RTEMS 6.3
_lpi2c_master_config Struct Reference
Structure with settings to initialize the LPI2C master module. More...
#include <fsl_lpi2c.h>
struct  [struct].hostRequest
bool enableMaster
bool enableDoze
bool debugEnable
bool ignoreAck
lpi2c_master_pin_config_t pinConfig
uint32_t baudRate_Hz
uint32_t busIdleTimeout_ns
uint32_t pinLowTimeout_ns
uint8_t sdaGlitchFilterWidth_ns
uint8_t sclGlitchFilterWidth_ns
struct  hostRequest
This structure holds configuration settings for the LPI2C peripheral. To initialize this structure to reasonable defaults, call the LPI2C_MasterGetDefaultConfig() function and pass a pointer to your configuration structure instance.
The configuration structure can be made constant so it resides in flash.
