RTEMS 6.3
occan_priv Struct Reference
Public Member Functions
 SPIN_DECLARE (devlock)
struct drvmgr_dev * dev
char devName [52]
pelican_regs * regs
int byte_regs
int irq
occan_speed_regs timing
int channel
int single_mode
unsigned int sys_freq_hz
rtems_id devsem
rtems_id txsem
rtems_id rxsem
int open
int started
int rxblk
int txblk
int sending
unsigned int status
occan_stats stats
occan_fifo * rxfifo
occan_fifo * txfifo
unsigned int speed
unsigned char acode [4]
unsigned char amask [4]
