RTEMS
6.3
Toggle main menu visibility
bsps
include
grlib
spwtdp.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
/* SPWTDP - SpaceWire Time Distribution Protocol. The driver provides
4
* device discovery and interrupt management.
5
6
* COPYRIGHT (c) 2017.
7
* Cobham Gaisler AB
8
9
10
* modification, are permitted provided that the following conditions
11
* are met:
12
* 1. Redistributions of source code must retain the above copyright
13
* notice, this list of conditions and the following disclaimer.
14
* 2. Redistributions in binary form must reproduce the above copyright
15
* notice, this list of conditions and the following disclaimer in the
16
* documentation and/or other materials provided with the distribution.
17
18
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
19
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
20
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
21
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
22
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
23
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
24
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
25
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
26
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
27
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
28
* POSSIBILITY OF SUCH DAMAGE.
29
30
31
32
#ifndef __SPWTDP_H__
33
#define __SPWTDP_H__
34
35
#ifdef __cplusplus
36
extern
"C"
37
#endif
38
39
#define SPWTDP_ERR_OK 0
40
#define SPWTDP_ERR_EINVAL -1
41
#define SPWTDP_ERR_ERROR -2
42
#define SPWTDP_ERR_NOINIT -3
43
44
/* Maximum number of SPWTDP devices supported by driver */
45
#define SPWTDP_MAX 2
46
47
/* SPWTDP Register layout */
48
struct
spwtdp_regs
49
volatile
unsigned
int
conf[4];
/* 0x000-0x00C */
50
volatile
unsigned
int
stat[4];
/* 0x010-0x01C */
51
volatile
unsigned
int
cmd_ctrl;
/* 0x020 */
52
volatile
unsigned
int
cmd_et[5];
/* 0x024-0x034 */
53
volatile
unsigned
int
resv1[2];
/* 0x038-0x03C */
54
volatile
unsigned
int
dat_ctrl;
/* 0x040 */
55
volatile
unsigned
int
dat_et[5];
/* 0x044-0x054 */
56
volatile
unsigned
int
resv2[2];
/* 0x058-0x05C */
57
volatile
unsigned
int
ts_rx_ctrl;
/* 0x060 */
58
volatile
unsigned
int
ts_rx_et[5];
/* 0x064-0x074 */
59
volatile
unsigned
int
resv3[2];
/* 0x078-0x07C */
60
volatile
unsigned
int
ts_tx_ctrl;
/* 0x080 */
61
volatile
unsigned
int
ts_tx_et[5];
/* 0x084-0x094 */
62
volatile
unsigned
int
resv4[2];
/* 0x098 */
63
volatile
unsigned
int
lat_ctrl;
/* 0x0A0 */
64
volatile
unsigned
int
lat_et[5];
/* 0x0A4-0x0B4 */
65
volatile
unsigned
int
resv5[2];
/* 0x0B8-0x0BC */
66
volatile
unsigned
int
ien;
