RTEMS 6.3
Test context for spec:/rtems/sem/req/flush test case. More...
struct  [struct].Map
TQContext tq_ctx
 This member contains the thread queue test context.
rtems_attribute attribute_set
 This member specifies if the attribute set of the semaphore.
uint32_t initial_count
 This member specifies if the initial count of the semaphore.
struct  Map
