RTEMS 6.3
system_stm32h7xx.c File Reference
CMSIS Cortex-Mx Device Peripheral Access Layer System Source File. More...
#include "stm32h7xx.h"
#include <math.h>
#define HSE_VALUE   ((uint32_t)25000000)
#define CSI_VALUE   ((uint32_t)4000000)
#define HSI_VALUE   ((uint32_t)64000000)
#define VECT_TAB_OFFSET   0x00000000UL
void SystemInit (void)
 Setup the microcontroller system Initialize the FPU setting and vector table location configuration.
void SystemCoreClockUpdate (void)
 Update SystemCoreClock variable according to Clock Register Values. The SystemCoreClock variable contains the core clock , it can be used by the user application to setup the SysTick timer or configure other parameters.
uint32_t SystemCoreClock = 64000000
uint32_t SystemD2Clock = 64000000
const uint8_t D1CorePrescTable [16] = {0, 0, 0, 0, 1, 2, 3, 4, 1, 2, 3, 4, 6, 7, 8, 9}
Author
MCD Application Team
This file provides two functions and one global variable to be called from user application:
  • SystemInit(): This function is called at startup just after reset and before branch to main program. This call is made inside the "startup_stm32h7xx.s" file.
  • SystemCoreClock variable: Contains the core clock (HCLK), it can be used by the user application to setup the SysTick timer or configure other parameters.
  • SystemCoreClockUpdate(): Updates the variable SystemCoreClock and must be called whenever the core clock is changed during program execution.
Attention
Copyright (c) 2019 STMicroelectronics. All rights reserved.
