RTEMS 6.3
CRC HAL module driver. This file provides firmware functions to manage the following functionalities of the Cyclic Redundancy Check (CRC) peripheral: More...
#include "stm32h7xx_hal.h"CRC HAL module driver. This file provides firmware functions to manage the following functionalities of the Cyclic Redundancy Check (CRC) peripheral:
##### How to use this driver #####
(+) Enable CRC AHB clock using __HAL_RCC_CRC_CLK_ENABLE();
(+) Initialize CRC calculator
(++) specify generating polynomial (peripheral default or non-default one)
(++) specify initialization value (peripheral default or non-default one)
(++) specify input data format
(++) specify input or output data inversion mode if any
(+) Use HAL_CRC_Accumulate() function to compute the CRC value of the
input data buffer starting with the previously computed CRC as
(+) Use HAL_CRC_Calculate() function to compute the CRC value of the
input data buffer starting with the defined initialization value
(default or non-default) to initiate CRC calculation
