RTEMS 6.3
stm32h7xx_hal_smartcard.h File Reference
Header file of SMARTCARD HAL module. More...
struct  SMARTCARD_InitTypeDef
 SMARTCARD Init Structure definition. More...
struct  SMARTCARD_AdvFeatureInitTypeDef
 SMARTCARD advanced features initialization structure definition. More...
struct  __SMARTCARD_HandleTypeDef
 SMARTCARD handle Structure definition. More...
#define HAL_SMARTCARD_STATE_RESET   0x00000000U
#define HAL_SMARTCARD_STATE_READY   0x00000020U
#define HAL_SMARTCARD_STATE_BUSY   0x00000024U
#define HAL_SMARTCARD_STATE_BUSY_TX   0x00000021U
#define HAL_SMARTCARD_STATE_BUSY_RX   0x00000022U
#define HAL_SMARTCARD_STATE_BUSY_TX_RX   0x00000023U
#define HAL_SMARTCARD_STATE_TIMEOUT   0x000000A0U
#define HAL_SMARTCARD_STATE_ERROR   0x000000E0U
#define HAL_SMARTCARD_ERROR_NONE   (0x00000000U)
#define HAL_SMARTCARD_ERROR_PE   (0x00000001U)
#define HAL_SMARTCARD_ERROR_NE   (0x00000002U)
#define HAL_SMARTCARD_ERROR_FE   (0x00000004U)
#define HAL_SMARTCARD_ERROR_ORE   (0x00000008U)
#define HAL_SMARTCARD_ERROR_DMA   (0x00000010U)
#define HAL_SMARTCARD_ERROR_RTO   (0x00000020U)
#define SMARTCARD_WORDLENGTH_9B   USART_CR1_M0
#define SMARTCARD_STOPBITS_0_5   USART_CR2_STOP_0
#define SMARTCARD_STOPBITS_1_5   USART_CR2_STOP
#define SMARTCARD_PARITY_EVEN   USART_CR1_PCE
#define SMARTCARD_PARITY_ODD   (USART_CR1_PCE | USART_CR1_PS)
#define SMARTCARD_MODE_RX   USART_CR1_RE
#define SMARTCARD_MODE_TX   USART_CR1_TE
#define SMARTCARD_MODE_TX_RX   (USART_CR1_TE |USART_CR1_RE)
#define SMARTCARD_POLARITY_LOW   0x00000000U
#define SMARTCARD_POLARITY_HIGH   USART_CR2_CPOL
#define SMARTCARD_PHASE_1EDGE   0x00000000U
#define SMARTCARD_PHASE_2EDGE   USART_CR2_CPHA
#define SMARTCARD_LASTBIT_DISABLE   0x00000000U
#define SMARTCARD_LASTBIT_ENABLE   USART_CR2_LBCL
#define SMARTCARD_ONE_BIT_SAMPLE_DISABLE   0x00000000U
#define SMARTCARD_ONE_BIT_SAMPLE_ENABLE   USART_CR3_ONEBIT
#define SMARTCARD_NACK_DISABLE   0x00000000U
#define SMARTCARD_NACK_ENABLE   USART_CR3_NACK
#define SMARTCARD_TIMEOUT_DISABLE   0x00000000U
#define SMARTCARD_TIMEOUT_ENABLE   USART_CR2_RTOEN
#define SMARTCARD_PRESCALER_DIV1   0x00000000U
#define SMARTCARD_PRESCALER_DIV2   0x00000001U
#define SMARTCARD_PRESCALER_DIV4   0x00000002U
#define SMARTCARD_PRESCALER_DIV6   0x00000003U
#define SMARTCARD_PRESCALER_DIV8   0x00000004U
#define SMARTCARD_PRESCALER_DIV10   0x00000005U
#define SMARTCARD_PRESCALER_DIV12   0x00000006U
#define SMARTCARD_PRESCALER_DIV16   0x00000007U
#define SMARTCARD_PRESCALER_DIV32   0x00000008U
#define SMARTCARD_PRESCALER_DIV64   0x00000009U
#define SMARTCARD_PRESCALER_DIV128   0x0000000AU
#define SMARTCARD_PRESCALER_DIV256   0x0000000BU
#define SMARTCARD_ADVFEATURE_TXINV_DISABLE   0x00000000U
#define SMARTCARD_ADVFEATURE_TXINV_ENABLE   USART_CR2_TXINV
#define SMARTCARD_ADVFEATURE_RXINV_DISABLE   0x00000000U
#define SMARTCARD_ADVFEATURE_RXINV_ENABLE   USART_CR2_RXINV
#define SMARTCARD_ADVFEATURE_DATAINV_DISABLE   0x00000000U
#define SMARTCARD_ADVFEATURE_DATAINV_ENABLE   USART_CR2_DATAINV
#define SMARTCARD_ADVFEATURE_SWAP_DISABLE   0x00000000U
#define SMARTCARD_ADVFEATURE_SWAP_ENABLE   USART_CR2_SWAP
#define SMARTCARD_ADVFEATURE_OVERRUN_ENABLE   0x00000000U
#define SMARTCARD_ADVFEATURE_OVERRUN_DISABLE   USART_CR3_OVRDIS
#define SMARTCARD_ADVFEATURE_DMA_ENABLEONRXERROR   0x00000000U
#define SMARTCARD_ADVFEATURE_DMA_DISABLEONRXERROR   USART_CR3_DDRE
#define SMARTCARD_ADVFEATURE_MSBFIRST_DISABLE   0x00000000U
#define SMARTCARD_ADVFEATURE_MSBFIRST_ENABLE   USART_CR2_MSBFIRST
#define SMARTCARD_RXDATA_FLUSH_REQUEST   USART_RQR_RXFRQ
#define SMARTCARD_TXDATA_FLUSH_REQUEST   USART_RQR_TXFRQ
#define SMARTCARD_IT_MASK   0x001FU
#define SMARTCARD_CR_MASK   0x00E0U
#define SMARTCARD_CR_POS   5U
#define SMARTCARD_ISR_MASK   0x1F00U
#define SMARTCARD_ISR_POS   8U
#define __HAL_SMARTCARD_RESET_HANDLE_STATE(__HANDLE__)
 Reset SMARTCARD handle states.
#define __HAL_SMARTCARD_FLUSH_DRREGISTER(__HANDLE__)
 Flush the Smartcard Data registers.
#define __HAL_SMARTCARD_CLEAR_FLAG(__HANDLE__, __FLAG__)
 Clear the specified SMARTCARD pending flag.
#define __HAL_SMARTCARD_CLEAR_PEFLAG(__HANDLE__)
 Clear the SMARTCARD PE pending flag.
#define __HAL_SMARTCARD_CLEAR_FEFLAG(__HANDLE__)
 Clear the SMARTCARD FE pending flag.
#define __HAL_SMARTCARD_CLEAR_NEFLAG(__HANDLE__)
 Clear the SMARTCARD NE pending flag.
#define __HAL_SMARTCARD_CLEAR_OREFLAG(__HANDLE__)
 Clear the SMARTCARD ORE pending flag.
#define __HAL_SMARTCARD_CLEAR_IDLEFLAG(__HANDLE__)
 Clear the SMARTCARD IDLE pending flag.
#define __HAL_SMARTCARD_GET_FLAG(__HANDLE__, __FLAG__)
 Check whether the specified Smartcard flag is set or not.
#define __HAL_SMARTCARD_ENABLE_IT(__HANDLE__, __INTERRUPT__)
 Enable the specified SmartCard interrupt.
#define __HAL_SMARTCARD_DISABLE_IT(__HANDLE__, __INTERRUPT__)
 Disable the specified SmartCard interrupt.
#define __HAL_SMARTCARD_GET_IT(__HANDLE__, __INTERRUPT__)
 Check whether the specified SmartCard interrupt has occurred or not.
#define __HAL_SMARTCARD_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)
 Check whether the specified SmartCard interrupt source is enabled or not.
#define __HAL_SMARTCARD_CLEAR_IT(__HANDLE__, __IT_CLEAR__)
 Clear the specified SMARTCARD ISR flag, in setting the proper ICR register flag.
#define __HAL_SMARTCARD_SEND_REQ(__HANDLE__, __REQ__)
 Set a specific SMARTCARD request flag.
