RTEMS 6.3
stm32h7xx_hal_dma.h File Reference
Header file of DMA HAL module. More...
struct  DMA_InitTypeDef
 DMA Configuration Structure definition. More...
struct  __DMA_HandleTypeDef
 DMA handle Structure definition. More...
#define HAL_DMA_ERROR_NONE   (0x00000000U)
#define HAL_DMA_ERROR_TE   (0x00000001U)
#define HAL_DMA_ERROR_FE   (0x00000002U)
#define HAL_DMA_ERROR_DME   (0x00000004U)
#define HAL_DMA_ERROR_TIMEOUT   (0x00000020U)
#define HAL_DMA_ERROR_PARAM   (0x00000040U)
#define HAL_DMA_ERROR_NO_XFER   (0x00000080U)
#define HAL_DMA_ERROR_NOT_SUPPORTED   (0x00000100U)
#define HAL_DMA_ERROR_SYNC   (0x00000200U)
#define HAL_DMA_ERROR_REQGEN   (0x00000400U)
#define HAL_DMA_ERROR_BUSY   (0x00000800U)
#define DMA_REQUEST_MEM2MEM   0U
#define DMA_REQUEST_GENERATOR0   1U
#define DMA_REQUEST_GENERATOR1   2U
#define DMA_REQUEST_GENERATOR2   3U
#define DMA_REQUEST_GENERATOR3   4U
#define DMA_REQUEST_GENERATOR4   5U
#define DMA_REQUEST_GENERATOR5   6U
#define DMA_REQUEST_GENERATOR6   7U
#define DMA_REQUEST_GENERATOR7   8U
#define DMA_REQUEST_ADC1   9U
#define DMA_REQUEST_ADC2   10U
#define DMA_REQUEST_TIM1_CH1   11U
#define DMA_REQUEST_TIM1_CH2   12U
#define DMA_REQUEST_TIM1_CH3   13U
#define DMA_REQUEST_TIM1_CH4   14U
#define DMA_REQUEST_TIM1_UP   15U
#define DMA_REQUEST_TIM1_TRIG   16U
#define DMA_REQUEST_TIM1_COM   17U
#define DMA_REQUEST_TIM2_CH1   18U
#define DMA_REQUEST_TIM2_CH2   19U
#define DMA_REQUEST_TIM2_CH3   20U
#define DMA_REQUEST_TIM2_CH4   21U
#define DMA_REQUEST_TIM2_UP   22U
#define DMA_REQUEST_TIM3_CH1   23U
#define DMA_REQUEST_TIM3_CH2   24U
#define DMA_REQUEST_TIM3_CH3   25U
#define DMA_REQUEST_TIM3_CH4   26U
#define DMA_REQUEST_TIM3_UP   27U
#define DMA_REQUEST_TIM3_TRIG   28U
#define DMA_REQUEST_TIM4_CH1   29U
#define DMA_REQUEST_TIM4_CH2   30U
#define DMA_REQUEST_TIM4_CH3   31U
#define DMA_REQUEST_TIM4_UP   32U
#define DMA_REQUEST_I2C1_RX   33U
#define DMA_REQUEST_I2C1_TX   34U
#define DMA_REQUEST_I2C2_RX   35U
#define DMA_REQUEST_I2C2_TX   36U
#define DMA_REQUEST_SPI1_RX   37U
#define DMA_REQUEST_SPI1_TX   38U
#define DMA_REQUEST_SPI2_RX   39U
#define DMA_REQUEST_SPI2_TX   40U
#define DMA_REQUEST_USART1_RX   41U
#define DMA_REQUEST_USART1_TX   42U
#define DMA_REQUEST_USART2_RX   43U
#define DMA_REQUEST_USART2_TX   44U
#define DMA_REQUEST_USART3_RX   45U
#define DMA_REQUEST_USART3_TX   46U
#define DMA_REQUEST_TIM8_CH1   47U
#define DMA_REQUEST_TIM8_CH2   48U
#define DMA_REQUEST_TIM8_CH3   49U
