The SC16IS752 device configuration.
More...
#include <sc16is752.h>
const char * | device_path |
| | The device file path for the new device.
sc16is752_mode | mode |
| | The SC16IS752 mode.
uint32_t | input_frequency |
| | The input frequency in Hertz of the SC16IS752 chip. See XTAL1 and XTAL2 pins.
const char * | spi_path |
| | The SPI bus device path.
uint8_t | spi_chip_select |
| | The SPI chip select (starts with 0, the SPI driver uses SPI_ChipSelect(1 << spi_chip_select)).
uint32_t | spi_speed_hz |
| | The SPI bus speed in Hertz.
const Pin | irq_pin |
| | The interrupt pin, e.g. { PIO_PD28, PIOD, ID_PIOD, PIO_INPUT, PIO_IT_LOW_LEVEL }.
uint32_t | server_index |
| | The index to identify the interrupt server used for interrupt processing.
- See also
- atsam_sc16is752_spi_create().