/* 0x0C0 */
67
volatile
unsigned
int
ists;
/* 0x0C4 */
68
volatile
unsigned
int
dlycnt;
/* 0x0C8 */
69
volatile
unsigned
int
dissync;
/* 0x0CC */
70
volatile
unsigned
int
resv6[12];
/* 0x0D0-0x0FC */
71
volatile
unsigned
int
edmask[4];
/* 0x100-0x10C */
72
struct
73
volatile
unsigned
int
ctrl;
/* 0x110, 0x130, 0x150, 0x170 */
74
volatile
unsigned
int
et[5];
/* 0x114-0x124, 0x134-0x144, 0x154-0x164, 0x174-0x184, */
75
volatile
unsigned
int
resv0[2];
/* 0x128-0x12C, 0x148-0x14C, 0x168-0x16C, 0x188-0x18C, */
76
} edat[4];
/* 0x110-0x18C */
77
volatile
unsigned
int
resv7[4];
/* 0x190-0x19C */
78
volatile
unsigned
int
pulse[8];
/* 0x1A0-0x1BC */
79
volatile
unsigned
int
resv8[16];
/* 0x1C0-0x1FC */
80
81
82
83
* Configuration register definitions
84
85
#define CONF0_JE (0x1 << CONF0_JE_BIT)
86
#define CONF0_ST (0x1 << CONF0_ST_BIT)
87
#define CONF0_EP (0x1 << CONF0_EP_BIT)
88
#define CONF0_ET (0x1 << CONF0_ET_BIT)
89
#define CONF0_SP (0x1 << CONF0_SP_BIT)
90
#define CONF0_SE (0x1 << CONF0_SE_BIT)
91
#define CONF0_LE (0x1 << CONF0_LE_BIT)
92
#define CONF0_AE (0x1 << CONF0_AE_BIT)
93
#define CONF0_MAP (0x1f << CONF0_MAP_BIT)
94
#define CONF0_TD (0x1 << CONF0_TD_BIT)
95
#define CONF0_MU (0x1 << CONF0_MU_BIT)
96
#define CONF0_SEL (0x3 << CONF0_SEL_BIT)
97
#define CONF0_ME (0x1 << CONF0_ME_BIT)
98
#define CONF0_RE (0x1 << CONF0_RE_BIT)
99
#define CONF0_TE (0x1 << CONF0_TE_BIT)
100
#define CONF0_RS (0x1 << CONF0_RS_BIT)
101
102
#define CONF0_JE_BIT 24
103
#define CONF0_ST_BIT 21
104
#define CONF0_EP_BIT 20
105
#define CONF0_ET_BIT 19
106
#define CONF0_SP_BIT 18
107
#define CONF0_SE_BIT 17
108
#define CONF0_LE_BIT 16
109
#define CONF0_AE_BIT 15
110
#define CONF0_MAP_BIT 8
111
#define CONF0_TD_BIT 7
112
#define CONF0_MU_BIT 6
113
#define CONF0_SEL_BIT 4
114
#define CONF0_ME_BIT 3
115
#define CONF0_RE_BIT 2
116
#define CONF0_TE_BIT 1
117
#define CONF0_RS_BIT 0
118
119
#define CONF1_FSINC (0x3fffffff << CONF1_FSINC_BIT)
120
121
#define CONF1_FSINC_BIT 0
122
123
#define CONF2_CV (0xffffff << CONF2_CV_BIT)
124
#define CONF2_ETINC (0xff << CONF2_ETINC_BIT)
125
126
#define CONF2_CV_BIT 8
127
#define CONF2_ETINC_BIT 0
128
129
#define CONF3_OUTPORT (0xf << CONF3_OUTPORT_BIT)
130
#define CONF3_INPORT (0xf << CONF3_INPORT_BIT)
131
#define CONF3_STM (0x3f << CONF3_STM_BIT)
132
#define CONF3_DI64R (0x1 << CONF3_DI64R_BIT)
133
#define CONF3_DI64T (0x1 << CONF3_DI64T_BIT)
134
#define CONF3_DI64 (0x1 << CONF3_DI64_BIT)
135
#define CONF3_DI (0x1 << CONF3_DI_BIT)
136
#define CONF3_INRX (0x1f << CONF3_INRX_BIT)
137
#define CONF3_INTX (0x1f << CONF3_INTX_BIT)
138
139
#define CONF3_OUTPORT_BIT 28
140
