RTEMS 6.3
spidev.h
2
10
11/*
12 * Copyright (c) 2016 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef _UAPI_LINUX_SPI_H
37#define _UAPI_LINUX_SPI_H
38
39#include <sys/ioccom.h>
40#include <stddef.h>
41#include <stdint.h>
42
56
62
66#define SPI_CPHA 0x01
67
71#define SPI_CPOL 0x02
72
77#define SPI_MODE_0 0
78
83#define SPI_MODE_1 SPI_CPHA
84
89#define SPI_MODE_2 SPI_CPOL
90
95#define SPI_MODE_3 (SPI_CPOL | SPI_CPHA)
96
101#define SPI_CS_HIGH 0x04
102
107#define SPI_LSB_FIRST 0x08
108
113#define SPI_3WIRE 0x10
114
118#define SPI_LOOP 0x20
119
124#define SPI_NO_CS 0x40
125
129#define SPI_READY 0x80
130
134#define SPI_TX_DUAL 0x100
135
139#define SPI_TX_QUAD 0x200
140
144#define SPI_RX_DUAL 0x400
145
149#define SPI_RX_QUAD 0x800
150
152
153#define SPI_IOC_MAGIC 's'
154
162 void *rx_buf;
163
167 const void *tx_buf;
168
172 size_t len;
173
177 uint32_t speed_hz;
178
183 uint16_t delay_usecs;
184
189
194 uint8_t cs_change;
195
199 uint8_t rx_nbits;
200
204 uint8_t tx_nbits;
205
210 uint32_t mode;
211
215 uint8_t cs;
216};
217
221#define SPI_MSGSIZE(n) \
222 (((n) * sizeof(struct spi_ioc_transfer) < IOCPARM_MAX) ? \
223 (n) * sizeof(struct spi_ioc_transfer) : 0)
224
228#define SPI_IOC_MESSAGE(n) _IOW(SPI_IOC_MAGIC, 0, char[SPI_MSGSIZE(n)])
229
233#define SPI_IOC_RD_MODE _IOR(SPI_IOC_MAGIC, 1, uint8_t)
234
239#define SPI_IOC_WR_MODE _IOW(SPI_IOC_MAGIC, 1, uint8_t)
240
244#define SPI_IOC_RD_LSB_FIRST _IOR(SPI_IOC_MAGIC, 2, uint8_t)
245
249#define SPI_IOC_WR_LSB_FIRST _IOW(SPI_IOC_MAGIC, 2, uint8_t)
250
254#define SPI_IOC_RD_BITS_PER_WORD _IOR(SPI_IOC_MAGIC, 3, uint8_t)
255
259#define SPI_IOC_WR_BITS_PER_WORD _IOW(SPI_IOC_MAGIC, 3, uint8_t)
260
264#define SPI_IOC_RD_MAX_SPEED_HZ _IOR(SPI_IOC_MAGIC, 4, uint32_t)
265
269#define SPI_IOC_WR_MAX_SPEED_HZ _IOW(SPI_IOC_MAGIC, 4, uint32_t)
270
274#define SPI_IOC_RD_MODE32 _IOR(SPI_IOC_MAGIC, 5, uint32_t)
275
279#define SPI_IOC_WR_MODE32 _IOW(SPI_IOC_MAGIC, 5, uint32_t)
280
281#endif /* _UAPI_LINUX_SPI_H */
uint8_t cs_change
If true, device is deselected after transfer ended and before a new transfer is started.
Definition spidev.h:194
uint32_t speed_hz
Sets the bit-rate of the device.
Definition spidev.h:177
void * rx_buf
Buffer for receive data.
Definition spidev.h:162
uint8_t rx_nbits
Amount of bits that are used for reading.
Definition spidev.h:199
uint8_t bits_per_word
Sets the device wordsize.
Definition spidev.h:188
Sets the delay after a transfer before the chip select status is changed and the next transfer is tri...
Definition spidev.h:183
uint8_t tx_nbits
Amount of bits that are used for writing.
Definition spidev.h:204
uint8_t cs
Indicates which device is currently used.
Definition spidev.h:215
size_t len
Length of receive and transmit buffers in bytes.
Definition spidev.h:172
const void * tx_buf
Buffer for transmit data.
Definition spidev.h:167
uint32_t mode
Sets one of the possible modes that can be used for SPI transfers (dependent on clock phase and polar...
Definition spidev.h:210
SPI transfer message.
Definition spidev.h:158
