RTEMS
6.3
Toggle main menu visibility
bsps
include
grlib
spwcuc.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
/* SPWCUC - SpaceWire - CCSDS unsegmented Code Transfer Protocol GRLIB core
4
* register driver interface.
5
6
* COPYRIGHT (c) 2009.
7
* Cobham Gaisler AB.
8
9
10
* modification, are permitted provided that the following conditions
11
* are met:
12
* 1. Redistributions of source code must retain the above copyright
13
* notice, this list of conditions and the following disclaimer.
14
* 2. Redistributions in binary form must reproduce the above copyright
15
* notice, this list of conditions and the following disclaimer in the
16
* documentation and/or other materials provided with the distribution.
17
18
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
19
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
20
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
21
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
22
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
23
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
24
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
25
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
26
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
27
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
28
* POSSIBILITY OF SUCH DAMAGE.
29
30
31
#ifndef __SPWCUC_H__
32
#define __SPWCUC_H__
33
34
#define PKT_INIT_IRQ 0x1
35
#define PKT_ERR_IRQ 0x2
36
#define PKT_RX_IRQ 0x4
37
#define WRAP_ERR_IRQ 0x8
38
#define WRAP_IRQ 0x10
39
#define SYNC_ERR_IRQ 0x20
40
#define SYNC_IRQ 0x40
41
#define TOL_ERR_IRQ 0x80
42
#define TICK_RX_ERR_IRQ 0x100
43
#define TICK_RX_WRAP_IRQ 0x200
44
#define TICK_RX_IRQ 0x400
45
#define TICK_TX_WRAP_IRQ 0x800
46
#define TICK_TX_IRQ 0x1000
47
48
/* SPWCUC Register layout */
49
struct
spwcuc_regs
50
volatile
unsigned
int
config;
/* 00 */
51
volatile
unsigned
int
status;
/* 04 */
52
volatile
unsigned
int
control;
/* 08 */
53
volatile
unsigned
int
unused0;
/* 0c */
54
volatile
unsigned
int
dla;
/* 10 */
55
volatile
unsigned
int
pid;
/* 14 */
56
volatile
unsigned
int
offset;
/* 18 */
57
volatile
unsigned
int
unused1;
/* 1c */
58
volatile
unsigned
int
pkt_ct;
/* 20 */
59
volatile
unsigned
int
pkt_ft;
/* 24 */
60
volatile
unsigned
int
pkt_pf_crc;
/* 28 */
61
volatile
unsigned
int
unused2;
/* 2c */
62
volatile
unsigned
int
etct;
/* 30 */
63
volatile
unsigned
int
etft;
/* 34 */
64
volatile
unsigned
int
etct_next;
/* 38 */
65
volatile
unsigned
int
etft_next;
/* 3c */
66
volatile
unsigned
int
unused3[8];
/* 40-5c */
67
volatile
unsigned
int
pimsr;
/* 60 */
68
volatile
unsigned
int
pimr;
/* 64 */
69
volatile
unsigned
int
pisr;
/* 68 */
70
volatile
unsigned
int
pir;
/* 6c */
71
volatile
unsigned
int
imr;
/* 70 */
72
volatile
unsigned
int
picr;
/* 74 */
73
74
75
struct
spwcuc_cfg
76
unsigned
char
sel_out;
/* Bits 3-0 enable time code transmission on respective output */
77
unsigned
char
sel_in;
/* Select SpW to receive time codes on, 0-3 */
78
unsigned
char
mapping;
/* Define mapping of time code time info into T-field, 0-31 */
79
unsigned
char
tolerance;
/* Define SpaceWire time code reception tolerance, 0-31 */
80
unsigned
char
tid;
/* Define CUC P-Field time code identification, 1 = Level 1, 2 = Level 2 */
81
unsigned
char
ctf;
/* If 1 check time code flags to be all zero */
82
unsigned
char
cp;
/* If 1 check P-Field time code id against tid */
83
84
unsigned
char
txen;
/* Enable SpaceWire time code transmission */
85
unsigned
char
rxen;
/* Enable SpaceWire time code reception */
86
unsigned
char
pktsyncen;
/* Enable SpaceWire time CUC packet sync */
87
unsigned
char
pktiniten;
/* Enable SpaceWire time CUC packet init */
88
unsigned
char
pktrxen;
/* Enable SpaceWire time CUC packet reception */
89
90
unsigned
char
dla;
/* SpaceWire destination logical address */
91
unsigned
char
dla_mask;
/* SpaceWire destination logical address mask */
92
unsigned
char
pid;
/* SpaceWire protocol ID */
93
94
unsigned
int
offset;
/* Packet reception offset */
95
96
97
/* SPWCUC Statistics gathered by driver */
98
struct
spwcuc_stats
99
100
/* IRQ Stats */
101
unsigned
int
nirqs;
102
unsigned
int
tick_tx;
103
unsigned
int
tick_tx_wrap;
104
unsigned
int
tick_rx;
105
unsigned
int
tick_rx_wrap;
106
unsigned
int
tick_rx_error;
107
unsigned
int
tolerr;
108
unsigned
int
sync;
109
unsigned
int
syncerr;
110
unsigned
int
wrap;
111
unsigned
int
wraperr;
112
unsigned
int
pkt_rx;
113
unsigned
int
pkt_err;
114
unsigned
int
pkt_init;
115
116
117
/* Function ISR callback prototype
118
119
* pimr - PIMR/PIR register of the SPWCUC core read by ISR
120
* data - Custom data provided by user
121
122
typedef
void (*spwcuc_isr_t)(
unsigned
int
pimr,
void
*data);
123
124
/* Open a SPWCUC device by minor number. A SPWCUC device can only by opened
125
* once. The handle returned must be used as the input parameter 'spwcuc' in
126
* the rest of the calls in the function interface.