#define CONF3_INPORT_BIT 24
141
#define CONF3_STM_BIT 16
142
#define CONF3_DI64R_BIT 13
143
#define CONF3_DI64T_BIT 12
144
#define CONF3_DI64_BIT 11
145
#define CONF3_DI_BIT 10
146
#define CONF3_INRX_BIT 5
147
#define CONF3_INTX_BIT 0
148
149
150
* Control register definitions
151
152
#define CTRL_NC (0x1 << CTRL_NC_BIT)
153
#define CTRL_IS (0x1 << CTRL_IS_BIT)
154
#define CTRL_SPWTC (0xff << CTRL_SPWTC_BIT)
155
#define CTRL_CPF (0xffff << CTRL_CPF_BIT)
156
157
#define CTRL_NC_BIT 31
158
#define CTRL_IS_BIT 30
159
#define CTRL_SPWTC_BIT 16
160
#define CTRL_CPF_BIT 0
161
162
163
* Interrupt register definition
164
165
#define SPWTDP_IRQ_S (0x1 << SPWTDP_IRQ_S_BIT)
166
#define SPWTDP_IRQ_TR (0x1 << SPWTDP_IRQ_TR_BIT)
167
#define SPWTDP_IRQ_TM (0x1 << SPWTDP_IRQ_TM_BIT)
168
#define SPWTDP_IRQ_TT (0x1 << SPWTDP_IRQ_TT_BIT)
169
#define SPWTDP_IRQ_DIR (0x1 << SPWTDP_IRQ_DIR_BIT)
170
#define SPWTDP_IRQ_DIT (0x1 << SPWTDP_IRQ_DIT_BIT)
171
#define SPWTDP_IRQ_EDI0 (0x1 << SPWTDP_IRQ_EDI0_BIT)
172
#define SPWTDP_IRQ_EDI1 (0x1 << SPWTDP_IRQ_EDI1_BIT)
173
#define SPWTDP_IRQ_EDI2 (0x1 << SPWTDP_IRQ_EDI2_BIT)
174
#define SPWTDP_IRQ_EDI3 (0x1 << SPWTDP_IRQ_EDI3_BIT)
175
#define SPWTDP_IRQ_SET (0x1 << SPWTDP_IRQ_SET_BIT)
176
#define SPWTDP_IRQ_P0 (0x1 << SPWTDP_IRQ_P0_BIT)
177
#define SPWTDP_IRQ_P1 (0x1 << SPWTDP_IRQ_P1_BIT)
178
#define SPWTDP_IRQ_P2 (0x1 << SPWTDP_IRQ_P2_BIT)
179
#define SPWTDP_IRQ_P3 (0x1 << SPWTDP_IRQ_P3_BIT)
180
#define SPWTDP_IRQ_P4 (0x1 << SPWTDP_IRQ_P4_BIT)
181
#define SPWTDP_IRQ_P5 (0x1 << SPWTDP_IRQ_P5_BIT)
182
#define SPWTDP_IRQ_P6 (0x1 << SPWTDP_IRQ_P6_BIT)
183
#define SPWTDP_IRQ_P7 (0x1 << SPWTDP_IRQ_P7_BIT)
184
#define SPWTDP_IRQ_NCTC (0x1 << SPWTDP_IRQ_NCTC_BIT)
185
#define SPWTDP_IRQ_WCLEAR \
186
(SPWTDP_IRQ_S | SPWTDP_IRQ_TR | SPWTDP_IRQ_TM | \
187
SPWTDP_IRQ_TT | SPWTDP_IRQ_DIR | SPWTDP_IRQ_DIT | SPWTDP_IRQ_EDI0 | \
188
SPWTDP_IRQ_EDI1 | SPWTDP_IRQ_EDI2 | SPWTDP_IRQ_EDI3 | SPWTDP_IRQ_SET |\
189
SPWTDP_IRQ_P0 | SPWTDP_IRQ_P1 | SPWTDP_IRQ_P2 | SPWTDP_IRQ_P3 | \
190
SPWTDP_IRQ_P4 | SPWTDP_IRQ_P5 | SPWTDP_IRQ_P6 | SPWTDP_IRQ_P7 | \
191
SPWTDP_IRQ_NCTC)
192
#define SPWTDP_IRQ_ALL (SPWTDP_IRQ_WCLEAR)
193
194
#define SPWTDP_IRQ_S_BIT 0
195
#define SPWTDP_IRQ_TR_BIT 1
196
#define SPWTDP_IRQ_TM_BIT 2
197
#define SPWTDP_IRQ_TT_BIT 3
198
#define SPWTDP_IRQ_DIR_BIT 4
199
#define SPWTDP_IRQ_DIT_BIT 5
200
#define SPWTDP_IRQ_EDI0_BIT 6
201
#define SPWTDP_IRQ_EDI1_BIT 7
202
#define SPWTDP_IRQ_EDI2_BIT 8
203
#define SPWTDP_IRQ_EDI3_BIT 9
204
#define SPWTDP_IRQ_SET_BIT 10
205
#define SPWTDP_IRQ_P0_BIT 11
206
#define SPWTDP_IRQ_P1_BIT 12
207
#define SPWTDP_IRQ_P2_BIT 13
208
