RTEMS
6.3
Toggle main menu visibility
bsps
arm
fvp
include
bsp
semihosting.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2020 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef _BSPS_ARM_FVP_SEMIHOSTING_H
37
#define _BSPS_ARM_FVP_SEMIHOSTING_H
38
39
#include <stdint.h>
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
44
50
51
#define SYS_CLOCK 0x10
52
#define SYS_CLOSE 0x02
53
#define SYS_ELAPSED 0x30
54
#define SYS_ERRNO 0x13
55
#define SYS_EXIT 0x18
56
#define SYS_EXIT_EXTENDED 0x20
57
#define SYS_FLEN 0x0c
58
#define SYS_GET_CMDLINE 0x15
59
#define SYS_HEAPINFO 0x16
60
#define SYS_ISERROR 0x08
61
#define SYS_ISTTY 0x09
62
#define SYS_OPEN 0x01
63
#define SYS_READ 0x06
64
#define SYS_READC 0x07
65
#define SYS_REMOVE 0x0e
66
#define SYS_RENAME 0x0f
67
#define SYS_SEEK 0x0a
68
#define SYS_SYSTEM 0x12
69
#define SYS_TICKFREQ 0x31
70
#define SYS_TIME 0x11
71
#define SYS_TMPNAM 0x0d
72
#define SYS_WRITE 0x05
73
#define SYS_WRITEC 0x03
74
#define SYS_WRITE0 0x04
75
76
#define ADP_Stopped_BranchThroughZero 0x20000
77
#define ADP_Stopped_UndefinedInstr 0x20001
78
#define ADP_Stopped_SoftwareInterrupt 0x20002
79
#define ADP_Stopped_PrefetchAbort 0x20003
80
#define ADP_Stopped_DataAbort 0x20004
81
#define ADP_Stopped_AddressException 0x20005
82
#define ADP_Stopped_IRQ 0x20006
83
#define ADP_Stopped_FIQ 0x20007
84
#define ADP_Stopped_BreakPoint 0x20020
85
#define ADP_Stopped_WatchPoint 0x20021
86
#define ADP_Stopped_StepComplete 0x20022
87
#define ADP_Stopped_RunTimeErrorUnknown 0x20023
88
#define ADP_Stopped_InternalError 0x20024
89
#define ADP_Stopped_UserInterruption 0x20025
90
#define ADP_Stopped_ApplicationExit 0x20026
91
#define ADP_Stopped_StackOverflow 0x20027
92
#define ADP_Stopped_DivisionByZero 0x20028
93
#define ADP_Stopped_OSSpecific 0x20029
94
95
static
inline
uintptr_t arm_fvp_semihosting_call(
96
uintptr_t op,
97
uintptr_t params
98
99
100
register
uintptr_t op_and_return_reg __asm__(
"r0"
101
register
uintptr_t params_reg __asm__(
"r1"
102
103
op_and_return_reg = op;
104
params_reg = params;
105
106
__asm__
volatile
107
#ifdef __thumb__
108
"svc #0xab"
109
#else
110
"svc #0x123456"
111
#endif
112
"=r"
(op_and_return_reg)
113
"0"
(op_and_return_reg),
"r"
(params_reg)
114
"memory"
115
116
117
return
op_and_return_reg;
118
119
120
void
arm_fvp_console_output(
char
c );
121
122
int
arm_fvp_console_input(
void
123
125
126
#ifdef __cplusplus
127
128
#endif
129
130
#endif
/* _BSPS_ARM_FVP_SEMIHOSTING_H */
