void | simple_out_32 (uint32_t base, uint32_t addr, uint32_t val) |
void | simple_out_le32 (uint32_t base, uint32_t addr, uint32_t val) |
uint8_t | simple_in_8 (uint32_t base, uint32_t addr) |
int16_t | simple_in_le16 (uint32_t base, uint32_t addr) |
int16_t | simple_in_16 (uint32_t base, uint32_t addr) |
uint32_t | simple_in_le32 (uint32_t base, uint32_t addr) |
uint32_t | simple_in_32 (uint32_t base, uint32_t addr) |
void | simple_out_8 (uint32_t base, uint32_t addr, uint8_t val) |
void | simple_out_le16 (uint32_t base, uint32_t addr, uint16_t val) |
void | simple_out_16 (uint32_t base, uint32_t addr, uint16_t val) |
This file contains the code to do simple memory and io accesses.