#define DMA_REQUEST_TIM8_CH4   50U
#define DMA_REQUEST_TIM8_UP   51U
#define DMA_REQUEST_TIM8_TRIG   52U
#define DMA_REQUEST_TIM8_COM   53U
#define DMA_REQUEST_TIM5_CH1   55U
#define DMA_REQUEST_TIM5_CH2   56U
#define DMA_REQUEST_TIM5_CH3   57U
#define DMA_REQUEST_TIM5_CH4   58U
#define DMA_REQUEST_TIM5_UP   59U
#define DMA_REQUEST_TIM5_TRIG   60U
#define DMA_REQUEST_SPI3_RX   61U
#define DMA_REQUEST_SPI3_TX   62U
#define DMA_REQUEST_UART4_RX   63U
#define DMA_REQUEST_UART4_TX   64U
#define DMA_REQUEST_UART5_RX   65U
#define DMA_REQUEST_UART5_TX   66U
#define DMA_REQUEST_DAC1_CH1   67U
#define DMA_REQUEST_DAC1_CH2   68U
#define DMA_REQUEST_TIM6_UP   69U
#define DMA_REQUEST_TIM7_UP   70U
#define DMA_REQUEST_USART6_RX   71U
#define DMA_REQUEST_USART6_TX   72U
#define DMA_REQUEST_I2C3_RX   73U
#define DMA_REQUEST_I2C3_TX   74U
#define DMA_REQUEST_DCMI   75U
#define DMA_REQUEST_CRYP_IN   76U
#define DMA_REQUEST_CRYP_OUT   77U
#define DMA_REQUEST_HASH_IN   78U
#define DMA_REQUEST_UART7_RX   79U
#define DMA_REQUEST_UART7_TX   80U
#define DMA_REQUEST_UART8_RX   81U
#define DMA_REQUEST_UART8_TX   82U
#define DMA_REQUEST_SPI4_RX   83U
#define DMA_REQUEST_SPI4_TX   84U
#define DMA_REQUEST_SPI5_RX   85U
#define DMA_REQUEST_SPI5_TX   86U
#define DMA_REQUEST_SAI1_A   87U
#define DMA_REQUEST_SAI1_B   88U
#define DMA_REQUEST_SWPMI_RX   91U
#define DMA_REQUEST_SWPMI_TX   92U
#define DMA_REQUEST_SPDIF_RX_DT   93U
#define DMA_REQUEST_SPDIF_RX_CS   94U
#define DMA_REQUEST_DFSDM1_FLT0   101U
#define DMA_REQUEST_DFSDM1_FLT1   102U
#define DMA_REQUEST_DFSDM1_FLT2   103U
#define DMA_REQUEST_DFSDM1_FLT3   104U
#define DMA_REQUEST_TIM15_CH1   105U
#define DMA_REQUEST_TIM15_UP   106U
#define DMA_REQUEST_TIM15_TRIG   107U
#define DMA_REQUEST_TIM15_COM   108U
#define DMA_REQUEST_TIM16_CH1   109U
#define DMA_REQUEST_TIM16_UP   110U
#define DMA_REQUEST_TIM17_CH1   111U
#define DMA_REQUEST_TIM17_UP   112U
#define BDMA_REQUEST_MEM2MEM   0U
#define BDMA_REQUEST_GENERATOR0   1U
#define BDMA_REQUEST_GENERATOR1   2U
#define BDMA_REQUEST_GENERATOR2   3U
#define BDMA_REQUEST_GENERATOR3   4U
#define BDMA_REQUEST_GENERATOR4   5U
#define BDMA_REQUEST_GENERATOR5   6U
#define BDMA_REQUEST_GENERATOR6   7U
#define BDMA_REQUEST_GENERATOR7   8U
#define BDMA_REQUEST_LPUART1_RX   9U
#define BDMA_REQUEST_LPUART1_TX   10U
#define BDMA_REQUEST_SPI6_RX   11U
#define BDMA_REQUEST_SPI6_TX   12U
#define BDMA_REQUEST_I2C4_RX   13U
