RTEMS 6.3
Test context for spec:/score/sem/req/seize-try test case. More...
struct  [struct].Map
uint32_t count_before
 This member specifies the semaphore count before the directive call.
Status_Control status
 This member contains the return status of the directive call.
uint32_t count_after
 This member contains the semaphore count after the directive call.
TQSemContext * tq_ctx
 This member contains a copy of the corresponding ScoreSemReqSeizeTry_Run() parameter.
struct  Map