#define __HAL_SMARTCARD_ONE_BIT_SAMPLE_ENABLE(__HANDLE__)
 Enable the SMARTCARD one bit sample method.
#define __HAL_SMARTCARD_ONE_BIT_SAMPLE_DISABLE(__HANDLE__)
 Disable the SMARTCARD one bit sample method.
#define __HAL_SMARTCARD_ENABLE(__HANDLE__)
 Enable the USART associated to the SMARTCARD Handle.
#define __HAL_SMARTCARD_DISABLE(__HANDLE__)
 Disable the USART associated to the SMARTCARD Handle.
#define SMARTCARD_GETCLOCKSOURCE(__HANDLE__, __CLOCKSOURCE__)
 Report the SMARTCARD clock source.
#define IS_SMARTCARD_BAUDRATE(__BAUDRATE__)
 Check the Baud rate range.
#define IS_SMARTCARD_BLOCKLENGTH(__LENGTH__)
 Check the block length range.
#define IS_SMARTCARD_TIMEOUT_VALUE(__TIMEOUTVALUE__)
 Check the receiver timeout value.
#define IS_SMARTCARD_AUTORETRY_COUNT(__COUNT__)
 Check the SMARTCARD autoretry counter value.
#define IS_SMARTCARD_WORD_LENGTH(__LENGTH__)
 Ensure that SMARTCARD frame length is valid.
#define IS_SMARTCARD_STOPBITS(__STOPBITS__)
 Ensure that SMARTCARD frame number of stop bits is valid.
#define IS_SMARTCARD_PARITY(__PARITY__)
 Ensure that SMARTCARD frame parity is valid.
#define IS_SMARTCARD_MODE(__MODE__)
 Ensure that SMARTCARD communication mode is valid.
#define IS_SMARTCARD_POLARITY(__CPOL__)
 Ensure that SMARTCARD frame polarity is valid.
#define IS_SMARTCARD_PHASE(__CPHA__)
 Ensure that SMARTCARD frame phase is valid.
#define IS_SMARTCARD_LASTBIT(__LASTBIT__)
 Ensure that SMARTCARD frame last bit clock pulse setting is valid.
#define IS_SMARTCARD_ONE_BIT_SAMPLE(__ONEBIT__)
 Ensure that SMARTCARD frame sampling is valid.
#define IS_SMARTCARD_NACK(__NACK__)
 Ensure that SMARTCARD NACK transmission setting is valid.
#define IS_SMARTCARD_TIMEOUT(__TIMEOUT__)
 Ensure that SMARTCARD receiver timeout setting is valid.
#define IS_SMARTCARD_CLOCKPRESCALER(__CLOCKPRESCALER__)
 Ensure that SMARTCARD clock Prescaler is valid.
#define IS_SMARTCARD_ADVFEATURE_INIT(__INIT__)
 Ensure that SMARTCARD advanced features initialization is valid.
#define IS_SMARTCARD_ADVFEATURE_TXINV(__TXINV__)
 Ensure that SMARTCARD frame TX inversion setting is valid.
#define IS_SMARTCARD_ADVFEATURE_RXINV(__RXINV__)
 Ensure that SMARTCARD frame RX inversion setting is valid.
#define IS_SMARTCARD_ADVFEATURE_DATAINV(__DATAINV__)
 Ensure that SMARTCARD frame data inversion setting is valid.
#define IS_SMARTCARD_ADVFEATURE_SWAP(__SWAP__)
 Ensure that SMARTCARD frame RX/TX pins swap setting is valid.
#define IS_SMARTCARD_OVERRUN(__OVERRUN__)
 Ensure that SMARTCARD frame overrun setting is valid.
#define IS_SMARTCARD_ADVFEATURE_DMAONRXERROR(__DMA__)
 Ensure that SMARTCARD DMA enabling or disabling on error setting is valid.
#define IS_SMARTCARD_ADVFEATURE_MSBFIRST(__MSBFIRST__)
 Ensure that SMARTCARD frame MSB first setting is valid.
