RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
samv71
component
component_xdmac.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMV71_XDMAC_COMPONENT_
31
#define _SAMV71_XDMAC_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__O
uint32_t XDMAC_CIE;
43
__O
uint32_t XDMAC_CID;
44
__O
uint32_t XDMAC_CIM;
45
__I
uint32_t XDMAC_CIS;
46
__IO
uint32_t XDMAC_CSA;
47
__IO
uint32_t XDMAC_CDA;
48
__IO
uint32_t XDMAC_CNDA;
49
__IO
uint32_t XDMAC_CNDC;
50
__IO
uint32_t XDMAC_CUBC;
51
__IO
uint32_t XDMAC_CBC;
52
__IO
uint32_t XDMAC_CC;
53
__IO
uint32_t XDMAC_CDS_MSP;
54
__IO
uint32_t XDMAC_CSUS;
55
__IO
uint32_t XDMAC_CDUS;
56
__I
uint32_t Reserved1[2];
57
XdmacChid
59
#define XDMACCHID_NUMBER 24
60
typedef
struct
61
__IO
uint32_t XDMAC_GTYPE;
62
__I
uint32_t XDMAC_GCFG;
63
__IO
uint32_t XDMAC_GWAC;
64
__O
uint32_t XDMAC_GIE;
65
__O
uint32_t XDMAC_GID;
66
__I
uint32_t XDMAC_GIM;
67
__I
uint32_t XDMAC_GIS;
68
__O
uint32_t XDMAC_GE;
69
__O
uint32_t XDMAC_GD;
70
__I
uint32_t XDMAC_GS;
71
__IO
uint32_t XDMAC_GRS;
72
__IO
uint32_t XDMAC_GWS;
73
__O
uint32_t XDMAC_GRWS;
74
__O
uint32_t XDMAC_GRWR;
75
__O
uint32_t XDMAC_GSWR;
76
__I
uint32_t XDMAC_GSWS;
77
__O
uint32_t XDMAC_GSWF;
78
__I
uint32_t Reserved1[3];
79
XdmacChid
XDMAC_CHID[XDMACCHID_NUMBER];
80
__I
uint32_t Reserved2[619];
81
__IO
uint32_t
XDMAC_VERSION
82
Xdmac
83
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
84
/* -------- XDMAC_GTYPE : (XDMAC Offset: 0x00) Global Type Register -------- */
85
#define XDMAC_GTYPE_NB_CH_Pos 0
86
#define XDMAC_GTYPE_NB_CH_Msk (0x1fu << XDMAC_GTYPE_NB_CH_Pos)
87
#define XDMAC_GTYPE_NB_CH(value) ((XDMAC_GTYPE_NB_CH_Msk & ((value) << XDMAC_GTYPE_NB_CH_Pos)))
88
#define XDMAC_GTYPE_FIFO_SZ_Pos 5
89
#define XDMAC_GTYPE_FIFO_SZ_Msk (0x7ffu << XDMAC_GTYPE_FIFO_SZ_Pos)
90
#define XDMAC_GTYPE_FIFO_SZ(value) ((XDMAC_GTYPE_FIFO_SZ_Msk & ((value) << XDMAC_GTYPE_FIFO_SZ_Pos)))
91
#define XDMAC_GTYPE_NB_REQ_Pos 16
92
#define XDMAC_GTYPE_NB_REQ_Msk (0x7fu << XDMAC_GTYPE_NB_REQ_Pos)
93
#define XDMAC_GTYPE_NB_REQ(value) ((XDMAC_GTYPE_NB_REQ_Msk & ((value) << XDMAC_GTYPE_NB_REQ_Pos)))
94
/* -------- XDMAC_GCFG : (XDMAC Offset: 0x04) Global Configuration Register -------- */
95
#define XDMAC_GCFG_CGDISREG (0x1u << 0)
96
#define XDMAC_GCFG_CGDISPIPE (0x1u << 1)
97
