RTEMS 6.3
Test context for spec:/score/tq/req/flush-priority-inherit test case. More...
struct  [struct].Map
CallWithinISRRequest request
 This member contains the call within ISR request.
bool minimum
 If this member is true, then a minimum priority of the owner of the thread queue shall be inherited from a thread enqueued on the thread queue.
TQContext * tq_ctx
 This member contains a copy of the corresponding ScoreTqReqFlushPriorityInherit_Run() parameter.
struct  Map
