RTEMS 6.3
Test context for spec:/score/mtx/req/seize-wait test case. More...
struct  [struct].Map
bool owner_caller
 If this member is true, then the calling thread shall be the owner of the mutex.
bool owner_other
 If this member is true, then a thread other than the calling thread shall be the owner of the mutex.
bool deadlock
 If this member is true, then a deadlock shall occur.
rtems_task_priority priority_before
 This member contains the current priority of the calling thread before the directive call.
const rtems_tcb * owner_after
 This member contains the owner of the mutex after the directive call.
rtems_task_priority priority_after
 This member contains the current priority of the calling thread after the directive call.
TQMtxContext * tq_ctx
 This member contains a copy of the corresponding ScoreMtxReqSeizeWait_Run() parameter.
struct  Map
