RTEMS 6.3
stm32h7xx_hal_dfsdm.h File Reference
Header file of DFSDM HAL module. More...
struct  DFSDM_Channel_OutputClockTypeDef
 DFSDM channel output clock structure definition. More...
struct  DFSDM_Channel_InputTypeDef
 DFSDM channel input structure definition. More...
struct  DFSDM_Channel_SerialInterfaceTypeDef
 DFSDM channel serial interface structure definition. More...
struct  DFSDM_Channel_AwdTypeDef
 DFSDM channel analog watchdog structure definition. More...
struct  DFSDM_Channel_InitTypeDef
 DFSDM channel init structure definition. More...
struct  DFSDM_Channel_HandleTypeDef
 DFSDM channel handle structure definition. More...
struct  DFSDM_Filter_RegularParamTypeDef
 DFSDM filter regular conversion parameters structure definition. More...
struct  DFSDM_Filter_InjectedParamTypeDef
 DFSDM filter injected conversion parameters structure definition. More...
struct  DFSDM_Filter_FilterParamTypeDef
 DFSDM filter parameters structure definition. More...
struct  DFSDM_Filter_InitTypeDef
 DFSDM filter init structure definition. More...
struct  DFSDM_Filter_HandleTypeDef
 DFSDM filter handle structure definition. More...
struct  DFSDM_Filter_AwdParamTypeDef
 DFSDM filter analog watchdog parameters structure definition. More...
#define DFSDM_CHANNEL_OUTPUT_CLOCK_SYSTEM   0x00000000U
#define DFSDM_CHANNEL_OUTPUT_CLOCK_AUDIO   DFSDM_CHCFGR1_CKOUTSRC
#define DFSDM_CHANNEL_EXTERNAL_INPUTS   0x00000000U
#define DFSDM_CHANNEL_ADC_OUTPUT   DFSDM_CHCFGR1_DATMPX_0
#define DFSDM_CHANNEL_INTERNAL_REGISTER   DFSDM_CHCFGR1_DATMPX_1
#define DFSDM_CHANNEL_STANDARD_MODE   0x00000000U
#define DFSDM_CHANNEL_INTERLEAVED_MODE   DFSDM_CHCFGR1_DATPACK_0
#define DFSDM_CHANNEL_DUAL_MODE   DFSDM_CHCFGR1_DATPACK_1
#define DFSDM_CHANNEL_SAME_CHANNEL_PINS   0x00000000U
#define DFSDM_CHANNEL_FOLLOWING_CHANNEL_PINS   DFSDM_CHCFGR1_CHINSEL
#define DFSDM_CHANNEL_SPI_RISING   0x00000000U
#define DFSDM_CHANNEL_SPI_FALLING   DFSDM_CHCFGR1_SITP_0
#define DFSDM_CHANNEL_MANCHESTER_RISING   DFSDM_CHCFGR1_SITP_1
#define DFSDM_CHANNEL_MANCHESTER_FALLING   DFSDM_CHCFGR1_SITP
#define DFSDM_CHANNEL_SPI_CLOCK_EXTERNAL   0x00000000U
#define DFSDM_CHANNEL_SPI_CLOCK_INTERNAL   DFSDM_CHCFGR1_SPICKSEL_0
#define DFSDM_CHANNEL_SPI_CLOCK_INTERNAL_DIV2_FALLING   DFSDM_CHCFGR1_SPICKSEL_1
#define DFSDM_CHANNEL_SPI_CLOCK_INTERNAL_DIV2_RISING   DFSDM_CHCFGR1_SPICKSEL
#define DFSDM_CHANNEL_FASTSINC_ORDER   0x00000000U
