RTEMS 6.3
gr_cpci_leon4_n2x_priv Struct Reference
Public Member Functions
 SPIN_DECLARE (devlock)
struct drvmgr_dev * dev
char prefix [20]
pci_dev_t pcidev
struct pci_dev_info * devinfo
uint32_t ahbmst2pci_map
int eirq
genirq_t genirq
unsigned int amba_freq_hz
unsigned int cg_en_mask
struct irqmp_regs * irq
struct l4n2x_grcg_regs * cg
struct grpci2_regs * grpci2
struct drvmgr_map_entry bus_maps_up [2]
struct drvmgr_map_entry bus_maps_down [4]
struct ambapp_bus abus
struct ambapp_mmap amba_maps [5]
struct ambapp_config config
