RTEMS 6.3
Test context for spec:/score/sched/req/yield test case. More...
struct  [struct].Map
TQContext tq_ctx
 This member contains the thread queue test context.
rtems_id sticky_mutex
 This member contains the identifier of a sticky mutex.
uint32_t cpu_after_yield
 This member contains the processor index after yielding.
bool has_helping
 If this member is true, then the runner shall have a helping scheduler.
bool use_helping
 If this member is true, then the runner shall use a helping scheduler.
bool ready
 If this member is true, then the runner shall be ready in its home scheduler.
bool sticky
 If this member is true, then the runner shall be sticky.
bool other_ready
 If this member is true, then another ready task in the home scheduler of the runner shall be ready with an equal priority.
bool is_idle_before_yield
 If this member is true, then the processor zero was idle before yielding.
bool is_idle_after_yield
 If this member is true, then the processor zero was idle after yielding.
struct  Map
