RTEMS
6.3
Toggle main menu visibility
bsps
arm
stm32h7
include
stm32h7xx_ll_wwdg.h
1
18
19
/* Define to prevent recursive inclusion -------------------------------------*/
20
#ifndef STM32H7xx_LL_WWDG_H
21
#define STM32H7xx_LL_WWDG_H
22
23
#ifdef __cplusplus
24
extern
"C"
25
#endif
26
27
/* Includes ------------------------------------------------------------------*/
28
#include "
stm32h7xx.h
29
33
34
#if defined (WWDG1) || defined (WWDG2)
35
40
41
/* Private types -------------------------------------------------------------*/
42
/* Private variables ---------------------------------------------------------*/
43
/* Private constants ---------------------------------------------------------*/
44
/* Private macros ------------------------------------------------------------*/
45
/* Exported types ------------------------------------------------------------*/
46
/* Exported constants --------------------------------------------------------*/
51
57
#define LL_WWDG_CFR_EWI WWDG_CFR_EWI
61
66
#define LL_WWDG_PRESCALER_1 0x00000000u
67
#define LL_WWDG_PRESCALER_2 WWDG_CFR_WDGTB_0
68
#define LL_WWDG_PRESCALER_4 WWDG_CFR_WDGTB_1
69
#define LL_WWDG_PRESCALER_8 (WWDG_CFR_WDGTB_0 | WWDG_CFR_WDGTB_1)
70
#define LL_WWDG_PRESCALER_16 WWDG_CFR_WDGTB_2
71
#define LL_WWDG_PRESCALER_32 (WWDG_CFR_WDGTB_2 | WWDG_CFR_WDGTB_0)
72
#define LL_WWDG_PRESCALER_64 (WWDG_CFR_WDGTB_2 | WWDG_CFR_WDGTB_1)
73
#define LL_WWDG_PRESCALER_128 (WWDG_CFR_WDGTB_2 | WWDG_CFR_WDGTB_1 | WWDG_CFR_WDGTB_0)
77
81
82
/* Exported macro ------------------------------------------------------------*/
98
#define LL_WWDG_WriteReg(__INSTANCE__, __REG__, __VALUE__) WRITE_REG(__INSTANCE__->__REG__, (__VALUE__))
99
106
#define LL_WWDG_ReadReg(__INSTANCE__, __REG__) READ_REG(__INSTANCE__->__REG__)
110
114
115
/* Exported functions --------------------------------------------------------*/
120
135
__STATIC_INLINE
void
LL_WWDG_Enable(
WWDG_TypeDef
*WWDGx)
136
137
SET_BIT(WWDGx->
CR
WWDG_CR_WDGA
138
139
146
__STATIC_INLINE uint32_t LL_WWDG_IsEnabled(
WWDG_TypeDef
*WWDGx)
147
148
return
((READ_BIT(WWDGx->
CR
WWDG_CR_WDGA
WWDG_CR_WDGA
)) ? 1UL : 0UL);
149
150
162
__STATIC_INLINE
void
LL_WWDG_SetCounter(
WWDG_TypeDef
*WWDGx, uint32_t Counter)
163
164
MODIFY_REG(WWDGx->
CR
WWDG_CR_T
, Counter);
165
166
173
__STATIC_INLINE uint32_t LL_WWDG_GetCounter(
WWDG_TypeDef
*WWDGx)
174
175
return
(READ_BIT(WWDGx->
CR
WWDG_CR_T
176
177
195
__STATIC_INLINE
void
LL_WWDG_SetPrescaler(
WWDG_TypeDef
*WWDGx, uint32_t Prescaler)
196
197
MODIFY_REG(WWDGx->
CFR
WWDG_CFR_WDGTB
, Prescaler);
198
199
214
__STATIC_INLINE uint32_t LL_WWDG_GetPrescaler(
WWDG_TypeDef
*WWDGx)
215
216
return
(READ_BIT(WWDGx->
CFR
WWDG_CFR_WDGTB
217
218
235
__STATIC_INLINE
void
LL_WWDG_SetWindow(
WWDG_TypeDef
*WWDGx, uint32_t Window)
236
237
MODIFY_REG(WWDGx->
CFR
WWDG_CFR_W
, Window);
238
239
246
__STATIC_INLINE uint32_t LL_WWDG_GetWindow(
WWDG_TypeDef
*WWDGx)
247
248
return
(READ_BIT(WWDGx->
CFR
WWDG_CFR_W
249
250
254
268
__STATIC_INLINE uint32_t LL_WWDG_IsActiveFlag_EWKUP(
WWDG_TypeDef
*WWDGx)
269
270
return
((READ_BIT(WWDGx->
SR
WWDG_SR_EWIF
WWDG_SR_EWIF
)) ? 1UL : 0UL);
271
272
279
__STATIC_INLINE
void
LL_WWDG_ClearFlag_EWKUP(
WWDG_TypeDef
*WWDGx)
280
281
WRITE_REG(WWDGx->
SR
WWDG_SR_EWIF
282
283
287
300
__STATIC_INLINE
void
LL_WWDG_EnableIT_EWKUP(
WWDG_TypeDef
*WWDGx)
301
302
SET_BIT(WWDGx->
CFR
WWDG_CFR_EWI
303
304
311
__STATIC_INLINE uint32_t LL_WWDG_IsEnabledIT_EWKUP(
WWDG_TypeDef
*WWDGx)
312
313
return
((READ_BIT(WWDGx->
CFR
WWDG_CFR_EWI
WWDG_CFR_EWI
)) ? 1UL : 0UL);
314
315
319
323
327
328
#endif
/* WWDG1 || WWDG2 */
329
333
334
#ifdef __cplusplus
335
336
#endif
337
338
#endif
/* STM32H7xx_LL_WWDG_H */
WWDG_CFR_WDGTB
#define WWDG_CFR_WDGTB
Definition
stm32h723xx.h:21536
WWDG_CR_T
#define WWDG_CR_T
Definition
stm32h723xx.h:21505
WWDG_CFR_EWI
#define WWDG_CFR_EWI
Definition
stm32h723xx.h:21532
WWDG_SR_EWIF
#define WWDG_SR_EWIF
Definition
stm32h723xx.h:21544
WWDG_CR_WDGA
#define WWDG_CR_WDGA
Definition
stm32h723xx.h:21516
WWDG_CFR_W
#define WWDG_CFR_W
Definition
stm32h723xx.h:21521
stm32h7xx.h
CMSIS STM32H7xx Device Peripheral Access Layer Header File.
WWDG_TypeDef
Window WATCHDOG.
Definition
stm32h723xx.h:1633
WWDG_TypeDef::SR
__IO uint32_t SR
Definition
stm32h723xx.h:1636
WWDG_TypeDef::CR
__IO uint32_t CR
Definition
stm32h723xx.h:1634
WWDG_TypeDef::CFR
__IO uint32_t CFR
Definition
stm32h723xx.h:1635
