RTEMS 6.3
stm32h7xx_hal_mdios.h
1
18
19/* Define to prevent recursive inclusion -------------------------------------*/
20#ifndef STM32H7xx_HAL_MDIOS_H
21#define STM32H7xx_HAL_MDIOS_H
22
23#ifdef __cplusplus
24 extern "C" {
25#endif
26
27
28/* Includes ------------------------------------------------------------------*/
29#include "stm32h7xx_hal_def.h"
30
31#if defined (MDIOS)
32
36
40
41/* Exported types ------------------------------------------------------------*/
46
51
52typedef enum
53{
54 HAL_MDIOS_STATE_RESET = 0x00U,
55 HAL_MDIOS_STATE_READY = 0x01U,
56 HAL_MDIOS_STATE_BUSY = 0x02U,
57 HAL_MDIOS_STATE_ERROR = 0x04U
58}HAL_MDIOS_StateTypeDef;
59
63
68
69typedef struct
70{
71 uint32_t PortAddress;
73 uint32_t PreambleCheck;
75}MDIOS_InitTypeDef;
76
80
85
86#if (USE_HAL_MDIOS_REGISTER_CALLBACKS == 1)
87typedef struct __MDIOS_HandleTypeDef
88#else
89typedef struct
90#endif
91{
92 MDIOS_TypeDef *Instance;
93
94 MDIOS_InitTypeDef Init;
95
96 __IO HAL_MDIOS_StateTypeDef State;
98
99 __IO uint32_t ErrorCode;
101
102 HAL_LockTypeDef Lock;
103
104#if (USE_HAL_MDIOS_REGISTER_CALLBACKS == 1)
105
106 void (* WriteCpltCallback) ( struct __MDIOS_HandleTypeDef * hmdios);
107 void (* ReadCpltCallback) ( struct __MDIOS_HandleTypeDef * hmdios);
108 void (* ErrorCallback) ( struct __MDIOS_HandleTypeDef * hmdios);
109 void (* WakeUpCallback) ( struct __MDIOS_HandleTypeDef * hmdios);
110
111 void (* MspInitCallback) ( struct __MDIOS_HandleTypeDef * hmdios);
112 void (* MspDeInitCallback) ( struct __MDIOS_HandleTypeDef * hmdios);
113
114#endif /* USE_HAL_MDIOS_REGISTER_CALLBACKS */
115}MDIOS_HandleTypeDef;
116
120
121#if (USE_HAL_MDIOS_REGISTER_CALLBACKS == 1)
125typedef enum
126{
127 HAL_MDIOS_MSPINIT_CB_ID = 0x00U,
128 HAL_MDIOS_MSPDEINIT_CB_ID = 0x01U,
129
130 HAL_MDIOS_WRITE_COMPLETE_CB_ID = 0x02U,
131 HAL_MDIOS_READ_COMPLETE_CB_ID = 0x03U,
132 HAL_MDIOS_ERROR_CB_ID = 0x04U,
133 HAL_MDIOS_WAKEUP_CB_ID = 0x05U
134}HAL_MDIOS_CallbackIDTypeDef;
135
139typedef void (*pMDIOS_CallbackTypeDef)(MDIOS_HandleTypeDef * hmdios);
140
141#endif /* USE_HAL_MDIOS_REGISTER_CALLBACKS */
142
146
147/* Exported constants --------------------------------------------------------*/
152
157#define MDIOS_PREAMBLE_CHECK_ENABLE ((uint32_t)0x00000000U)
158#define MDIOS_PREAMBLE_CHECK_DISABLE MDIOS_CR_DPC
162
167#define MDIOS_REG0 ((uint32_t)0x00000000U)
168#define MDIOS_REG1 ((uint32_t)0x00000001U)
169#define MDIOS_REG2 ((uint32_t)0x00000002U)
170#define MDIOS_REG3 ((uint32_t)0x00000003U)
171#define MDIOS_REG4 ((uint32_t)0x00000004U)
172#define MDIOS_REG5 ((uint32_t)0x00000005U)
173#define MDIOS_REG6 ((uint32_t)0x00000006U)
174#define MDIOS_REG7 ((uint32_t)0x00000007U)
175#define MDIOS_REG8 ((uint32_t)0x00000008U)
176#define MDIOS_REG9 ((uint32_t)0x00000009U)
177#define MDIOS_REG10 ((uint32_t)0x0000000AU)
178#define MDIOS_REG11 ((uint32_t)0x0000000BU)
179#define MDIOS_REG12 ((uint32_t)0x0000000CU)
180#define MDIOS_REG13 ((uint32_t)0x0000000DU)
181#define MDIOS_REG14 ((uint32_t)0x0000000EU)