#define BDMA_REQUEST_I2C4_TX   14U
#define DMA_PERIPH_TO_MEMORY   ((uint32_t)0x00000000U)
#define DMA_MEMORY_TO_PERIPH   ((uint32_t)DMA_SxCR_DIR_0)
#define DMA_MEMORY_TO_MEMORY   ((uint32_t)DMA_SxCR_DIR_1)
#define DMA_PINC_ENABLE   ((uint32_t)DMA_SxCR_PINC)
#define DMA_PINC_DISABLE   ((uint32_t)0x00000000U)
#define DMA_MINC_ENABLE   ((uint32_t)DMA_SxCR_MINC)
#define DMA_MINC_DISABLE   ((uint32_t)0x00000000U)
#define DMA_PDATAALIGN_BYTE   ((uint32_t)0x00000000U)
#define DMA_PDATAALIGN_HALFWORD   ((uint32_t)DMA_SxCR_PSIZE_0)
#define DMA_PDATAALIGN_WORD   ((uint32_t)DMA_SxCR_PSIZE_1)
#define DMA_MDATAALIGN_BYTE   ((uint32_t)0x00000000U)
#define DMA_MDATAALIGN_HALFWORD   ((uint32_t)DMA_SxCR_MSIZE_0)
#define DMA_MDATAALIGN_WORD   ((uint32_t)DMA_SxCR_MSIZE_1)
#define DMA_NORMAL   ((uint32_t)0x00000000U)
#define DMA_CIRCULAR   ((uint32_t)DMA_SxCR_CIRC)
#define DMA_PFCTRL   ((uint32_t)DMA_SxCR_PFCTRL)
#define DMA_DOUBLE_BUFFER_M0   ((uint32_t)DMA_SxCR_DBM)
#define DMA_DOUBLE_BUFFER_M1   ((uint32_t)(DMA_SxCR_DBM | DMA_SxCR_CT))
#define DMA_PRIORITY_LOW   ((uint32_t)0x00000000U)
#define DMA_PRIORITY_MEDIUM   ((uint32_t)DMA_SxCR_PL_0)
#define DMA_PRIORITY_HIGH   ((uint32_t)DMA_SxCR_PL_1)
#define DMA_PRIORITY_VERY_HIGH   ((uint32_t)DMA_SxCR_PL)
#define DMA_FIFOMODE_DISABLE   ((uint32_t)0x00000000U)
#define DMA_FIFOMODE_ENABLE   ((uint32_t)DMA_SxFCR_DMDIS)
#define DMA_FIFO_THRESHOLD_1QUARTERFULL   ((uint32_t)0x00000000U)
#define DMA_FIFO_THRESHOLD_HALFFULL   ((uint32_t)DMA_SxFCR_FTH_0)
#define DMA_FIFO_THRESHOLD_3QUARTERSFULL   ((uint32_t)DMA_SxFCR_FTH_1)
#define DMA_FIFO_THRESHOLD_FULL   ((uint32_t)DMA_SxFCR_FTH)
#define DMA_MBURST_SINGLE   ((uint32_t)0x00000000U)
#define DMA_MBURST_INC4   ((uint32_t)DMA_SxCR_MBURST_0)
#define DMA_MBURST_INC8   ((uint32_t)DMA_SxCR_MBURST_1)
#define DMA_MBURST_INC16   ((uint32_t)DMA_SxCR_MBURST)
#define DMA_PBURST_SINGLE   ((uint32_t)0x00000000U)
#define DMA_PBURST_INC4   ((uint32_t)DMA_SxCR_PBURST_0)
#define DMA_PBURST_INC8   ((uint32_t)DMA_SxCR_PBURST_1)
#define DMA_PBURST_INC16   ((uint32_t)DMA_SxCR_PBURST)
#define DMA_IT_TC   ((uint32_t)DMA_SxCR_TCIE)
#define DMA_IT_HT   ((uint32_t)DMA_SxCR_HTIE)
#define DMA_IT_TE   ((uint32_t)DMA_SxCR_TEIE)
#define DMA_IT_DME   ((uint32_t)DMA_SxCR_DMEIE)
#define DMA_IT_FE   ((uint32_t)0x00000080U)
#define DMA_FLAG_FEIF0_4   ((uint32_t)0x00000001U)
#define DMA_FLAG_DMEIF0_4   ((uint32_t)0x00000004U)
#define DMA_FLAG_TEIF0_4   ((uint32_t)0x00000008U)
