RTEMS 6.3
Data Fields | |
| uint32_t | node |
| uint32_t | maximum_nodes |
| uint32_t | maximum_global_objects |
| uint32_t | maximum_proxies |
| uint32_t | extra_mpci_receive_server_stack |
| MPCI_Control * | User_mpci_table |
| uint32_t MPCI_Configuration::extra_mpci_receive_server_stack |
The MPCI Receive server is assumed to have a stack of at least minimum stack size. This field specifies the amount of extra stack this task will be given in bytes.
| uint32_t MPCI_Configuration::maximum_global_objects |
This is the maximum number of global objects.
| uint32_t MPCI_Configuration::maximum_nodes |
This is the maximum number of nodes in system.
| uint32_t MPCI_Configuration::maximum_proxies |
This is the maximum number of proxies.
| uint32_t MPCI_Configuration::node |
This is the local node number.
| MPCI_Control* MPCI_Configuration::User_mpci_table |
This is a pointer to User/BSP provided MPCI Table.
