RTEMS 6.3
bootloader_api_entry_t Struct Reference
Root of the bootloader api tree. More...
void(*) runBootloader (void *arg)
const uint32_t version
const uint8_t * copyright
const uint32_t reserved0
flexspi_nor_driver_interface_t * flexSpiNorDriver
standard_version_t version
const char * copyright
const flexspi_nor_driver_interface_t * flexSpiNorDriver
const uint32_t reserved [8]
An instance of this struct resides in read-only memory in the bootloader. It provides a user application access to APIs exported by the bootloader.
Note
The order of existing fields must not be changed.
Field Documentation
◆ copyright [1/2]
const uint8_t* bootloader_api_entry_t::copyright
Bootloader Copyright
◆ copyright [2/2]
const char* bootloader_api_entry_t::copyright
Copyright string.
◆ flexSpiNorDriver [1/2]
flexspi_nor_driver_interface_t* bootloader_api_entry_t::flexSpiNorDriver
FLEXSPI NOR flash api
◆ flexSpiNorDriver [2/2]
const flexspi_nor_driver_interface_t* bootloader_api_entry_t::flexSpiNorDriver
FlexSPI NOR FLASH Driver API.
◆ reserved
const uint32_t bootloader_api_entry_t::reserved[8]
Reserved
◆ runBootloader
void(* bootloader_api_entry_t::runBootloader)(void *arg)
Function to start the bootloader executing
Function to start the bootloader executing.
◆ version [1/2]
const uint32_t bootloader_api_entry_t::version
Bootloader version number
◆ version [2/2]
standard_version_t bootloader_api_entry_t::version
Bootloader version number.
The documentation for this struct was generated from the following files:
