RTEMS 6.3
Test context for spec:/score/tq/req/flush-fifo test case. More...
| struct | [struct].Map |
Data Fields | |
| bool | stop |
| If this member is true, then the flush filter shall return NULL. | |
| bool | intend_to_block |
| If this member is true, then the least recently enqueued thread shall be in the intend to block wait state. | |
| CallWithinISRRequest | request |
| This member contains the call within ISR request. | |
| TQContext * | tq_ctx |
| This member contains a copy of the corresponding ScoreTqReqFlushFifo_Run() parameter. | |
| bool | may_stop |
| struct | Map |
