RTEMS 6.3
stm32h7xx_hal_hsem.h File Reference
Header file of HSEM HAL module. More...
#define __HAL_HSEM_SEMID_TO_MASK(__SEMID__)
 SemID to mask helper Macro.
#define __HAL_HSEM_ENABLE_IT(__SEM_MASK__)
 Enables the specified HSEM interrupts.
#define __HAL_HSEM_DISABLE_IT(__SEM_MASK__)
 Disables the specified HSEM interrupts.
#define __HAL_HSEM_GET_IT(__SEM_MASK__)
 Checks whether interrupt has occurred or not for semaphores specified by a mask.
#define __HAL_HSEM_GET_FLAG(__SEM_MASK__)
 Get the semaphores release status flags.
#define __HAL_HSEM_CLEAR_FLAG(__SEM_MASK__)
 Clears the HSEM Interrupt flags.
#define IS_HSEM_SEMID(__SEMID__)
#define IS_HSEM_PROCESSID(__PROCESSID__)
#define IS_HSEM_KEY(__KEY__)
#define IS_HSEM_COREID(__COREID__)
HAL_StatusTypeDef HAL_HSEM_Take (uint32_t SemID, uint32_t ProcessID)
HAL_StatusTypeDef HAL_HSEM_FastTake (uint32_t SemID)
void HAL_HSEM_Release (uint32_t SemID, uint32_t ProcessID)
void HAL_HSEM_ReleaseAll (uint32_t Key, uint32_t CoreID)
uint32_t HAL_HSEM_IsSemTaken (uint32_t SemID)
void HAL_HSEM_SetClearKey (uint32_t Key)
uint32_t HAL_HSEM_GetClearKey (void)
void HAL_HSEM_ActivateNotification (uint32_t SemMask)
void HAL_HSEM_DeactivateNotification (uint32_t SemMask)
void HAL_HSEM_FreeCallback (uint32_t SemMask)
void HAL_HSEM_IRQHandler (void)
Author
MCD Application Team
Attention
