RTEMS 6.3
Test context for spec:/score/tq/req/enqueue-deadlock test case. More...
struct  [struct].Map
bool more
 If this member is true, then more than one mutex shall be used for the deadlock scenario.
TQContext * tq_ctx
 This member contains a copy of the corresponding ScoreTqReqEnqueueDeadlock_Run() parameter.
struct  Map