#define SPWTDP_IRQ_P3_BIT 14
209
#define SPWTDP_IRQ_P4_BIT 15
210
#define SPWTDP_IRQ_P5_BIT 16
211
#define SPWTDP_IRQ_P6_BIT 17
212
#define SPWTDP_IRQ_P7_BIT 18
213
#define SPWTDP_IRQ_NCTC_BIT 19
214
215
/* Register the SPWTDP Driver to the Driver Manager */
216
void
spwtdp_register_drv(
void
217
218
/* Open a SPWTDP device by registration order index. A SPWTDP device can only by
219
* opened once. The handle returned must be used as the input parameter 'spwtdp'
220
* in the rest of the calls in the function interface.
221
222
extern
void
*spwtdp_open(
int
dev_no);
223
224
/* Close a previously opened SPWTDP device */
225
extern
int
spwtdp_close(
void
spwtdp
226
227
/* Reset SPWTDP Core */
228
extern
int
spwtdp_reset(
void
spwtdp
229
230
/* Setup the frequency configuration registers */
231
extern
int
spwtdp_freq_setup(
void
spwtdp
, uint32_t fsinc, uint32_t
cv
232
uint8_t etinc);
233
234
/* Unmask Interrupts at Interrupt controller */
235
extern
int
spwtdp_interrupt_unmask(
void
spwtdp
, uint32_t irqmask);
236
237
/* Mask Interrupts at Interrupt controller */
238
extern
int
spwtdp_interrupt_mask(
void
spwtdp
239
240
/* Function ISR callback prototype
241
242
* ists - Interrupt STatus register of the SPWTDP core read by ISR
243
* data - Custom data provided by user
244
245
typedef
void (*spwtdp_isr_t)(
unsigned
int
ists,
void
*data);
246
247
/* Register an Interrupt handler and custom data, the function call is
248
* removed by calling unregister function.
249
250
extern
int
spwtdp_isr_register(
void
spwtdp
, spwtdp_isr_t isr,
void
*data);
251
252
/* Unregister an Interrupt handler */
253
extern
int
spwtdp_isr_unregister(
void
spwtdp
254
255
/* Get and clear interrupt status */
256
extern
int
spwtdp_interrupt_status(
void
spwtdp
, uint32_t *sts,
257
uint32_t clrmask);
258
259
/* Setup Initiator and target */
260
#define SPWTDP_TDP_ENABLE CONF0_TD
261
#define SPWTDP_TDP_DISABLE 0
262
#define SPWTDP_LATENCY_ENABLE CONF0_LE
263
#define SPWTDP_LATENCY_DISABLE 0
264
#define SPWTDP_EXTET_INC_POLARITY_RISING CONF0_EP
265
#define SPWTDP_EXTET_INC_POLARITY_FALLING 0
266
#define SPWTDP_EXTET_INC_ENABLE CONF0_ET
267
#define SPWTDP_EXTET_INC_DISABLE 0
268
#define SPWTDP_EXTET_POLARITY_RISING CONF0_SP
269
#define SPWTDP_EXTET_POLARITY_FALLING 0
270
#define SPWTDP_EXTET_ENABLE CONF0_SE
271
#define SPWTDP_EXTET_DISABLE 0
272
#define SPWTDP_TARGET_SPWSYNC_ENABLE CONF0_ST
273
#define SPWTDP_TARGET_SPWSYNC_DISABLE 0
274
#define SPWTDP_TARGET_JITTERC_ENABLE CONF0_JE
275
#define SPWTDP_TARGET_JITTERC_DISABLE 0
276
#define SPWTDP_TARGET_MITIGATION_ENABLE CONF0_ME
277
#define SPWTDP_TARGET_MITIGATION_DISABLE 0
