RTEMS 6.3
Test context for spec:/rtems/io/req/getchark test case. More...
struct  [struct].Map
size_t input_count
 This member contains the character input count.
BSP_polling_getchar_function_type poll_char
 This member specifies the value for BSP_poll_char.
int result
 This member contains the return value of the getchark() call.
struct  Map
