RTEMS 6.3
Test context for spec:/score/tq/req/surrender test case. More...
struct  [struct].Map
CallWithinISRRequest request
 This member contains the call within ISR request.
SMP_barrier_Control barrier
 This member contains the barrier to synchronize the runner and the worker.
bool intend_to_block
 If this member is true, then the dequeued thread shall be in the intend to block wait state.
uint32_t expected_blocker_b_counter
 If this member contains the expected counter of worker B.
TQContext * tq_ctx
 This member contains a copy of the corresponding ScoreTqReqSurrender_Run() parameter.
struct  Map