#define DMA_FLAG_HTIF0_4   ((uint32_t)0x00000010U)
#define DMA_FLAG_TCIF0_4   ((uint32_t)0x00000020U)
#define DMA_FLAG_FEIF1_5   ((uint32_t)0x00000040U)
#define DMA_FLAG_DMEIF1_5   ((uint32_t)0x00000100U)
#define DMA_FLAG_TEIF1_5   ((uint32_t)0x00000200U)
#define DMA_FLAG_HTIF1_5   ((uint32_t)0x00000400U)
#define DMA_FLAG_TCIF1_5   ((uint32_t)0x00000800U)
#define DMA_FLAG_FEIF2_6   ((uint32_t)0x00010000U)
#define DMA_FLAG_DMEIF2_6   ((uint32_t)0x00040000U)
#define DMA_FLAG_TEIF2_6   ((uint32_t)0x00080000U)
#define DMA_FLAG_HTIF2_6   ((uint32_t)0x00100000U)
#define DMA_FLAG_TCIF2_6   ((uint32_t)0x00200000U)
#define DMA_FLAG_FEIF3_7   ((uint32_t)0x00400000U)
#define DMA_FLAG_DMEIF3_7   ((uint32_t)0x01000000U)
#define DMA_FLAG_TEIF3_7   ((uint32_t)0x02000000U)
#define DMA_FLAG_HTIF3_7   ((uint32_t)0x04000000U)
#define DMA_FLAG_TCIF3_7   ((uint32_t)0x08000000U)
#define BDMA_FLAG_GL0   ((uint32_t)0x00000001)
#define BDMA_FLAG_TC0   ((uint32_t)0x00000002)
#define BDMA_FLAG_HT0   ((uint32_t)0x00000004)
#define BDMA_FLAG_TE0   ((uint32_t)0x00000008)
#define BDMA_FLAG_GL1   ((uint32_t)0x00000010)
#define BDMA_FLAG_TC1   ((uint32_t)0x00000020)
#define BDMA_FLAG_HT1   ((uint32_t)0x00000040)
#define BDMA_FLAG_TE1   ((uint32_t)0x00000080)
#define BDMA_FLAG_GL2   ((uint32_t)0x00000100)
#define BDMA_FLAG_TC2   ((uint32_t)0x00000200)
#define BDMA_FLAG_HT2   ((uint32_t)0x00000400)
#define BDMA_FLAG_TE2   ((uint32_t)0x00000800)
#define BDMA_FLAG_GL3   ((uint32_t)0x00001000)
#define BDMA_FLAG_TC3   ((uint32_t)0x00002000)
#define BDMA_FLAG_HT3   ((uint32_t)0x00004000)
#define BDMA_FLAG_TE3   ((uint32_t)0x00008000)
#define BDMA_FLAG_GL4   ((uint32_t)0x00010000)
#define BDMA_FLAG_TC4   ((uint32_t)0x00020000)
#define BDMA_FLAG_HT4   ((uint32_t)0x00040000)
#define BDMA_FLAG_TE4   ((uint32_t)0x00080000)
#define BDMA_FLAG_GL5   ((uint32_t)0x00100000)
#define BDMA_FLAG_TC5   ((uint32_t)0x00200000)
#define BDMA_FLAG_HT5   ((uint32_t)0x00400000)
#define BDMA_FLAG_TE5   ((uint32_t)0x00800000)
#define BDMA_FLAG_GL6   ((uint32_t)0x01000000)
#define BDMA_FLAG_TC6   ((uint32_t)0x02000000)
#define BDMA_FLAG_HT6   ((uint32_t)0x04000000)
#define BDMA_FLAG_TE6   ((uint32_t)0x08000000)
#define BDMA_FLAG_GL7   ((uint32_t)0x10000000)
#define BDMA_FLAG_TC7   ((uint32_t)0x20000000)
#define BDMA_FLAG_HT7   ((uint32_t)0x40000000)
#define BDMA_FLAG_TE7   ((uint32_t)0x80000000)
#define __HAL_DMA_RESET_HANDLE_STATE(__HANDLE__)
 Reset DMA handle state.
