RTEMS 6.3
stm32h7xx_hal_gpio_ex.h File Reference
Header file of GPIO HAL Extension module. More...
#define GPIO_AF0_RTC_50Hz   ((uint8_t)0x00)
 AF 0 selection.
#define GPIO_AF0_MCO   ((uint8_t)0x00)
#define GPIO_AF0_SWJ   ((uint8_t)0x00)
#define GPIO_AF0_LCDBIAS   ((uint8_t)0x00)
#define GPIO_AF0_TRACE   ((uint8_t)0x00)
#define GPIO_AF1_TIM1   ((uint8_t)0x01)
 AF 1 selection.
#define GPIO_AF1_TIM2   ((uint8_t)0x01)
#define GPIO_AF1_TIM16   ((uint8_t)0x01)
#define GPIO_AF1_TIM17   ((uint8_t)0x01)
#define GPIO_AF1_LPTIM1   ((uint8_t)0x01)
#define GPIO_AF1_FMC   ((uint8_t)0x01)
#define GPIO_AF2_TIM3   ((uint8_t)0x02)
 AF 2 selection.
#define GPIO_AF2_TIM4   ((uint8_t)0x02)
#define GPIO_AF2_TIM5   ((uint8_t)0x02)
#define GPIO_AF2_TIM12   ((uint8_t)0x02)
#define GPIO_AF2_SAI1   ((uint8_t)0x02)
#define GPIO_AF2_TIM15   ((uint8_t)0x02)
#define GPIO_AF3_TIM8   ((uint8_t)0x03)
 AF 3 selection.
#define GPIO_AF3_LPTIM2   ((uint8_t)0x03)
#define GPIO_AF3_DFSDM1   ((uint8_t)0x03)
#define GPIO_AF3_LPTIM3   ((uint8_t)0x03)
#define GPIO_AF3_LPTIM4   ((uint8_t)0x03)
#define GPIO_AF3_LPTIM5   ((uint8_t)0x03)
#define GPIO_AF3_LPUART   ((uint8_t)0x03)
#define GPIO_AF3_LTDC   ((uint8_t)0x03)
#define GPIO_AF4_I2C1   ((uint8_t)0x04)
 AF 4 selection.
#define GPIO_AF4_I2C2   ((uint8_t)0x04)
#define GPIO_AF4_I2C3   ((uint8_t)0x04)
#define GPIO_AF4_I2C4   ((uint8_t)0x04)
#define GPIO_AF4_TIM15   ((uint8_t)0x04)
#define GPIO_AF4_CEC   ((uint8_t)0x04)
#define GPIO_AF4_LPTIM2   ((uint8_t)0x04)
#define GPIO_AF4_USART1   ((uint8_t)0x04)
#define GPIO_AF4_DFSDM1   ((uint8_t)0x04)
#define GPIO_AF4_DCMI   ((uint8_t)0x04)
#define GPIO_AF5_SPI1   ((uint8_t)0x05)
 AF 5 selection.
#define GPIO_AF5_SPI2   ((uint8_t)0x05)
#define GPIO_AF5_SPI3   ((uint8_t)0x05)
#define GPIO_AF5_SPI4   ((uint8_t)0x05)
#define GPIO_AF5_SPI5   ((uint8_t)0x05)
#define GPIO_AF5_SPI6   ((uint8_t)0x05)
#define GPIO_AF5_CEC   ((uint8_t)0x05)
#define GPIO_AF6_SPI2   ((uint8_t)0x06)
 AF 6 selection.
#define GPIO_AF6_SPI3   ((uint8_t)0x06)
#define GPIO_AF6_SAI1   ((uint8_t)0x06)
#define GPIO_AF6_I2C4   ((uint8_t)0x06)
#define GPIO_AF6_DFSDM1   ((uint8_t)0x06)
#define GPIO_AF6_UART4   ((uint8_t)0x06)
#define GPIO_AF7_SPI2   ((uint8_t)0x07)
 AF 7 selection.
#define GPIO_AF7_SPI3   ((uint8_t)0x07)
#define GPIO_AF7_SPI6   ((uint8_t)0x07)
#define GPIO_AF7_USART1   ((uint8_t)0x07)
#define GPIO_AF7_USART2   ((uint8_t)0x07)
#define GPIO_AF7_USART3   ((uint8_t)0x07)
#define GPIO_AF7_USART6   ((uint8_t)0x07)
#define GPIO_AF7_UART7   ((uint8_t)0x07)
#define GPIO_AF7_SDMMC1   ((uint8_t)0x07)
#define GPIO_AF8_SPI6   ((uint8_t)0x08)
 AF 8 selection.
