RTEMS 6.3
Test context for spec:/rtems/support/req/is-name-valid test case. More...
struct  [struct].Map
bool result
 This member contains the return value of the rtems_is_name_valid() call.
rtems_name name
 This member specifies if the name parameter value.
struct  Map
