RTEMS 6.3
RNG HAL module driver. This file provides firmware functions to manage the following functionalities of the Random Number Generator (RNG) peripheral: More...
#include "stm32h7xx_hal.h"RNG HAL module driver. This file provides firmware functions to manage the following functionalities of the Random Number Generator (RNG) peripheral:
##### How to use this driver #####
The RNG HAL driver can be used as follows:
(#) Enable the RNG controller clock using __HAL_RCC_RNG_CLK_ENABLE() macro
in HAL_RNG_MspInit().
(#) Activate the RNG peripheral using HAL_RNG_Init() function.
(#) Wait until the 32 bit Random Number Generator contains a valid
random data using (polling/interrupt) mode.
(#) Get the 32 bit random number using HAL_RNG_GenerateRandomNumber() function.
##### Callback registration #####
The compilation define USE_HAL_RNG_REGISTER_CALLBACKS when set to 1
allows the user to configure dynamically the driver callbacks.
Use Function HAL_RNG_RegisterCallback() to register a user callback.
Function HAL_RNG_RegisterCallback() allows to register following callbacks:
(+) ErrorCallback : RNG Error Callback.
(+) MspInitCallback : RNG MspInit.
(+) MspDeInitCallback : RNG MspDeInit.
This function takes as parameters the HAL peripheral handle, the Callback ID
and a pointer to the user callback function.
Use function HAL_RNG_UnRegisterCallback() to reset a callback to the default
weak (overridden) function.
HAL_RNG_UnRegisterCallback() takes as parameters the HAL peripheral handle,
and the Callback ID.
This function allows to reset following callbacks:
For specific callback ReadyDataCallback, use dedicated register callbacks:
respectively HAL_RNG_RegisterReadyDataCallback() , HAL_RNG_UnRegisterReadyDataCallback().
By default, after the HAL_RNG_Init() and when the state is HAL_RNG_STATE_RESET
all callbacks are set to the corresponding weak (overridden) functions:
example HAL_RNG_ErrorCallback().
Exception done for MspInit and MspDeInit functions that are respectively
reset to the legacy weak (overridden) functions in the HAL_RNG_Init()
and HAL_RNG_DeInit() only when these callbacks are null (not registered beforehand).
If not, MspInit or MspDeInit are not null, the HAL_RNG_Init() and HAL_RNG_DeInit()
keep and use the user MspInit/MspDeInit callbacks (registered beforehand).
Callbacks can be registered/unregistered in HAL_RNG_STATE_READY state only.
Exception done MspInit/MspDeInit that can be registered/unregistered
in HAL_RNG_STATE_READY or HAL_RNG_STATE_RESET state, thus registered (user)
MspInit/DeInit callbacks can be used during the Init/DeInit.
In that case first register the MspInit/MspDeInit user callbacks
using HAL_RNG_RegisterCallback() before calling HAL_RNG_DeInit()
or HAL_RNG_Init() function.
When The compilation define USE_HAL_RNG_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registration feature is not available
and weak (overridden) callbacks are used.