#define GPIO_AF8_UART4   ((uint8_t)0x08)
#define GPIO_AF8_UART5   ((uint8_t)0x08)
#define GPIO_AF8_UART8   ((uint8_t)0x08)
#define GPIO_AF8_SPDIF   ((uint8_t)0x08)
#define GPIO_AF8_LPUART   ((uint8_t)0x08)
#define GPIO_AF8_SDMMC1   ((uint8_t)0x08)
#define GPIO_AF9_FDCAN1   ((uint8_t)0x09)
 AF 9 selection.
#define GPIO_AF9_FDCAN2   ((uint8_t)0x09)
#define GPIO_AF9_TIM13   ((uint8_t)0x09)
#define GPIO_AF9_TIM14   ((uint8_t)0x09)
#define GPIO_AF9_SDMMC2   ((uint8_t)0x09)
#define GPIO_AF9_LTDC   ((uint8_t)0x09)
#define GPIO_AF9_SPDIF   ((uint8_t)0x09)
#define GPIO_AF9_FMC   ((uint8_t)0x09)
#define GPIO_AF10_SDMMC2   ((uint8_t)0x0A)
 AF 10 selection.
#define GPIO_AF10_COMP1   ((uint8_t)0x0A)
#define GPIO_AF10_COMP2   ((uint8_t)0x0A)
#define GPIO_AF10_CRS_SYNC   ((uint8_t)0x0A)
#define GPIO_AF10_OTG1_FS   ((uint8_t)0x0A)
#define GPIO_AF10_OTG1_HS   ((uint8_t)0x0A)
#define GPIO_AF10_TIM8   ((uint8_t)0x0A)
#define GPIO_AF10_FMC   ((uint8_t)0x0A)
#define GPIO_AF11_SWP   ((uint8_t)0x0B)
 AF 11 selection.
#define GPIO_AF11_MDIOS   ((uint8_t)0x0B)
#define GPIO_AF11_UART7   ((uint8_t)0x0B)
#define GPIO_AF11_SDMMC2   ((uint8_t)0x0B)
#define GPIO_AF11_DFSDM1   ((uint8_t)0x0B)
#define GPIO_AF11_COMP1   ((uint8_t)0x0B)
#define GPIO_AF11_COMP2   ((uint8_t)0x0B)
#define GPIO_AF11_TIM1   ((uint8_t)0x0B)
#define GPIO_AF11_TIM8   ((uint8_t)0x0B)
#define GPIO_AF11_I2C4   ((uint8_t)0x0B)
#define GPIO_AF12_FMC   ((uint8_t)0x0C)
 AF 12 selection.
#define GPIO_AF12_SDMMC1   ((uint8_t)0x0C)
#define GPIO_AF12_MDIOS   ((uint8_t)0x0C)
#define GPIO_AF12_COMP1   ((uint8_t)0x0C)
#define GPIO_AF12_COMP2   ((uint8_t)0x0C)
#define GPIO_AF12_TIM1   ((uint8_t)0x0C)
#define GPIO_AF12_TIM8   ((uint8_t)0x0C)
#define GPIO_AF13_DCMI   ((uint8_t)0x0D)
 AF 13 selection.
#define GPIO_AF13_COMP1   ((uint8_t)0x0D)
#define GPIO_AF13_COMP2   ((uint8_t)0x0D)
#define GPIO_AF13_TIM1   ((uint8_t)0x0D)
#define GPIO_AF14_LTDC   ((uint8_t)0x0E)
 AF 14 selection.
#define GPIO_AF14_UART5   ((uint8_t)0x0E)
#define GPIO_AF15_EVENTOUT   ((uint8_t)0x0F)
 AF 15 selection.
#define IS_GPIO_AF(AF)
#define GPIOA_PIN_AVAILABLE   GPIO_PIN_All
 GPIO pin available on the platform.
#define GPIOB_PIN_AVAILABLE   GPIO_PIN_All
#define GPIOC_PIN_AVAILABLE   GPIO_PIN_All
#define GPIOD_PIN_AVAILABLE   GPIO_PIN_All
#define GPIOE_PIN_AVAILABLE   GPIO_PIN_All
#define GPIOF_PIN_AVAILABLE   GPIO_PIN_All
#define GPIOG_PIN_AVAILABLE   GPIO_PIN_All
#define GPIOJ_PIN_AVAILABLE   (GPIO_PIN_8 | GPIO_PIN_9 | GPIO_PIN_10 | GPIO_PIN_11 )
#define GPIOH_PIN_AVAILABLE   GPIO_PIN_All
#define GPIOK_PIN_AVAILABLE   (GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 )
#define GPIO_GET_INDEX(__GPIOx__)
Author
MCD Application Team
Attention
