);
35
void
lm3s69xx_syscon_enable_pwm_clock(
bool
enable);
36
void
lm3s69xx_syscon_set_pwmdiv
unsigned
int
div);
37
void
lm3s69xx_syscon_delay_3x_clocks(
unsigned
long
x_count);
38
39
#ifdef __cplusplus
40
41
#endif
42
43
#endif
/* LIBBSP_ARM_LM3S69XX_SYSCON_H */
void lm3s69xx_syscon_set_pwmdiv(unsigned int div)
Definition
syscon.c:106
