RTEMS 6.3
rtems_task_config Struct Reference
This structure defines the configuration of a task constructed by rtems_task_construct(). More...
#include <tasks.h>
rtems_name name
 This member defines the name of the task.
rtems_task_priority initial_priority
 This member defines the initial priority of the task.
void * storage_area
 This member shall point to the task storage area begin.
size_t storage_size
 This member defines size of the task storage area in bytes.
size_t maximum_thread_local_storage_size
 This member defines the maximum thread-local storage size supported by the task storage area.
void(*) storage_free (void *)
 This member defines the optional handler to free the task storage area.
rtems_mode initial_modes
 This member defines the initial modes of the task.
rtems_attribute attributes
 This member defines the attributes of the task.
Field Documentation
◆ maximum_thread_local_storage_size
size_t rtems_task_config::maximum_thread_local_storage_size
Use RTEMS_ALIGN_UP() and RTEMS_TASK_STORAGE_ALIGNMENT to adjust the size to meet the minimum alignment requirement of a thread-local storage area used to construct a task.
If the value is less than the actual thread-local storage size, then the task construction by rtems_task_construct() fails.
If the is less than the task storage area size, then the task construction by rtems_task_construct() fails.
The actual thread-local storage size is determined when the application executable is linked. The rtems-exeinfo command line tool included in the RTEMS Tools can be used to obtain the thread-local storage size and alignment of an application executable.
The application may configure the maximum thread-local storage size for all threads explicitly through the CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE configuration option.
◆ storage_area
void* rtems_task_config::storage_area
The task storage area will contain the task stack, the thread-local storage, and the floating-point context on architectures with a separate floating-point context.
The task storage area begin address and size should be aligned by RTEMS_TASK_STORAGE_ALIGNMENT. To avoid memory waste, use RTEMS_ALIGNED() and RTEMS_TASK_STORAGE_ALIGNMENT to enforce the recommended alignment of a statically allocated task storage area.
◆ storage_free
void(*) rtems_task_config::storage_free(void *)
It is called on exactly two mutually exclusive occasions. Firstly, when the task construction aborts due to a failed task create extension, or secondly, when the task is deleted. It is called from task context under protection of the object allocator lock. It is allowed to call free() in this handler. If handler is NULL, then no action will be performed.
◆ storage_size
size_t rtems_task_config::storage_size
Use the RTEMS_TASK_STORAGE_SIZE() macro to determine the recommended task storage area size.