#define DFSDM_CHANNEL_SINC1_ORDER   DFSDM_CHAWSCDR_AWFORD_0
#define DFSDM_CHANNEL_SINC2_ORDER   DFSDM_CHAWSCDR_AWFORD_1
#define DFSDM_CHANNEL_SINC3_ORDER   DFSDM_CHAWSCDR_AWFORD
#define DFSDM_FILTER_SW_TRIGGER   0x00000000U
#define DFSDM_FILTER_SYNC_TRIGGER   0x00000001U
#define DFSDM_FILTER_EXT_TRIGGER   0x00000002U
#define DFSDM_FILTER_EXT_TRIG_TIM1_TRGO   0x00000000U
#define DFSDM_FILTER_EXT_TRIG_TIM1_TRGO2   DFSDM_FLTCR1_JEXTSEL_0
#define DFSDM_FILTER_EXT_TRIG_TIM8_TRGO   DFSDM_FLTCR1_JEXTSEL_1
#define DFSDM_FILTER_EXT_TRIG_TIM8_TRGO2   (DFSDM_FLTCR1_JEXTSEL_0 | DFSDM_FLTCR1_JEXTSEL_1)
#define DFSDM_FILTER_EXT_TRIG_TIM3_TRGO   DFSDM_FLTCR1_JEXTSEL_2
#define DFSDM_FILTER_EXT_TRIG_TIM4_TRGO   (DFSDM_FLTCR1_JEXTSEL_0 | DFSDM_FLTCR1_JEXTSEL_2)
#define DFSDM_FILTER_EXT_TRIG_TIM16_OC1   (DFSDM_FLTCR1_JEXTSEL_2 | DFSDM_FLTCR1_JEXTSEL_1)
#define DFSDM_FILTER_EXT_TRIG_TIM6_TRGO   (DFSDM_FLTCR1_JEXTSEL_0 | DFSDM_FLTCR1_JEXTSEL_2 | DFSDM_FLTCR1_JEXTSEL_1)
#define DFSDM_FILTER_EXT_TRIG_TIM7_TRGO   DFSDM_FLTCR1_JEXTSEL_3
#define DFSDM_FILTER_EXT_TRIG_HRTIM1_ADCTRG1   (DFSDM_FLTCR1_JEXTSEL_3 | DFSDM_FLTCR1_JEXTSEL_0)
#define DFSDM_FILTER_EXT_TRIG_HRTIM1_ADCTRG3   (DFSDM_FLTCR1_JEXTSEL_3 | DFSDM_FLTCR1_JEXTSEL_1)
#define DFSDM_FILTER_EXT_TRIG_EXTI11   (DFSDM_FLTCR1_JEXTSEL_4 | DFSDM_FLTCR1_JEXTSEL_3)
#define DFSDM_FILTER_EXT_TRIG_EXTI15   (DFSDM_FLTCR1_JEXTSEL_4 | DFSDM_FLTCR1_JEXTSEL_3 | DFSDM_FLTCR1_JEXTSEL_0)
#define DFSDM_FILTER_EXT_TRIG_LPTIM1_OUT   (DFSDM_FLTCR1_JEXTSEL_4 | DFSDM_FLTCR1_JEXTSEL_3 | DFSDM_FLTCR1_JEXTSEL_1)
#define DFSDM_FILTER_EXT_TRIG_LPTIM2_OUT   (DFSDM_FLTCR1_JEXTSEL_4 | DFSDM_FLTCR1_JEXTSEL_3 | DFSDM_FLTCR1_JEXTSEL_1 | DFSDM_FLTCR1_JEXTSEL_0)
#define DFSDM_FILTER_EXT_TRIG_LPTIM3_OUT   (DFSDM_FLTCR1_JEXTSEL_4 | DFSDM_FLTCR1_JEXTSEL_3 | DFSDM_FLTCR1_JEXTSEL_2)
#define DFSDM_FILTER_EXT_TRIG_RISING_EDGE   DFSDM_FLTCR1_JEXTEN_0
#define DFSDM_FILTER_EXT_TRIG_FALLING_EDGE   DFSDM_FLTCR1_JEXTEN_1
#define DFSDM_FILTER_EXT_TRIG_BOTH_EDGES   DFSDM_FLTCR1_JEXTEN
#define DFSDM_FILTER_FASTSINC_ORDER   0x00000000U
#define DFSDM_FILTER_SINC1_ORDER   DFSDM_FLTFCR_FORD_0
#define DFSDM_FILTER_SINC2_ORDER   DFSDM_FLTFCR_FORD_1
#define DFSDM_FILTER_SINC3_ORDER   (DFSDM_FLTFCR_FORD_0 | DFSDM_FLTFCR_FORD_1)
#define DFSDM_FILTER_SINC4_ORDER   DFSDM_FLTFCR_FORD_2
#define DFSDM_FILTER_SINC5_ORDER   (DFSDM_FLTFCR_FORD_0 | DFSDM_FLTFCR_FORD_2)
#define DFSDM_FILTER_AWD_FILTER_DATA   0x00000000U
#define DFSDM_FILTER_AWD_CHANNEL_DATA   DFSDM_FLTCR1_AWFSEL
