RTEMS 6.3
Test context for spec:/score/tq/req/timeout-mrsp test case. More...
| struct | [struct].Map |
Data Fields | |
| bool | other_scheduler |
| If this member is true, then the enqueued thread shall use a home scheduler other than the home scheduler of the owner. | |
| bool | restore_scheduler |
| If this member is true, then the processor set of the schedulers shall be restored. | |
| TQContext * | tq_ctx |
| This member contains a copy of the corresponding ScoreTqReqTimeoutMrsp_Run() parameter. | |
| struct | Map |