182#define MDIOS_REG15 ((uint32_t)0x0000000FU)
183#define MDIOS_REG16 ((uint32_t)0x00000010U)
184#define MDIOS_REG17 ((uint32_t)0x00000011U)
185#define MDIOS_REG18 ((uint32_t)0x00000012U)
186#define MDIOS_REG19 ((uint32_t)0x00000013U)
187#define MDIOS_REG20 ((uint32_t)0x00000014U)
188#define MDIOS_REG21 ((uint32_t)0x00000015U)
189#define MDIOS_REG22 ((uint32_t)0x00000016U)
190#define MDIOS_REG23 ((uint32_t)0x00000017U)
191#define MDIOS_REG24 ((uint32_t)0x00000018U)
192#define MDIOS_REG25 ((uint32_t)0x00000019U)
193#define MDIOS_REG26 ((uint32_t)0x0000001AU)
194#define MDIOS_REG27 ((uint32_t)0x0000001BU)
195#define MDIOS_REG28 ((uint32_t)0x0000001CU)
196#define MDIOS_REG29 ((uint32_t)0x0000001DU)
197#define MDIOS_REG30 ((uint32_t)0x0000001EU)
198#define MDIOS_REG31 ((uint32_t)0x0000001FU)
202
207#define MDIOS_REG0_FLAG ((uint32_t)0x00000001U)
208#define MDIOS_REG1_FLAG ((uint32_t)0x00000002U)
209#define MDIOS_REG2_FLAG ((uint32_t)0x00000004U)
210#define MDIOS_REG3_FLAG ((uint32_t)0x00000008U)
211#define MDIOS_REG4_FLAG ((uint32_t)0x00000010U)
212#define MDIOS_REG5_FLAG ((uint32_t)0x00000020U)
213#define MDIOS_REG6_FLAG ((uint32_t)0x00000040U)
214#define MDIOS_REG7_FLAG ((uint32_t)0x00000080U)
215#define MDIOS_REG8_FLAG ((uint32_t)0x00000100U)
216#define MDIOS_REG9_FLAG ((uint32_t)0x00000200U)
217#define MDIOS_REG10_FLAG ((uint32_t)0x00000400U)
218#define MDIOS_REG11_FLAG ((uint32_t)0x00000800U)
219#define MDIOS_REG12_FLAG ((uint32_t)0x00001000U)
220#define MDIOS_REG13_FLAG ((uint32_t)0x00002000U)
221#define MDIOS_REG14_FLAG ((uint32_t)0x00004000U)
222#define MDIOS_REG15_FLAG ((uint32_t)0x00008000U)
223#define MDIOS_REG16_FLAG ((uint32_t)0x00010000U)
224#define MDIOS_REG17_FLAG ((uint32_t)0x00020000U)
225#define MDIOS_REG18_FLAG ((uint32_t)0x00040000U)
226#define MDIOS_REG19_FLAG ((uint32_t)0x00080000U)
227#define MDIOS_REG20_FLAG ((uint32_t)0x00100000U)
228#define MDIOS_REG21_FLAG ((uint32_t)0x00200000U)
229#define MDIOS_REG22_FLAG ((uint32_t)0x00400000U)
230#define MDIOS_REG23_FLAG ((uint32_t)0x00800000U)
231#define MDIOS_REG24_FLAG ((uint32_t)0x01000000U)
232#define MDIOS_REG25_FLAG ((uint32_t)0x02000000U)
233#define MDIOS_REG26_FLAG ((uint32_t)0x04000000U)
234#define MDIOS_REG27_FLAG ((uint32_t)0x08000000U)
235#define MDIOS_REG28_FLAG ((uint32_t)0x10000000U)
236#define MDIOS_REG29_FLAG ((uint32_t)0x20000000U)
237#define MDIOS_REG30_FLAG ((uint32_t)0x40000000U)
238#define MDIOS_REG31_FLAG ((uint32_t)0x80000000U)
239#define MDIOS_ALLREG_FLAG ((uint32_t)0xFFFFFFFFU)
243
248#define MDIOS_IT_WRITE MDIOS_CR_WRIE
249#define MDIOS_IT_READ MDIOS_CR_RDIE
250#define MDIOS_IT_ERROR MDIOS_CR_EIE
254
259#define MDIOS_TURNAROUND_ERROR_FLAG MDIOS_SR_TERF
260#define MDIOS_START_ERROR_FLAG MDIOS_SR_SERF
261#define MDIOS_PREAMBLE_ERROR_FLAG MDIOS_SR_PERF
265
270#define HAL_MDIOS_ERROR_NONE ((uint32_t)0x00000000U)
271#define HAL_MDIOS_ERROR_PARAM ((uint32_t)0x00000001U)
272#define HAL_MDIOS_ERROR_BUSY ((uint32_t)0x00000002U)
273#define HAL_MDIOS_ERROR_TIMEOUT ((uint32_t)0x00000004U)
