RTEMS 6.3
Test context for spec:/score/tq/req/enqueue-ceiling test case. More...
struct  [struct].Map
bool helping
 This this member is true, then the enqueueing thread shall have at least one helping scheduler.
rtems_task_priority priority
 This member specifies the priority of a thread with an eligible scheduler equal to an eligible scheduler of the enqueueing thread.
size_t other_before
 If this member is true, then a thread those eligible schedulers are ineligible scheduler to the enqueueing task should be enqueued before a thread with an eligible scheduler equal to an eligible scheduler of the enqueueing thread.
size_t other_after
 If this member is true, then a thread those eligible schedulers are ineligible scheduler to the enqueueing task should be enqueued after a thread with an eligible scheduler equal to an eligible scheduler of the enqueueing thread.
TQContext * tq_ctx
 This member contains a copy of the corresponding ScoreTqReqEnqueueCeiling_Run() parameter.
struct  Map
