RTEMS 6.3
Extended OPAMP HAL module driver. This file provides firmware functions to manage the following functionalities of the operational amplifier(s) peripheral: More...
| HAL_StatusTypeDef | HAL_OPAMPEx_Unlock (OPAMP_HandleTypeDef *hopamp) |
| Unlock the selected OPAMP configuration. | |
| HAL_StatusTypeDef | HAL_OPAMPEx_SelfCalibrateAll (OPAMP_HandleTypeDef *hopamp1, OPAMP_HandleTypeDef *hopamp2) |
| Run the self calibration of 2 OPAMPs in parallel. | |
* @attention
* Copyright (c) 2017 STMicroelectronics.
* All rights reserved.
* This software is licensed under terms that can be found in the LICENSE file
* in the root directory of this software component.
* If no LICENSE file comes with this software, it is provided AS-IS.
/* Includes ------------------------------------------------------------------*/
#include "stm32h7xx_hal.h"
/** @addtogroup STM32H7xx_HAL_Driver
/** @defgroup OPAMPEx OPAMPEx
* @ingroup RTEMSBSPsARMSTM32H7
* @brief OPAMP Extended HAL module driver
#ifdef HAL_OPAMP_MODULE_ENABLED
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Exported functions --------------------------------------------------------*/
/** @defgroup OPAMPEx_Exported_Functions OPAMP Extended Exported Functions
/** @defgroup OPAMPEx_Exported_Functions_Group1 Extended Input and Output operation functions
* @brief Extended operation functions
@verbatim
##### Extended IO operation functions #####
(+) OPAMP Self calibration.
