RTEMS 6.3
#include <drvmgr.h>
Data Fields | |
| int(* | init [DRVMGR_LEVEL_MAX])(struct drvmgr_bus *) |
| int(*) | remove (struct drvmgr_bus *) |
| int(*) | unite (struct drvmgr_drv *, struct drvmgr_dev *) |
| int(*) | int_register (struct drvmgr_dev *, int index, const char *info, drvmgr_isr isr, void *arg) |
| int(*) | int_unregister (struct drvmgr_dev *, int index, drvmgr_isr isr, void *arg) |
| int(*) | int_clear (struct drvmgr_dev *, int index) |
| int(*) | int_mask (struct drvmgr_dev *, int index) |
| int(*) | int_unmask (struct drvmgr_dev *, int index) |
| int(*) | get_params (struct drvmgr_dev *, struct drvmgr_bus_params *) |
| int(*) | get_freq (struct drvmgr_dev *, int, unsigned int *) |
| void(*) | get_info_dev (struct drvmgr_dev *, void(*print)(void *p, char *str), void *p) |
Bus operations
| void(*) drvmgr_bus_ops::get_info_dev(struct drvmgr_dev *, void(*print)(void *p, char *str), void *p) |
Function called to request information about a device. The bus driver interpret the bus-specific information about the device.
| int(*) drvmgr_bus_ops::unite(struct drvmgr_drv *, struct drvmgr_dev *) |
Unite Hardware Device with Driver