274#define HAL_MDIOS_ERROR_DATA ((uint32_t)0x00000010U)
275#if (USE_HAL_MDIOS_REGISTER_CALLBACKS == 1)
276#define HAL_MDIOS_ERROR_INVALID_CALLBACK ((uint32_t)0x00000020U)
277#endif /* USE_HAL_MDIOS_REGISTER_CALLBACKS */
281
286#define MDIOS_WAKEUP_EXTI_LINE ((uint32_t)0x00000400) /* !< 42 - 32 = 10 */
290
294/* Exported macros -----------------------------------------------------------*/
299
304#if (USE_HAL_MDIOS_REGISTER_CALLBACKS == 1)
305#define __HAL_MDIOS_RESET_HANDLE_STATE(__HANDLE__) do{ \
306 (__HANDLE__)->State = HAL_MDIOS_STATE_RESET; \
307 (__HANDLE__)->MspInitCallback = NULL; \
308 (__HANDLE__)->MspDeInitCallback = NULL; \
309 } while(0)
310#else
311#define __HAL_MDIOS_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_MDIOS_STATE_RESET)
312#endif /*USE_HAL_MDIOS_REGISTER_CALLBACKS */
313
319#define __HAL_MDIOS_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR |= MDIOS_CR_EN)
320#define __HAL_MDIOS_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR &= ~MDIOS_CR_EN)
321
322
333#define __HAL_MDIOS_ENABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR |= (__INTERRUPT__))
334
345#define __HAL_MDIOS_DISABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR &= ~(__INTERRUPT__))
346
352#define __HAL_MDIOS_GET_WRITE_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->WRFR & (__FLAG__))
353
359#define __HAL_MDIOS_GET_READ_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->RDFR & (__FLAG__))
360
370#define __HAL_MDIOS_GET_ERROR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->SR & (__FLAG__))
371
381#define __HAL_MDIOS_CLEAR_ERROR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->CLRFR) |= (__FLAG__)
382
393#define __HAL_MDIOS_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR & (__INTERRUPT__))
394
402#define __HAL_MDIOS_WAKEUP_EXTI_ENABLE_IT(__EXTI_LINE__) (EXTI->IMR2 |= (__EXTI_LINE__))
403
404#if defined(DUAL_CORE)
412#define __HAL_MDIOS_WAKEUP_EXTID2_ENABLE_IT(__EXTI_LINE__) (EXTI->C2IMR2 |= (__EXTI_LINE__))
413
414#endif
422#define __HAL_MDIOS_WAKEUP_EXTI_GET_FLAG(__EXTI_LINE__) (EXTI->PR2 & (__EXTI_LINE__))
423
424#if defined(DUAL_CORE)
432#define __HAL_MDIOS_WAKEUP_EXTID2_GET_FLAG(__EXTI_LINE__) (EXTI->C2PR2 & (__EXTI_LINE__))
433#endif
441#define __HAL_MDIOS_WAKEUP_EXTI_CLEAR_FLAG(__EXTI_LINE__) (EXTI->PR2 = (__EXTI_LINE__))
442
443#if defined(DUAL_CORE)
451#define __HAL_MDIOS_WAKEUP_EXTID2_CLEAR_FLAG(__EXTI_LINE__) (EXTI->C2PR2 = (__EXTI_LINE__))
452
453#endif
461#define __HAL_MDIOS_WAKEUP_EXTI_ENABLE_RISING_EDGE(__EXTI_LINE__) (EXTI->FTSR2 &= ~(__EXTI_LINE__)); \
462 (EXTI->RTSR2 |= (__EXTI_LINE__))
463
471#define __HAL_MDIOS_WAKEUP_EXTI_ENABLE_FALLING_EDGE(__EXTI_LINE__) (EXTI->RTSR2 &= ~(__EXTI_LINE__));\
472 (EXTI->FTSR2 |= (__EXTI_LINE__))
473
481#define __HAL_MDIOS_WAKEUP_EXTI_ENABLE_RISING_FALLING_EDGE(__EXTI_LINE__) (EXTI->RTSR2 |= (__EXTI_LINE__));\
482 (EXTI->FTSR2 |= (__EXTI_LINE__))
483
491#define __HAL_MDIOS_WAKEUP_EXTI_GENERATE_SWIT(__EXTI_LINE__) (EXTI->SWIER2 |= (__EXTI_LINE__))
492
496
497/* Exported functions --------------------------------------------------------*/