#define IS_SMARTCARD_REQUEST_PARAMETER(__PARAM__)
 Ensure that SMARTCARD request parameter is valid.
typedef uint32_t HAL_SMARTCARD_StateTypeDef
 HAL SMARTCARD State definition.
typedef struct __SMARTCARD_HandleTypeDef SMARTCARD_HandleTypeDef
enum  SMARTCARD_ClockSourceTypeDef {
  SMARTCARD_CLOCKSOURCE_D2PCLK1 = 0x00U , SMARTCARD_CLOCKSOURCE_D2PCLK2 = 0x01U , SMARTCARD_CLOCKSOURCE_HSI = 0x04U , SMARTCARD_CLOCKSOURCE_CSI = 0x08U ,
  SMARTCARD_CLOCKSOURCE_LSE = 0x20U , SMARTCARD_CLOCKSOURCE_PLL2Q = 0x40U , SMARTCARD_CLOCKSOURCE_PLL3Q = 0x80U , SMARTCARD_CLOCKSOURCE_UNDEFINED = 0x10U
 SMARTCARD clock sources. More...
HAL_StatusTypeDef HAL_SMARTCARD_Init (SMARTCARD_HandleTypeDef *hsmartcard)
HAL_StatusTypeDef HAL_SMARTCARD_DeInit (SMARTCARD_HandleTypeDef *hsmartcard)
void HAL_SMARTCARD_MspInit (SMARTCARD_HandleTypeDef *hsmartcard)
void HAL_SMARTCARD_MspDeInit (SMARTCARD_HandleTypeDef *hsmartcard)
HAL_StatusTypeDef HAL_SMARTCARD_Transmit (SMARTCARD_HandleTypeDef *hsmartcard, const uint8_t *pData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_SMARTCARD_Receive (SMARTCARD_HandleTypeDef *hsmartcard, uint8_t *pData, uint16_t Size, uint32_t Timeout)
HAL_StatusTypeDef HAL_SMARTCARD_Transmit_IT (SMARTCARD_HandleTypeDef *hsmartcard, const uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_SMARTCARD_Receive_IT (SMARTCARD_HandleTypeDef *hsmartcard, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_SMARTCARD_Transmit_DMA (SMARTCARD_HandleTypeDef *hsmartcard, const uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_SMARTCARD_Receive_DMA (SMARTCARD_HandleTypeDef *hsmartcard, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_SMARTCARD_Abort (SMARTCARD_HandleTypeDef *hsmartcard)
HAL_StatusTypeDef HAL_SMARTCARD_AbortTransmit (SMARTCARD_HandleTypeDef *hsmartcard)
HAL_StatusTypeDef HAL_SMARTCARD_AbortReceive (SMARTCARD_HandleTypeDef *hsmartcard)
HAL_StatusTypeDef HAL_SMARTCARD_Abort_IT (SMARTCARD_HandleTypeDef *hsmartcard)
HAL_StatusTypeDef HAL_SMARTCARD_AbortTransmit_IT (SMARTCARD_HandleTypeDef *hsmartcard)
HAL_StatusTypeDef HAL_SMARTCARD_AbortReceive_IT (SMARTCARD_HandleTypeDef *hsmartcard)
void HAL_SMARTCARD_IRQHandler (SMARTCARD_HandleTypeDef *hsmartcard)
void HAL_SMARTCARD_TxCpltCallback (SMARTCARD_HandleTypeDef *hsmartcard)
void HAL_SMARTCARD_RxCpltCallback (SMARTCARD_HandleTypeDef *hsmartcard)
void HAL_SMARTCARD_ErrorCallback (SMARTCARD_HandleTypeDef *hsmartcard)
void HAL_SMARTCARD_AbortCpltCallback (SMARTCARD_HandleTypeDef *hsmartcard)
void HAL_SMARTCARD_AbortTransmitCpltCallback (SMARTCARD_HandleTypeDef *hsmartcard)
void HAL_SMARTCARD_AbortReceiveCpltCallback (SMARTCARD_HandleTypeDef *hsmartcard)
HAL_SMARTCARD_StateTypeDef HAL_SMARTCARD_GetState (const SMARTCARD_HandleTypeDef *hsmartcard)
uint32_t HAL_SMARTCARD_GetError (const SMARTCARD_HandleTypeDef *hsmartcard)
Author
MCD Application Team
Attention