278
extern
int
spwtdp_initiator_conf(
void
spwtdp
, uint8_t mapping,
279
uint32_t options);
280
extern
int
spwtdp_target_conf(
void
spwtdp
, uint8_t mapping, uint32_t options);
281
282
/* Setup Initiator and target dist interrupts */
283
extern
int
spwtdp_initiator_int_conf(
void
spwtdp
, uint8_t stm, uint8_t inrx,
284
uint8_t intx);
285
#define SPWTDP_TARGET_DISTINT_INTACK CONF3_DI
286
#define SPWTDP_TARGET_DISTINT_INT 0
287
extern
int
spwtdp_target_int_conf(
void
spwtdp
, uint8_t inrx, uint8_t intx,
288
uint32_t options);
289
290
/* Enable Initiator and target */
291
extern
int
spwtdp_initiator_enable(
void
spwtdp
292
extern
int
spwtdp_target_enable(
void
spwtdp
293
294
/* Disable Initiator and target */
295
extern
int
spwtdp_initiator_disable(
void
spwtdp
296
extern
int
spwtdp_target_disable(
void
spwtdp
297
298
/* Get and clear status */
299
extern
int
spwtdp_status(
void
spwtdp
, uint32_t *sts, uint32_t clrmask);
300
301
/* Define time struct */
302
/* Length of the max data sample (136 bits), aligned to the next 32-bit word
303
* (160 bits=20 byte=5 words)
304
305
#define SPWTDP_TIME_DATA_LENGTH 20
306
struct
spwtdp_time_t
307
uint8_t data[SPWTDP_TIME_DATA_LENGTH];
308
uint32_t preamble;
309
310
typedef
struct
spwtdp_time_t
spwtdp_time_t
311
312
/* Get datation elapsed time */
313
extern
int
spwtdp_dat_et_get(
void
spwtdp
spwtdp_time_t
* val);
314
extern
int
spwtdp_tsrx_et_get(
void
spwtdp
spwtdp_time_t
* val);
315
extern
int
spwtdp_tstx_et_get(
void
spwtdp
spwtdp_time_t
* val);
316
extern
int
spwtdp_lat_et_get(
void
spwtdp
spwtdp_time_t
* val);
317
extern
int
spwtdp_cmd_et_get(
void
spwtdp
spwtdp_time_t
* val);
318
319
/* Configure TSTX */
320
extern
int
spwtdp_initiator_tstx_conf(
void
spwtdp
, uint8_t tstc);
321
322
/* Manage control register */
323
extern
int
spwtdp_initiator_cmd_et_set(
void
spwtdp
spwtdp_time_t
val);
324
extern
int
spwtdp_initiator_cmd_spwtc_set(
void
spwtdp
, uint8_t spwtc);
325
#define SPWTDP_TARGET_CTRL_NEWCOMMAND_ENABLE CTRL_NC
326
#define SPWTDP_TARGET_CTRL_NEWCOMMAND_DISABLE 0
327
#define SPWTDP_TARGET_CTRL_INIT CTRL_IS
328
#define SPWTDP_TARGET_CTRL_SYNC 0
329
extern
int
spwtdp_target_cmd_conf(
void
spwtdp
, uint8_t spwtc, uint16_t cpf,
330
uint32_t options);
331
332
/* Get precision */
333
extern
int
spwtdp_precision_get(
void
spwtdp
, uint8_t *fine, uint8_t *coarse);
334
335
#ifdef __cplusplus
336
337
#endif
338
339
#endif
spwtdp_regs
Definition
spwtdp.h:48
spwtdp_time_t
Definition
spwtdp.h:306
spwtdp
This structure defines the SPWTDP register block memory map.
Definition
spwtdp-regs.h:1055
cv
unsigned cv
Definition
tte.h:15
