RTEMS 6.3
stm32h7xx_hal_dsi.c File Reference
DSI HAL module driver. This file provides firmware functions to manage the following functionalities of the DSI peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • IO operation functions
  • Peripheral Control functions
  • Peripheral State and Errors functions
Attention
                      ##### How to use this driver #####
  The DSI HAL driver can be used as follows:
  (#) Declare a DSI_HandleTypeDef handle structure, for example: DSI_HandleTypeDef  hdsi;
  (#) Initialize the DSI low level resources by implementing the HAL_DSI_MspInit() API:
      (##) Enable the DSI interface clock
      (##) NVIC configuration if you need to use interrupt process
          (+++) Configure the DSI interrupt priority
          (+++) Enable the NVIC DSI IRQ Channel
  (#) Initialize the DSI Host peripheral, the required PLL parameters, number of lances and
      TX Escape clock divider by calling the HAL_DSI_Init() API which calls HAL_DSI_MspInit().
  *** Configuration ***
  (#) Use HAL_DSI_ConfigAdaptedCommandMode() function to configure the DSI host in adapted
      command mode.
  (#) When operating in video mode , use HAL_DSI_ConfigVideoMode() to configure the DSI host.
  (#) Function HAL_DSI_ConfigCommand() is used to configure the DSI commands behavior in low power mode.
  (#) To configure the DSI PHY timings parameters, use function HAL_DSI_ConfigPhyTimer().
  (#) The DSI Host can be started/stopped using respectively functions HAL_DSI_Start() and HAL_DSI_Stop().
      Functions HAL_DSI_ShortWrite(), HAL_DSI_LongWrite() and HAL_DSI_Read() allows respectively
      to write DSI short packets, long packets and to read DSI packets.
  (#) The DSI Host Offers two Low power modes :
      (++) Low Power Mode on data lanes only: Only DSI data lanes are shut down.
          It is possible to enter/exit from this mode using respectively functions HAL_DSI_EnterULPMData()
          and HAL_DSI_ExitULPMData()
      (++) Low Power Mode on data and clock lanes : All DSI lanes are shut down including data and clock lanes.
          It is possible to enter/exit from this mode using respectively functions HAL_DSI_EnterULPM()
          and HAL_DSI_ExitULPM()
  (#) To control DSI state you can use the following function: HAL_DSI_GetState()
  *** Error management ***
  (#) User can select the DSI errors to be reported/monitored using function HAL_DSI_ConfigErrorMonitor()
      When an error occurs, the callback HAL_DSI_ErrorCallback() is asserted and then user can retrieve
      the error code by calling function HAL_DSI_GetError()
  *** DSI HAL driver macros list ***
     Below the list of most used macros in DSI HAL driver.
    (+) __HAL_DSI_ENABLE: Enable the DSI Host.
    (+) __HAL_DSI_DISABLE: Disable the DSI Host.
    (+) __HAL_DSI_WRAPPER_ENABLE: Enables the DSI wrapper.
    (+) __HAL_DSI_WRAPPER_DISABLE: Disable the DSI wrapper.
    (+) __HAL_DSI_PLL_ENABLE: Enables the DSI PLL.
    (+) __HAL_DSI_PLL_DISABLE: Disables the DSI PLL.
    (+) __HAL_DSI_REG_ENABLE: Enables the DSI regulator.
    (+) __HAL_DSI_REG_DISABLE: Disables the DSI regulator.
    (+) __HAL_DSI_GET_FLAG: Get the DSI pending flags.
    (+) __HAL_DSI_CLEAR_FLAG: Clears the DSI pending flags.
    (+) __HAL_DSI_ENABLE_IT: Enables the specified DSI interrupts.
    (+) __HAL_DSI_DISABLE_IT: Disables the specified DSI interrupts.
    (+) __HAL_DSI_GET_IT_SOURCE: Checks whether the specified DSI interrupt source is enabled or not.
    (@) You can refer to the DSI HAL driver header file for more useful macros
  *** Callback registration ***
  The compilation define  USE_HAL_DSI_REGISTER_CALLBACKS when set to 1
  allows the user to configure dynamically the driver callbacks.
  Use Function HAL_DSI_RegisterCallback() to register a callback.
  Function HAL_DSI_RegisterCallback() allows to register following callbacks:
    (+) TearingEffectCallback : DSI Tearing Effect Callback.
    (+) EndOfRefreshCallback  : DSI End Of Refresh Callback.
    (+) ErrorCallback         : DSI Error Callback
    (+) MspInitCallback       : DSI MspInit.
    (+) MspDeInitCallback     : DSI MspDeInit.
  This function takes as parameters the HAL peripheral handle, the callback ID
  and a pointer to the user callback function.
  Use function HAL_DSI_UnRegisterCallback() to reset a callback to the default
  weak function.
  HAL_DSI_UnRegisterCallback takes as parameters the HAL peripheral handle,
  and the callback ID.
  This function allows to reset following callbacks:
  By default, after the HAL_DSI_Init and when the state is HAL_DSI_STATE_RESET
  all callbacks are set to the corresponding weak functions:
  examples HAL_DSI_TearingEffectCallback(), HAL_DSI_EndOfRefreshCallback().
  Exception done for MspInit and MspDeInit functions that are respectively
  reset to the legacy weak (overridden) functions in the HAL_DSI_Init()
  and HAL_DSI_DeInit() only when these callbacks are null (not registered beforehand).
  If not, MspInit or MspDeInit are not null, the HAL_DSI_Init() and HAL_DSI_DeInit()
  keep and use the user MspInit/MspDeInit callbacks (registered beforehand).
  Callbacks can be registered/unregistered in HAL_DSI_STATE_READY state only.
  Exception done MspInit/MspDeInit that can be registered/unregistered
  in HAL_DSI_STATE_READY or HAL_DSI_STATE_RESET state,
  thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
  In that case first register the MspInit/MspDeInit user callbacks
  using HAL_DSI_RegisterCallback() before calling HAL_DSI_DeInit()
  or HAL_DSI_Init() function.
  When The compilation define USE_HAL_DSI_REGISTER_CALLBACKS is set to 0 or
  not defined, the callback registration feature is not available and all callbacks
  are set to the corresponding weak functions.