#define XDMAC_GCFG_CGDISFIFO (0x1u << 2)
98
#define XDMAC_GCFG_CGDISIF (0x1u << 3)
99
#define XDMAC_GCFG_BXKBEN (0x1u << 8)
100
/* -------- XDMAC_GWAC : (XDMAC Offset: 0x08) Global Weighted Arbiter Configuration Register -------- */
101
#define XDMAC_GWAC_PW0_Pos 0
102
#define XDMAC_GWAC_PW0_Msk (0xfu << XDMAC_GWAC_PW0_Pos)
103
#define XDMAC_GWAC_PW0(value) ((XDMAC_GWAC_PW0_Msk & ((value) << XDMAC_GWAC_PW0_Pos)))
104
#define XDMAC_GWAC_PW1_Pos 4
105
#define XDMAC_GWAC_PW1_Msk (0xfu << XDMAC_GWAC_PW1_Pos)
106
#define XDMAC_GWAC_PW1(value) ((XDMAC_GWAC_PW1_Msk & ((value) << XDMAC_GWAC_PW1_Pos)))
107
#define XDMAC_GWAC_PW2_Pos 8
108
#define XDMAC_GWAC_PW2_Msk (0xfu << XDMAC_GWAC_PW2_Pos)
109
#define XDMAC_GWAC_PW2(value) ((XDMAC_GWAC_PW2_Msk & ((value) << XDMAC_GWAC_PW2_Pos)))
110
#define XDMAC_GWAC_PW3_Pos 12
111
#define XDMAC_GWAC_PW3_Msk (0xfu << XDMAC_GWAC_PW3_Pos)
112
#define XDMAC_GWAC_PW3(value) ((XDMAC_GWAC_PW3_Msk & ((value) << XDMAC_GWAC_PW3_Pos)))
113
/* -------- XDMAC_GIE : (XDMAC Offset: 0x0C) Global Interrupt Enable Register -------- */
114
#define XDMAC_GIE_IE0 (0x1u << 0)
115
#define XDMAC_GIE_IE1 (0x1u << 1)
116
#define XDMAC_GIE_IE2 (0x1u << 2)
117
#define XDMAC_GIE_IE3 (0x1u << 3)
118
#define XDMAC_GIE_IE4 (0x1u << 4)
119
#define XDMAC_GIE_IE5 (0x1u << 5)
120
#define XDMAC_GIE_IE6 (0x1u << 6)
121
#define XDMAC_GIE_IE7 (0x1u << 7)
122
#define XDMAC_GIE_IE8 (0x1u << 8)
123
#define XDMAC_GIE_IE9 (0x1u << 9)
124
#define XDMAC_GIE_IE10 (0x1u << 10)
125
#define XDMAC_GIE_IE11 (0x1u << 11)
126
#define XDMAC_GIE_IE12 (0x1u << 12)
127
#define XDMAC_GIE_IE13 (0x1u << 13)
128
#define XDMAC_GIE_IE14 (0x1u << 14)
129
#define XDMAC_GIE_IE15 (0x1u << 15)
130
#define XDMAC_GIE_IE16 (0x1u << 16)
131
#define XDMAC_GIE_IE17 (0x1u << 17)
132
#define XDMAC_GIE_IE18 (0x1u << 18)
133
#define XDMAC_GIE_IE19 (0x1u << 19)
134
#define XDMAC_GIE_IE20 (0x1u << 20)
135
#define XDMAC_GIE_IE21 (0x1u << 21)
136
#define XDMAC_GIE_IE22 (0x1u << 22)
137
#define XDMAC_GIE_IE23 (0x1u << 23)
138
/* -------- XDMAC_GID : (XDMAC Offset: 0x10) Global Interrupt Disable Register -------- */
139
#define XDMAC_GID_ID0 (0x1u << 0)
140
#define XDMAC_GID_ID1 (0x1u << 1)
141
#define XDMAC_GID_ID2 (0x1u << 2)
142
#define XDMAC_GID_ID3 (0x1u << 3)
143
#define XDMAC_GID_ID4 (0x1u << 4)
