RTEMS 6.3
The structure is used to organize message buffers of a message queue. More...
#include <coremsgbuffer.h>
Data Fields | |
| Chain_Node | Node |
| This member is used to enqueue the buffer in the pending or free buffer queue of a message queue. | |
| size_t | size |
| This member defines the size of this message. | |
| int | priority |
| This member defines the priority of this message. | |
| size_t | buffer [RTEMS_ZERO_LENGTH_ARRAY] |
| This member contains the actual message. | |
| size_t CORE_message_queue_Buffer::buffer[RTEMS_ZERO_LENGTH_ARRAY] |
This is a zero-length array since the maximum message size is defined by the user. Use a size_t array to make sure that the member offset is at the structure end. This enables a more efficient memcpy() on 64-bit targets and makes it easier to inspect the message buffers with a debugger.