#define DFSDM_FILTER_ERROR_NONE   0x00000000U
#define DFSDM_FILTER_ERROR_REGULAR_OVERRUN   0x00000001U
#define DFSDM_FILTER_ERROR_INJECTED_OVERRUN   0x00000002U
#define DFSDM_FILTER_ERROR_DMA   0x00000003U
#define DFSDM_NO_BREAK_SIGNAL   0x00000000U
#define DFSDM_BREAK_SIGNAL_0   0x00000001U
#define DFSDM_BREAK_SIGNAL_1   0x00000002U
#define DFSDM_BREAK_SIGNAL_2   0x00000004U
#define DFSDM_BREAK_SIGNAL_3   0x00000008U
#define DFSDM_CHANNEL_0   0x00000001U
#define DFSDM_CHANNEL_1   0x00010002U
#define DFSDM_CHANNEL_2   0x00020004U
#define DFSDM_CHANNEL_3   0x00030008U
#define DFSDM_CHANNEL_4   0x00040010U
#define DFSDM_CHANNEL_5   0x00050020U
#define DFSDM_CHANNEL_6   0x00060040U
#define DFSDM_CHANNEL_7   0x00070080U
#define DFSDM_CONTINUOUS_CONV_OFF   0x00000000U
#define DFSDM_CONTINUOUS_CONV_ON   0x00000001U
#define DFSDM_AWD_HIGH_THRESHOLD   0x00000000U
#define DFSDM_AWD_LOW_THRESHOLD   0x00000001U
#define __HAL_DFSDM_CHANNEL_RESET_HANDLE_STATE(__HANDLE__)
 Reset DFSDM channel handle state.
#define __HAL_DFSDM_FILTER_RESET_HANDLE_STATE(__HANDLE__)
 Reset DFSDM filter handle state.
#define IS_DFSDM_CHANNEL_OUTPUT_CLOCK(CLOCK)
#define IS_DFSDM_CHANNEL_OUTPUT_CLOCK_DIVIDER(DIVIDER)
#define IS_DFSDM_CHANNEL_INPUT(INPUT)
#define IS_DFSDM_CHANNEL_DATA_PACKING(MODE)
#define IS_DFSDM_CHANNEL_INPUT_PINS(PINS)
#define IS_DFSDM_CHANNEL_SERIAL_INTERFACE_TYPE(MODE)
#define IS_DFSDM_CHANNEL_SPI_CLOCK(TYPE)
#define IS_DFSDM_CHANNEL_FILTER_ORDER(ORDER)
#define IS_DFSDM_CHANNEL_FILTER_OVS_RATIO(RATIO)
#define IS_DFSDM_CHANNEL_OFFSET(VALUE)
#define IS_DFSDM_CHANNEL_RIGHT_BIT_SHIFT(VALUE)
#define IS_DFSDM_CHANNEL_SCD_THRESHOLD(VALUE)
#define IS_DFSDM_FILTER_REG_TRIGGER(TRIG)
#define IS_DFSDM_FILTER_INJ_TRIGGER(TRIG)
#define IS_DFSDM_FILTER_EXT_TRIG(TRIG)
#define IS_DFSDM_FILTER_EXT_TRIG_EDGE(EDGE)
#define IS_DFSDM_FILTER_SINC_ORDER(ORDER)
#define IS_DFSDM_FILTER_OVS_RATIO(RATIO)
#define IS_DFSDM_FILTER_INTEGRATOR_OVS_RATIO(RATIO)
#define IS_DFSDM_FILTER_AWD_DATA_SOURCE(DATA)
#define IS_DFSDM_FILTER_AWD_THRESHOLD(VALUE)
#define IS_DFSDM_BREAK_SIGNALS(VALUE)
#define IS_DFSDM_REGULAR_CHANNEL(CHANNEL)
#define IS_DFSDM_INJECTED_CHANNEL(CHANNEL)
#define IS_DFSDM_CONTINUOUS_MODE(MODE)
enum  HAL_DFSDM_Channel_StateTypeDef { HAL_DFSDM_CHANNEL_STATE_RESET = 0x00U , HAL_DFSDM_CHANNEL_STATE_READY = 0x01U , HAL_DFSDM_CHANNEL_STATE_ERROR = 0xFFU }
 HAL DFSDM Channel states definition. More...