144
#define XDMAC_GID_ID5 (0x1u << 5)
145
#define XDMAC_GID_ID6 (0x1u << 6)
146
#define XDMAC_GID_ID7 (0x1u << 7)
147
#define XDMAC_GID_ID8 (0x1u << 8)
148
#define XDMAC_GID_ID9 (0x1u << 9)
149
#define XDMAC_GID_ID10 (0x1u << 10)
150
#define XDMAC_GID_ID11 (0x1u << 11)
151
#define XDMAC_GID_ID12 (0x1u << 12)
152
#define XDMAC_GID_ID13 (0x1u << 13)
153
#define XDMAC_GID_ID14 (0x1u << 14)
154
#define XDMAC_GID_ID15 (0x1u << 15)
155
#define XDMAC_GID_ID16 (0x1u << 16)
156
#define XDMAC_GID_ID17 (0x1u << 17)
157
#define XDMAC_GID_ID18 (0x1u << 18)
158
#define XDMAC_GID_ID19 (0x1u << 19)
159
#define XDMAC_GID_ID20 (0x1u << 20)
160
#define XDMAC_GID_ID21 (0x1u << 21)
161
#define XDMAC_GID_ID22 (0x1u << 22)
162
#define XDMAC_GID_ID23 (0x1u << 23)
163
/* -------- XDMAC_GIM : (XDMAC Offset: 0x14) Global Interrupt Mask Register -------- */
164
#define XDMAC_GIM_IM0 (0x1u << 0)
165
#define XDMAC_GIM_IM1 (0x1u << 1)
166
#define XDMAC_GIM_IM2 (0x1u << 2)
167
#define XDMAC_GIM_IM3 (0x1u << 3)
168
#define XDMAC_GIM_IM4 (0x1u << 4)
169
#define XDMAC_GIM_IM5 (0x1u << 5)
170
#define XDMAC_GIM_IM6 (0x1u << 6)
171
#define XDMAC_GIM_IM7 (0x1u << 7)
172
#define XDMAC_GIM_IM8 (0x1u << 8)
173
#define XDMAC_GIM_IM9 (0x1u << 9)
174
#define XDMAC_GIM_IM10 (0x1u << 10)
175
#define XDMAC_GIM_IM11 (0x1u << 11)
176
#define XDMAC_GIM_IM12 (0x1u << 12)
177
#define XDMAC_GIM_IM13 (0x1u << 13)
178
#define XDMAC_GIM_IM14 (0x1u << 14)
179
#define XDMAC_GIM_IM15 (0x1u << 15)
180
#define XDMAC_GIM_IM16 (0x1u << 16)
181
#define XDMAC_GIM_IM17 (0x1u << 17)
182
#define XDMAC_GIM_IM18 (0x1u << 18)
183
#define XDMAC_GIM_IM19 (0x1u << 19)
184
#define XDMAC_GIM_IM20 (0x1u << 20)
185
#define XDMAC_GIM_IM21 (0x1u << 21)
186
#define XDMAC_GIM_IM22 (0x1u << 22)
187
#define XDMAC_GIM_IM23 (0x1u << 23)
188
/* -------- XDMAC_GIS : (XDMAC Offset: 0x18) Global Interrupt Status Register -------- */
189
#define XDMAC_GIS_IS0 (0x1u << 0)
190
#define XDMAC_GIS_IS1 (0x1u << 1)
191
#define XDMAC_GIS_IS2 (0x1u << 2)
192
#define XDMAC_GIS_IS3 (0x1u << 3)
193
#define XDMAC_GIS_IS4 (0x1u << 4)
194
#define XDMAC_GIS_IS5 (0x1u << 5)
195
#define XDMAC_GIS_IS6 (0x1u << 6)
196
#define XDMAC_GIS_IS7 (0x1u << 7)
197
#define XDMAC_GIS_IS8 (0x1u << 8)
198
#define XDMAC_GIS_IS9 (0x1u << 9)
199
