RTEMS 6.3
Header file of BUS LL module. More...
#include "stm32h7xx.h"Go to the source code of this file.
##### RCC Limitations #####
A delay between an RCC peripheral clock enable and the effective peripheral
enabling should be taken into account in order to manage the peripheral read/write
from/to registers.
(+) This delay depends on the peripheral mapping.
(++) AHB & APB peripherals, 1 dummy read is necessary
Workarounds:
(#) For AHB & APB peripherals, a dummy read to the peripheral register has been
inserted in each LL_{BUS}_GRP{x}_EnableClock() function.