#define __HAL_DMA_GET_FS(__HANDLE__)
 Return the current DMA Stream FIFO filled level.
#define __HAL_DMA_ENABLE(__HANDLE__)
 Enable the specified DMA Stream.
#define __HAL_DMA_DISABLE(__HANDLE__)
 Disable the specified DMA Stream.
#define __HAL_DMA_GET_TC_FLAG_INDEX(__HANDLE__)
 Return the current DMA Stream transfer complete flag.
#define __HAL_DMA_GET_HT_FLAG_INDEX(__HANDLE__)
 Return the current DMA Stream half transfer complete flag.
#define __HAL_DMA_GET_TE_FLAG_INDEX(__HANDLE__)
 Return the current DMA Stream transfer error flag.
#define __HAL_DMA_GET_FE_FLAG_INDEX(__HANDLE__)
 Return the current DMA Stream FIFO error flag.
#define __HAL_DMA_GET_DME_FLAG_INDEX(__HANDLE__)
 Return the current DMA Stream direct mode error flag.
#define __HAL_BDMA_GET_GI_FLAG_INDEX(__HANDLE__)
 Returns the current BDMA Channel Global interrupt flag.
#define __HAL_DMA_GET_FLAG(__HANDLE__, __FLAG__)
 Get the DMA Stream pending flags.
#define __HAL_DMA_CLEAR_FLAG(__HANDLE__, __FLAG__)
 Clear the DMA Stream pending flags.
#define DMA_TO_BDMA_IT(__DMA_IT__)
#define __HAL_BDMA_CHANNEL_ENABLE_IT(__HANDLE__, __INTERRUPT__)
#define __HAL_DMA_STREAM_ENABLE_IT(__HANDLE__, __INTERRUPT__)
#define __HAL_DMA_ENABLE_IT(__HANDLE__, __INTERRUPT__)
 Enable the specified DMA Stream interrupts.
#define __HAL_BDMA_CHANNEL_DISABLE_IT(__HANDLE__, __INTERRUPT__)
#define __HAL_DMA_STREAM_DISABLE_IT(__HANDLE__, __INTERRUPT__)
#define __HAL_DMA_DISABLE_IT(__HANDLE__, __INTERRUPT__)
 Disable the specified DMA Stream interrupts.
#define __HAL_BDMA_CHANNEL_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)
#define __HAL_DMA_STREAM_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)
#define __HAL_DMA_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)
 Check whether the specified DMA Stream interrupt is enabled or not.
#define __HAL_DMA_SET_COUNTER(__HANDLE__, __COUNTER__)
 Writes the number of data units to be transferred on the DMA Stream.
#define __HAL_DMA_GET_COUNTER(__HANDLE__)
 Returns the number of remaining data units in the current DMAy Streamx transfer.