502
506HAL_StatusTypeDef HAL_MDIOS_Init(MDIOS_HandleTypeDef *hmdios);
507HAL_StatusTypeDef HAL_MDIOS_DeInit(MDIOS_HandleTypeDef *hmdios);
508void HAL_MDIOS_MspInit(MDIOS_HandleTypeDef *hmdios);
509void HAL_MDIOS_MspDeInit(MDIOS_HandleTypeDef *hmdios);
510
511/* Callbacks Register/UnRegister functions ***********************************/
512#if (USE_HAL_MDIOS_REGISTER_CALLBACKS == 1)
513HAL_StatusTypeDef HAL_MDIOS_RegisterCallback(MDIOS_HandleTypeDef *hmdios, HAL_MDIOS_CallbackIDTypeDef CallbackID, pMDIOS_CallbackTypeDef pCallback);
514HAL_StatusTypeDef HAL_MDIOS_UnRegisterCallback(MDIOS_HandleTypeDef *hmdios, HAL_MDIOS_CallbackIDTypeDef CallbackID);
515#endif /* USE_HAL_MDIOS_REGISTER_CALLBACKS */
519
523HAL_StatusTypeDef HAL_MDIOS_WriteReg(MDIOS_HandleTypeDef *hmdios, uint32_t RegNum, uint16_t Data);
524HAL_StatusTypeDef HAL_MDIOS_ReadReg(MDIOS_HandleTypeDef *hmdios, uint32_t RegNum, uint16_t *pData);
525
526uint32_t HAL_MDIOS_GetWrittenRegAddress(MDIOS_HandleTypeDef *hmdios);
527uint32_t HAL_MDIOS_GetReadRegAddress(MDIOS_HandleTypeDef *hmdios);
528HAL_StatusTypeDef HAL_MDIOS_ClearWriteRegAddress(MDIOS_HandleTypeDef *hmdios, uint32_t RegNum);
529HAL_StatusTypeDef HAL_MDIOS_ClearReadRegAddress(MDIOS_HandleTypeDef *hmdios, uint32_t RegNum);
530
531HAL_StatusTypeDef HAL_MDIOS_EnableEvents(MDIOS_HandleTypeDef *hmdios);
532void HAL_MDIOS_IRQHandler(MDIOS_HandleTypeDef *hmdios);
533void HAL_MDIOS_WriteCpltCallback(MDIOS_HandleTypeDef *hmdios);
534void HAL_MDIOS_ReadCpltCallback(MDIOS_HandleTypeDef *hmdios);
535void HAL_MDIOS_ErrorCallback(MDIOS_HandleTypeDef *hmdios);
536void HAL_MDIOS_WakeUpCallback(MDIOS_HandleTypeDef *hmdios);
540
544uint32_t HAL_MDIOS_GetError(MDIOS_HandleTypeDef *hmdios);
545HAL_MDIOS_StateTypeDef HAL_MDIOS_GetState(MDIOS_HandleTypeDef *hmdios);
549
553
554/* Private types -------------------------------------------------------------*/
559
563
564/* Private variables ---------------------------------------------------------*/
569
573
574/* Private constants ---------------------------------------------------------*/
579
583
584/* Private macros ------------------------------------------------------------*/
589
590#define IS_MDIOS_PORTADDRESS(__ADDR__) ((__ADDR__) < 32U)
591
592#define IS_MDIOS_REGISTER(__REGISTER__) ((__REGISTER__) < 32U)
593
594#define IS_MDIOS_PREAMBLECHECK(__PREAMBLECHECK__) (((__PREAMBLECHECK__) == MDIOS_PREAMBLE_CHECK_ENABLE) || \
595 ((__PREAMBLECHECK__) == MDIOS_PREAMBLE_CHECK_DISABLE))
596
600
601/* Private functions ---------------------------------------------------------*/
606
610
611
615
619
620#endif /* MDIOS */
621
622#ifdef __cplusplus
623}
624#endif
625
626#endif /* STM32H7xx_HAL_MDIOS_H */
627
#define __IO
Definition core_cm4.h:239
This file contains HAL common defines, enumeration, macros and structures definitions.
HAL_StatusTypeDef
HAL Status structures definition.
Definition stm32h7xx_hal_def.h:47
HAL_LockTypeDef
HAL Lock structures definition.
Definition stm32h7xx_hal_def.h:58
