34#ifndef _RTEMS_POSIX_SHM_H
35#define _RTEMS_POSIX_SHM_H
162#define POSIX_SHM_INFORMATION_DEFINE( max ) \
163 OBJECTS_INFORMATION_DEFINE( \
166 OBJECTS_POSIX_SHMS, \
int _POSIX_Shm_Object_create_from_workspace(POSIX_Shm_Object *shm_obj, size_t size)
object_create operation for shm objects stored in RTEMS Workspace.
Definition shmwkspace.c:41
int _POSIX_Shm_Object_read_from_workspace(POSIX_Shm_Object *shm_obj, void *buf, size_t count)
object_read operation for shm objects stored in RTEMS Workspace.
Definition shmwkspace.c:84
int _POSIX_Shm_Object_resize_from_heap(POSIX_Shm_Object *shm_obj, size_t size)
object_resize operation for shm objects stored in C program heap.
Definition shmheap.c:66
void * _POSIX_Shm_Object_mmap_from_heap(POSIX_Shm_Object *shm_obj, size_t len, int prot, off_t off)
object_mmap operation for shm objects stored in C program heap.
Definition shmheap.c:113
int _POSIX_Shm_Object_read_from_heap(POSIX_Shm_Object *shm_obj, void *buf, size_t count)
object_read operation for shm objects stored in C program heap.
Definition shmheap.c:94
int _POSIX_Shm_Object_delete_from_workspace(POSIX_Shm_Object *shm_obj)
object_delete operation for shm objects stored in RTEMS Workspace.
Definition shmwkspace.c:56
int _POSIX_Shm_Object_create_from_heap(POSIX_Shm_Object *shm_obj, size_t size)
object_create operation for shm objects stored in C program heap.
Definition shmheap.c:41
int _POSIX_Shm_Object_resize_from_workspace(POSIX_Shm_Object *shm_obj, size_t size)
object_resize operation for shm objects stored in RTEMS Workspace.
Definition shmwkspace.c:66
int _POSIX_Shm_Object_delete_from_heap(POSIX_Shm_Object *shm_obj)
object_delete operation for shm objects stored in C program heap.
Definition shmheap.c:56
Objects_Information _POSIX_Shm_Information
The POSIX Shared Memory objects information.
void * _POSIX_Shm_Object_mmap_from_workspace(POSIX_Shm_Object *shm_obj, size_t len, int prot, off_t off)
object_mmap operation for shm objects stored in RTEMS Workspace.
Definition shmwkspace.c:102
This header file provides data structures used by the implementation and the Application Configuratio...
Definition objectdata.h:61
Control for a POSIX Shared Memory Object.
Definition shm.h:130
Operations on POSIX Shared Memory Objects.
Definition shm.h:81
int(*) object_delete(POSIX_Shm_Object *shm_obj)
Deletes the shm_obj.
Definition shm.h:107
int(*) object_read(POSIX_Shm_Object *shm_obj, void *buf, size_t count)
Copies up to @count bytes of the shm_obj data into buf.
Definition shm.h:114
int(*) object_resize(POSIX_Shm_Object *shm_obj, size_t size)
Changes the shm_obj size to size.
Definition shm.h:98
int(*) object_create(POSIX_Shm_Object *shm_obj, size_t size)
Allocates a new shm_obj with initial size.
Definition shm.h:89
Encapsulation for the storage and manipulation of shm objects.
Definition shm.h:60
size_t size
The number of bytes allocated to the object. A size of 0 with a handle of NULL means no object is all...
Definition shm.h:70
void * handle
The handle is private for finding object storage.
Definition shm.h:64
const POSIX_Shm_Object_operations * ops
Implementation-specific operations on shm objects.
Definition shm.h:75
This header file provides interfaces of the Thread Queue Handler which are used by the implementation...
