RTEMS 6.3
_rtems_rfs_inode Struct Reference
#include <rtems-rfs-inode.h>
union  [union].data
uint16_t links
uint16_t mode
uint32_t owner
uint16_t flags
uint16_t block_offset
uint32_t block_count
rtems_rfs_time atime
rtems_rfs_time mtime
rtems_rfs_time ctime
union  data
rtems_rfs_inode_block last_map_block
rtems_rfs_inode_block last_data_block
The inode.
Field Documentation
◆ atime
rtems_rfs_time _rtems_rfs_inode::atime
The access time. The last time the file was read.
◆ block_count
uint32_t _rtems_rfs_inode::block_count
Number of blocks held by this file.
◆ block_offset
uint16_t _rtems_rfs_inode::block_offset
Amount of data held in the last block data.
◆ ctime
rtems_rfs_time _rtems_rfs_inode::ctime
The change time. The last time the inode was written too.
◆ flags
uint16_t _rtems_rfs_inode::flags
Reserved.
◆ last_data_block
rtems_rfs_inode_block _rtems_rfs_inode::last_data_block
The last data block. Used as the goal when allocating a new block.
◆ last_map_block
rtems_rfs_inode_block _rtems_rfs_inode::last_map_block
The last block map block. Used as the goal when allocating a new block for use in the map.
◆ links
uint16_t _rtems_rfs_inode::links
The number of links to the inode.
◆ mode
uint16_t _rtems_rfs_inode::mode
The mode of the node.
◆ mtime
rtems_rfs_time _rtems_rfs_inode::mtime
The modified time. The last time the file was written too.
◆ owner
uint32_t _rtems_rfs_inode::owner
The owner of the node.
