RTEMS
6.3
Toggle main menu visibility
include
posix
sigset.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
* COPYRIGHT (c) 1989-2011.
14
* On-Line Applications Research Corporation (OAR).
15
16
17
* modification, are permitted provided that the following conditions
18
* are met:
19
* 1. Redistributions of source code must retain the above copyright
20
* notice, this list of conditions and the following disclaimer.
21
* 2. Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in the
23
* documentation and/or other materials provided with the distribution.
24
25
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
* POSSIBILITY OF SUCH DAMAGE.
36
37
38
#ifndef _RTEMS_POSIX_SIGSET_H
39
#define _RTEMS_POSIX_SIGSET_H
40
41
#include <stdbool.h>
42
#include <signal.h>
43
44
45
* Currently 32 signals numbered 1-32 are defined
46
47
48
#define SIGNAL_EMPTY_MASK 0x00000000L
49
#define SIGNAL_ALL_MASK 0xffffffffL
50
51
static
inline
sigset_t signo_to_mask(
52
uint32_t sig
53
54
55
return
1u << (sig - 1);
56
57
58
static
inline
bool
is_valid_signo(
59
int
signo
60
61
62
return
((signo) >= 1 && (signo) <= 32 );
63
64
65
#endif