127
128
extern
void
*spwcuc_open(
int
minor);
129
130
/* Close a previously opened SPWCUC device */
131
extern
void
spwcuc_close(
void
*spwcuc);
132
133
/* Reset SPWCUC Core */
134
extern
int
spwcuc_reset(
void
*spwcuc);
135
136
/* Enable Interrupts at Interrupt controller */
137
extern
void
spwcuc_int_enable(
void
*spwcuc);
138
139
/* Disable Interrupts at Interrupt controller */
140
extern
void
spwcuc_int_disable(
void
*spwcuc);
141
142
/* Clear Statistics gathered by the driver */
143
extern
void
spwcuc_clr_stats(
void
*spwcuc);
144
145
/* Get Statistics gathered by the driver. The statistics are stored into
146
* the location pointed to by 'stats'.
147
148
extern
void
spwcuc_get_stats(
void
*spwcuc,
struct
spwcuc_stats
*stats);
149
150
/* Register an Interrupt handler and custom data, the function call is
151
* removed by setting func to NULL.
152
153
* The driver's interrupt handler is installed on open(), however the user
154
* callback called from the driver's ISR is installed using this function.
155
156
extern
void
spwcuc_int_register(
void
*spwcuc, spwcuc_isr_t func,
void
*data);
157
158
/* Configure the spwcuc core. The configuration is taken from the data
159
* structure pointed to by 'cfg'. See data structure spwcuc_cfg fields.
160
161
extern
void
spwcuc_config(
void
*spwcuc,
struct
spwcuc_cfg
*cfg);
162
163
/* Return elapsed coarse time */
164
extern
unsigned
int
spwcuc_get_et_coarse(
void
*spwcuc);
165
166
/* Return elapsed fine time */
167
extern
unsigned
int
spwcuc_get_et_fine(
void
*spwcuc);
168
169
/* Return elapsed time (coarse and fine) 64-bit value */
170
extern
unsigned
long
long
spwcuc_get_et(
void
*spwcuc);
171
172
/* Return next elapsed coarse time (for use when sending SpW time packet) */
173
extern
unsigned
int
spwcuc_get_next_et_coarse(
void
*spwcuc);
174
175
/* Return next elapsed fine time (for use when sending SpW time packet) */
176
extern
unsigned
int
spwcuc_get_next_et_fine(
void
*spwcuc);
177
178
/* Return next elapsed time (for use when sending SpW time packet) */
179
extern
unsigned
long
long
spwcuc_get_next_et(
void
*spwcuc);
180
181
/* Force/Set the elapsed time (coarse 32-bit and fine 24-bit) by writing the
182
* T-Field Time Packet Registers then the FORCE bit.
183
184
extern
void
spwcuc_force_et(
void
*spwcuc,
unsigned
long
long
time);
185
186
/* Return received (from time packet) elapsed coarse time */
187
extern
unsigned
int
spwcuc_get_tp_et_coarse(
void
*spwcuc);
188
189
/* Return received (from time packet) elapsed fine time */
190
extern
unsigned
int
spwcuc_get_tp_et_fine(
void
*spwcuc);
191
192
/* Return received (from time packet) elapsed time (coarse and fine) */
193
extern
unsigned
long
long
spwcuc_get_tp_et(
void
*spwcuc);
194
195
/* Clear interrupts */
196
extern
void
spwcuc_clear_irqs(
void
*spwcuc,
int
irqs);
197
198
/* Enable interrupts */
199
extern
void
spwcuc_enable_irqs(
void
*spwcuc,
int
irqs);
200
201
/* Get Register */
202
extern
struct
spwcuc_regs
*spwcuc_get_regs(
void
*spwcuc);
203
204
/* Register the SPWCUC Driver to the Driver Manager */
205
extern
void
spwcuc_register(
void
206
207
#endif
spwcuc_cfg
Definition
spwcuc.h:75
spwcuc_regs
Definition
spwcuc.h:49
spwcuc_stats
Definition
spwcuc.h:98