enum  HAL_DFSDM_Filter_StateTypeDef {
  HAL_DFSDM_FILTER_STATE_RESET = 0x00U , HAL_DFSDM_FILTER_STATE_READY = 0x01U , HAL_DFSDM_FILTER_STATE_REG = 0x02U , HAL_DFSDM_FILTER_STATE_INJ = 0x03U ,
  HAL_DFSDM_FILTER_STATE_REG_INJ = 0x04U , HAL_DFSDM_FILTER_STATE_ERROR = 0xFFU
 HAL DFSDM Filter states definition. More...
HAL_StatusTypeDef HAL_DFSDM_ChannelInit (DFSDM_Channel_HandleTypeDef *hdfsdm_channel)
HAL_StatusTypeDef HAL_DFSDM_ChannelDeInit (DFSDM_Channel_HandleTypeDef *hdfsdm_channel)
void HAL_DFSDM_ChannelMspInit (DFSDM_Channel_HandleTypeDef *hdfsdm_channel)
void HAL_DFSDM_ChannelMspDeInit (DFSDM_Channel_HandleTypeDef *hdfsdm_channel)
HAL_StatusTypeDef HAL_DFSDM_ChannelCkabStart (DFSDM_Channel_HandleTypeDef *hdfsdm_channel)
HAL_StatusTypeDef HAL_DFSDM_ChannelCkabStart_IT (DFSDM_Channel_HandleTypeDef *hdfsdm_channel)
HAL_StatusTypeDef HAL_DFSDM_ChannelCkabStop (DFSDM_Channel_HandleTypeDef *hdfsdm_channel)
HAL_StatusTypeDef HAL_DFSDM_ChannelCkabStop_IT (DFSDM_Channel_HandleTypeDef *hdfsdm_channel)
HAL_StatusTypeDef HAL_DFSDM_ChannelScdStart (DFSDM_Channel_HandleTypeDef *hdfsdm_channel, uint32_t Threshold, uint32_t BreakSignal)
HAL_StatusTypeDef HAL_DFSDM_ChannelScdStart_IT (DFSDM_Channel_HandleTypeDef *hdfsdm_channel, uint32_t Threshold, uint32_t BreakSignal)
HAL_StatusTypeDef HAL_DFSDM_ChannelScdStop (DFSDM_Channel_HandleTypeDef *hdfsdm_channel)
HAL_StatusTypeDef HAL_DFSDM_ChannelScdStop_IT (DFSDM_Channel_HandleTypeDef *hdfsdm_channel)
int16_t HAL_DFSDM_ChannelGetAwdValue (const DFSDM_Channel_HandleTypeDef *hdfsdm_channel)
HAL_StatusTypeDef HAL_DFSDM_ChannelModifyOffset (DFSDM_Channel_HandleTypeDef *hdfsdm_channel, int32_t Offset)
HAL_StatusTypeDef HAL_DFSDM_ChannelPollForCkab (const DFSDM_Channel_HandleTypeDef *hdfsdm_channel, uint32_t Timeout)
HAL_StatusTypeDef HAL_DFSDM_ChannelPollForScd (const DFSDM_Channel_HandleTypeDef *hdfsdm_channel, uint32_t Timeout)
void HAL_DFSDM_ChannelCkabCallback (DFSDM_Channel_HandleTypeDef *hdfsdm_channel)
void HAL_DFSDM_ChannelScdCallback (DFSDM_Channel_HandleTypeDef *hdfsdm_channel)
HAL_DFSDM_Channel_StateTypeDef HAL_DFSDM_ChannelGetState (const DFSDM_Channel_HandleTypeDef *hdfsdm_channel)
HAL_StatusTypeDef HAL_DFSDM_FilterInit (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
HAL_StatusTypeDef HAL_DFSDM_FilterDeInit (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
void HAL_DFSDM_FilterMspInit (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
void HAL_DFSDM_FilterMspDeInit (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
HAL_StatusTypeDef HAL_DFSDM_FilterConfigRegChannel (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t Channel, uint32_t ContinuousMode)
HAL_StatusTypeDef HAL_DFSDM_FilterConfigInjChannel (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t Channel)
HAL_StatusTypeDef HAL_DFSDM_FilterRegularStart (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
HAL_StatusTypeDef HAL_DFSDM_FilterRegularStart_IT (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
HAL_StatusTypeDef HAL_DFSDM_FilterRegularStart_DMA (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, int32_t *pData, uint32_t Length)
HAL_StatusTypeDef HAL_DFSDM_FilterRegularMsbStart_DMA (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, int16_t *pData, uint32_t Length)
