RTEMS 6.3
_dcdc_setpoint_config Struct Reference
DCDC configuration in set point mode. More...
#include <fsl_dcdc.h>
uint32_t enableDCDCMap
uint32_t enableDigLogicMap
uint32_t lowpowerMap
uint32_t standbyMap
uint32_t standbyLowpowerMap
dcdc_buck_mode_1P8_target_vol_t * buckVDD1P8TargetVoltage
dcdc_buck_mode_1P0_target_vol_t * buckVDD1P0TargetVoltage
dcdc_standby_mode_1P8_target_vol_t * standbyVDD1P8TargetVoltage
dcdc_standby_mode_1P0_target_vol_t * standbyVDD1P0TargetVoltage
Field Documentation
◆ buckVDD1P0TargetVoltage
dcdc_buck_mode_1P0_target_vol_t* _dcdc_setpoint_config::buckVDD1P0TargetVoltage
Point to the array that store the target voltage level of VDD1P0 in buck mode, please refer to dcdc_buck_mode_1P0_target_vol_t. Note that the pointed array must have 16 elements.
◆ buckVDD1P8TargetVoltage
dcdc_buck_mode_1P8_target_vol_t* _dcdc_setpoint_config::buckVDD1P8TargetVoltage
Point to the array that store the target voltage level of VDD1P8 in buck mode, please refer to dcdc_buck_mode_1P8_target_vol_t. Note that the pointed array must have 16 elements.
◆ enableDCDCMap
uint32_t _dcdc_setpoint_config::enableDCDCMap
The setpoint map that enable the DCDC module. Should be the OR'ed value of _dcdc_setpoint_map.
◆ enableDigLogicMap
uint32_t _dcdc_setpoint_config::enableDigLogicMap
The setpoint map that enable the DCDC dig logic. Should be the OR'ed value of _dcdc_setpoint_map.
◆ lowpowerMap
uint32_t _dcdc_setpoint_config::lowpowerMap
The setpoint map that enable the DCDC Low powermode. Should be the OR'ed value of _dcdc_setpoint_map.
◆ standbyLowpowerMap
uint32_t _dcdc_setpoint_config::standbyLowpowerMap
The setpoint map that enable the DCDC low power mode, when the related setpoint is in standby mode. Please refer to _dcdc_setpoint_map.
◆ standbyMap
uint32_t _dcdc_setpoint_config::standbyMap
The setpoint map that enable the DCDC standby mode. Should be the OR'ed value of _dcdc_setpoint_map.
◆ standbyVDD1P0TargetVoltage
dcdc_standby_mode_1P0_target_vol_t* _dcdc_setpoint_config::standbyVDD1P0TargetVoltage
Point to the array that store the target voltage level of VDD1P0 in standby mode, please refer to dcdc_standby_mode_1P0_target_vol_t. Note that the pointed array must have 16 elements.
◆ standbyVDD1P8TargetVoltage
dcdc_standby_mode_1P8_target_vol_t* _dcdc_setpoint_config::standbyVDD1P8TargetVoltage
Point to the array that store the target voltage level of VDD1P8 in standby mode, please refer to dcdc_standby_mode_1P8_target_vol_t. Note that the pointed array must have 16 elements.
