RTEMS
6.3
Toggle main menu visibility
dev
serial
sc16is752-regs.h
1
2
* Copyright (c) 2016 embedded brains GmbH & Co. KG
3
4
* The license and distribution terms for this file may be
5
* found in the file LICENSE in this distribution or at
6
* http://www.rtems.org/license/LICENSE.
7
8
9
#ifndef LIBBSP_ARM_ATSAM_SC16IS752_H
10
#define LIBBSP_ARM_ATSAM_SC16IS752_H
11
12
#ifdef __cplusplus
13
extern
"C"
14
#endif
/* __cplusplus */
15
16
/* General register set */
17
#define SC16IS752_RHR 0x0
18
#define SC16IS752_THR 0x0
19
#define SC16IS752_IER 0x1
20
#define SC16IS752_FCR 0x2
21
#define SC16IS752_IIR 0x2
22
#define SC16IS752_LCR 0x3
23
#define SC16IS752_MCR 0x4
24
#define SC16IS752_LSR 0x5
25
#define SC16IS752_MSR 0x6
26
#define SC16IS752_TCR 0x6
27
#define SC16IS752_SPR 0x7
28
#define SC16IS752_TLR 0x7
29
#define SC16IS752_TXLVL 0x8
30
#define SC16IS752_RXLVL 0x9
31
#define SC16IS752_IODIR 0xA
32
#define SC16IS752_IOSTATE 0xB
33
#define SC16IS752_IOINTENA 0xC
34
#define SC16IS752_IOCONTROL 0xE
35
#define SC16IS752_EFCR 0xF
36
37
/* Special register set */
38
#define SC16IS752_DLL 0x0
39
#define SC16IS752_DLH 0x1
40
41
/* Enhanced register set */
42
#define SC16IS752_EFR 0x2
43
#define SC16IS752_XON1 0x4
44
#define SC16IS752_XON2 0x5
45
#define SC16IS752_XOFF1 0x6
46
#define SC16IS752_XOFF2 0x7
47
48
/* FCR */
49
#define SC16IS752_FCR_FIFO_EN 0x01
50
#define SC16IS752_FCR_RX_FIFO_RST 0x02
51
#define SC16IS752_FCR_TX_FIFO_RST 0x04
52
#define SC16IS752_FCR_TX_FIFO_TRG_8 0x00
53
#define SC16IS752_FCR_TX_FIFO_TRG_16 0x10
54
#define SC16IS752_FCR_TX_FIFO_TRG_32 0x20
55
#define SC16IS752_FCR_TX_FIFO_TRG_56 0x30
56
#define SC16IS752_FCR_RX_FIFO_TRG_8 0x00
57
#define SC16IS752_FCR_RX_FIFO_TRG_16 0x40
58
#define SC16IS752_FCR_RX_FIFO_TRG_56 0x80
59
#define SC16IS752_FCR_RX_FIFO_TRG_60 0xc0
60
61
/* EFCR */
62
#define SC16IS752_EFCR_RS485_ENABLE (1u << 0)
63
#define SC16IS752_EFCR_RX_DISABLE (1u << 1)
64
#define SC16IS752_EFCR_TX_DISABLE (1u << 2)
65
#define SC16IS752_EFCR_RTSCON (1u << 4)
66
#define SC16IS752_EFCR_RTSINVER (1u << 5)
67
68
/* IER */
69
#define SC16IS752_IER_RHR (1u << 0)
70
#define SC16IS752_IER_THR (1u << 1)
71
#define SC16IS752_IER_RECEIVE_LINE_STATUS (1u << 2)
72
#define SC16IS752_IER_MODEM_STATUS (1u << 3)
73
#define SC16IS752_IER_SLEEP_MODE (1u << 4)
74
#define SC16IS752_IER_XOFF (1u << 5)
75
#define SC16IS752_IER_RTS (1u << 6)
76
#define SC16IS752_IER_CTS (1u << 7)
77
78
/* IIR */
79
#define SC16IS752_IIR_TX_INTERRUPT (1u << 1)
80
#define SC16IS752_IIR_RX_INTERRUPT (1u << 2)
81
82
/* LCR */
83
#define SC16IS752_LCR_CHRL_5_BIT (0u << 1) | (0u << 0)
84
#define SC16IS752_LCR_CHRL_6_BIT (0u << 1) | (1u << 0)
85
#define SC16IS752_LCR_CHRL_7_BIT (1u << 1) | (0u << 0)
86
#define SC16IS752_LCR_CHRL_8_BIT (1u << 1) | (1u << 0)
87
#define SC16IS752_LCR_2_STOP_BIT (1u << 2)
88
#define SC16IS752_LCR_SET_PARITY (1u << 3)
89
#define SC16IS752_LCR_EVEN_PARITY (1u << 4)
90
#define SC16IS752_LCR_BREAK (1u << 5)
91
#define SC16IS752_LCR_ENABLE_DIVISOR (1u << 7)
92
93
/* LSR */
94
#define SC16IS752_LSR_TXEMPTY (1u << 5)
95
#define SC16IS752_LSR_RXRDY (1u << 0)
96
#define SC16IS752_LSR_ERROR_BITS (7u << 2)
97
98
/* MCR */
99
#define SC16IS752_MCR_DTR (1u << 0)
100
#define SC16IS752_MCR_RTS (1u << 1)
101
#define SC16IS752_MCR_TCR_TLR (1u << 2)
102
#define SC16IS752_MCR_LOOPBACK (1u << 4)
103
#define SC16IS752_MCR_XON_ANY (1u << 5)
104
#define SC16IS752_MCR_IRDA_ENABLE (1u << 6)
105
#define SC16IS752_MCR_PRESCALE_NEEDED (1u << 7)
106
107
/* MSR */
108
#define SC16IS752_MSR_dCTS (1u << 0)
109
#define SC16IS752_MSR_dDSR (1u << 1)
110
#define SC16IS752_MSR_dRI (1u << 2)
111
#define SC16IS752_MSR_dCD (1u << 3)
112
#define SC16IS752_MSR_CTS (1u << 4)
113
#define SC16IS752_MSR_DSR (1u << 5)
114
#define SC16IS752_MSR_RI (1u << 6)
115
#define SC16IS752_MSR_CD (1u << 7)
116
117
/* EFR */
118
#define SC16IS752_EFR_ENHANCED_FUNC_ENABLE (1u << 4)
119
#define SC16IS752_EFR_SPECIAL_CHAR_DETECT (1u << 5)
120
#define SC16IS752_EFR_RTS_FLOW_CTRL_EN (1u << 6)
121
#define SC16IS752_EFR_CTS_FLOW_CTRL_EN (1u << 7)
122
123
/* IOCONTROL: User accessible. Therefore see sc16is752.h for the defines. */
124
125
#define SC16IS752_FIFO_DEPTH 64
126
127
#ifdef __cplusplus
128
129
#endif
/* __cplusplus */
130
131
#endif
/* LIBBSP_ARM_ATSAM_SC16IS752_H */