HAL_StatusTypeDef HAL_DFSDM_FilterRegularStop (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
HAL_StatusTypeDef HAL_DFSDM_FilterRegularStop_IT (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
HAL_StatusTypeDef HAL_DFSDM_FilterRegularStop_DMA (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
HAL_StatusTypeDef HAL_DFSDM_FilterInjectedStart (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
HAL_StatusTypeDef HAL_DFSDM_FilterInjectedStart_IT (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
HAL_StatusTypeDef HAL_DFSDM_FilterInjectedStart_DMA (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, int32_t *pData, uint32_t Length)
HAL_StatusTypeDef HAL_DFSDM_FilterInjectedMsbStart_DMA (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, int16_t *pData, uint32_t Length)
HAL_StatusTypeDef HAL_DFSDM_FilterInjectedStop (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
HAL_StatusTypeDef HAL_DFSDM_FilterInjectedStop_IT (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
HAL_StatusTypeDef HAL_DFSDM_FilterInjectedStop_DMA (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
HAL_StatusTypeDef HAL_DFSDM_FilterAwdStart_IT (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, const DFSDM_Filter_AwdParamTypeDef *awdParam)
HAL_StatusTypeDef HAL_DFSDM_FilterAwdStop_IT (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
HAL_StatusTypeDef HAL_DFSDM_FilterExdStart (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t Channel)
HAL_StatusTypeDef HAL_DFSDM_FilterExdStop (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
int32_t HAL_DFSDM_FilterGetRegularValue (const DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t *Channel)
int32_t HAL_DFSDM_FilterGetInjectedValue (const DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t *Channel)
int32_t HAL_DFSDM_FilterGetExdMaxValue (const DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t *Channel)
int32_t HAL_DFSDM_FilterGetExdMinValue (const DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t *Channel)
uint32_t HAL_DFSDM_FilterGetConvTimeValue (const DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
void HAL_DFSDM_IRQHandler (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
HAL_StatusTypeDef HAL_DFSDM_FilterPollForRegConversion (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t Timeout)
HAL_StatusTypeDef HAL_DFSDM_FilterPollForInjConversion (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t Timeout)
void HAL_DFSDM_FilterRegConvCpltCallback (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
void HAL_DFSDM_FilterRegConvHalfCpltCallback (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
void HAL_DFSDM_FilterInjConvCpltCallback (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
void HAL_DFSDM_FilterInjConvHalfCpltCallback (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
void HAL_DFSDM_FilterAwdCallback (DFSDM_Filter_HandleTypeDef *hdfsdm_filter, uint32_t Channel, uint32_t Threshold)
void HAL_DFSDM_FilterErrorCallback (DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
HAL_DFSDM_Filter_StateTypeDef HAL_DFSDM_FilterGetState (const DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
uint32_t HAL_DFSDM_FilterGetError (const DFSDM_Filter_HandleTypeDef *hdfsdm_filter)
Author
MCD Application Team
Attention