#define IS_DMA_REQUEST(REQUEST)
#define IS_BDMA_REQUEST(REQUEST)
#define IS_DMA_DIRECTION(DIRECTION)
#define IS_DMA_BUFFER_SIZE(SIZE)
#define IS_DMA_PERIPHERAL_INC_STATE(STATE)
#define IS_DMA_MEMORY_INC_STATE(STATE)
#define IS_DMA_PERIPHERAL_DATA_SIZE(SIZE)
#define IS_DMA_MEMORY_DATA_SIZE(SIZE)
#define IS_DMA_MODE(MODE)
#define IS_DMA_PRIORITY(PRIORITY)
#define IS_DMA_FIFO_MODE_STATE(STATE)
#define IS_DMA_FIFO_THRESHOLD(THRESHOLD)
#define IS_DMA_MEMORY_BURST(BURST)
#define IS_DMA_PERIPHERAL_BURST(BURST)
typedef struct __DMA_HandleTypeDef DMA_HandleTypeDef
enum  HAL_DMA_StateTypeDef {
  HAL_DMA_STATE_RESET = 0x00U , HAL_DMA_STATE_READY = 0x01U , HAL_DMA_STATE_BUSY = 0x02U , HAL_DMA_STATE_ERROR = 0x03U ,
  HAL_DMA_STATE_ABORT = 0x04U
 HAL DMA State structures definition. More...
enum  HAL_DMA_LevelCompleteTypeDef { HAL_DMA_FULL_TRANSFER = 0x00U , HAL_DMA_HALF_TRANSFER = 0x01U }
 HAL DMA Transfer complete level structure definition. More...
enum  HAL_DMA_CallbackIDTypeDef {
  HAL_DMA_XFER_CPLT_CB_ID = 0x00U , HAL_DMA_XFER_HALFCPLT_CB_ID = 0x01U , HAL_DMA_XFER_M1CPLT_CB_ID = 0x02U , HAL_DMA_XFER_M1HALFCPLT_CB_ID = 0x03U ,
  HAL_DMA_XFER_ERROR_CB_ID = 0x04U , HAL_DMA_XFER_ABORT_CB_ID = 0x05U , HAL_DMA_XFER_ALL_CB_ID = 0x06U
 HAL DMA Callbacks IDs structure definition. More...
HAL_StatusTypeDef HAL_DMA_Init (DMA_HandleTypeDef *hdma)
HAL_StatusTypeDef HAL_DMA_DeInit (DMA_HandleTypeDef *hdma)
HAL_StatusTypeDef HAL_DMA_Start (DMA_HandleTypeDef *hdma, uint32_t SrcAddress, uint32_t DstAddress, uint32_t DataLength)
HAL_StatusTypeDef HAL_DMA_Start_IT (DMA_HandleTypeDef *hdma, uint32_t SrcAddress, uint32_t DstAddress, uint32_t DataLength)
HAL_StatusTypeDef HAL_DMA_Abort (DMA_HandleTypeDef *hdma)
HAL_StatusTypeDef HAL_DMA_Abort_IT (DMA_HandleTypeDef *hdma)
HAL_StatusTypeDef HAL_DMA_PollForTransfer (DMA_HandleTypeDef *hdma, HAL_DMA_LevelCompleteTypeDef CompleteLevel, uint32_t Timeout)
void HAL_DMA_IRQHandler (DMA_HandleTypeDef *hdma)
HAL_StatusTypeDef HAL_DMA_RegisterCallback (DMA_HandleTypeDef *hdma, HAL_DMA_CallbackIDTypeDef CallbackID, void(*pCallback)(DMA_HandleTypeDef *_hdma))
HAL_StatusTypeDef HAL_DMA_UnRegisterCallback (DMA_HandleTypeDef *hdma, HAL_DMA_CallbackIDTypeDef CallbackID)
HAL_DMA_StateTypeDef HAL_DMA_GetState (DMA_HandleTypeDef *hdma)
uint32_t HAL_DMA_GetError (DMA_HandleTypeDef *hdma)
Author
MCD Application Team
Attention
