RTEMS 6.3
PCD HAL module driver. This file provides firmware functions to manage the following functionalities of the USB Peripheral Controller: More...
#include "stm32h7xx_hal.h"PCD HAL module driver. This file provides firmware functions to manage the following functionalities of the USB Peripheral Controller:
##### How to use this driver #####
The PCD HAL driver can be used as follows:
(#) Declare a PCD_HandleTypeDef handle structure, for example:
PCD_HandleTypeDef hpcd;
(#) Fill parameters of Init structure in HCD handle
(#) Call HAL_PCD_Init() API to initialize the PCD peripheral (Core, Device core, ...)
(#) Initialize the PCD low level resources through the HAL_PCD_MspInit() API:
(##) Enable the PCD/USB Low Level interface clock using
(+++) __HAL_RCC_USB_OTG_FS_CLK_ENABLE();
(+++) __HAL_RCC_USB_OTG_HS_CLK_ENABLE(); (For High Speed Mode)
(##) Initialize the related GPIO clocks
(##) Configure PCD pin-out
(##) Configure PCD NVIC interrupt
(#)Associate the Upper USB device stack to the HAL PCD Driver:
(##) hpcd.pData = pdev;
(#)Enable PCD transmission and reception:
(##) HAL_PCD_Start();