#define XDMAC_GIS_IS10 (0x1u << 10)
200
#define XDMAC_GIS_IS11 (0x1u << 11)
201
#define XDMAC_GIS_IS12 (0x1u << 12)
202
#define XDMAC_GIS_IS13 (0x1u << 13)
203
#define XDMAC_GIS_IS14 (0x1u << 14)
204
#define XDMAC_GIS_IS15 (0x1u << 15)
205
#define XDMAC_GIS_IS16 (0x1u << 16)
206
#define XDMAC_GIS_IS17 (0x1u << 17)
207
#define XDMAC_GIS_IS18 (0x1u << 18)
208
#define XDMAC_GIS_IS19 (0x1u << 19)
209
#define XDMAC_GIS_IS20 (0x1u << 20)
210
#define XDMAC_GIS_IS21 (0x1u << 21)
211
#define XDMAC_GIS_IS22 (0x1u << 22)
212
#define XDMAC_GIS_IS23 (0x1u << 23)
213
/* -------- XDMAC_GE : (XDMAC Offset: 0x1C) Global Channel Enable Register -------- */
214
#define XDMAC_GE_EN0 (0x1u << 0)
215
#define XDMAC_GE_EN1 (0x1u << 1)
216
#define XDMAC_GE_EN2 (0x1u << 2)
217
#define XDMAC_GE_EN3 (0x1u << 3)
218
#define XDMAC_GE_EN4 (0x1u << 4)
219
#define XDMAC_GE_EN5 (0x1u << 5)
220
#define XDMAC_GE_EN6 (0x1u << 6)
221
#define XDMAC_GE_EN7 (0x1u << 7)
222
#define XDMAC_GE_EN8 (0x1u << 8)
223
#define XDMAC_GE_EN9 (0x1u << 9)
224
#define XDMAC_GE_EN10 (0x1u << 10)
225
#define XDMAC_GE_EN11 (0x1u << 11)
226
#define XDMAC_GE_EN12 (0x1u << 12)
227
#define XDMAC_GE_EN13 (0x1u << 13)
228
#define XDMAC_GE_EN14 (0x1u << 14)
229
#define XDMAC_GE_EN15 (0x1u << 15)
230
#define XDMAC_GE_EN16 (0x1u << 16)
231
#define XDMAC_GE_EN17 (0x1u << 17)
232
#define XDMAC_GE_EN18 (0x1u << 18)
233
#define XDMAC_GE_EN19 (0x1u << 19)
234
#define XDMAC_GE_EN20 (0x1u << 20)
235
#define XDMAC_GE_EN21 (0x1u << 21)
236
#define XDMAC_GE_EN22 (0x1u << 22)
237
#define XDMAC_GE_EN23 (0x1u << 23)
238
/* -------- XDMAC_GD : (XDMAC Offset: 0x20) Global Channel Disable Register -------- */
239
#define XDMAC_GD_DI0 (0x1u << 0)
240
#define XDMAC_GD_DI1 (0x1u << 1)
241
#define XDMAC_GD_DI2 (0x1u << 2)
242
#define XDMAC_GD_DI3 (0x1u << 3)
243
#define XDMAC_GD_DI4 (0x1u << 4)
244
#define XDMAC_GD_DI5 (0x1u << 5)
245
#define XDMAC_GD_DI6 (0x1u << 6)
246
#define XDMAC_GD_DI7 (0x1u << 7)
247
#define XDMAC_GD_DI8 (0x1u << 8)
248
#define XDMAC_GD_DI9 (0x1u << 9)
249
#define XDMAC_GD_DI10 (0x1u << 10)
250
#define XDMAC_GD_DI11 (0x1u << 11)
251
#define XDMAC_GD_DI12 (0x1u << 12)
252
#define XDMAC_GD_DI13 (0x1u << 13)
253
#define XDMAC_GD_DI14 (0x1u << 14)
254
#define XDMAC_GD_DI15 (0x1u << 15)
255
#define XDMAC_GD_DI16 (0x1u << 16)
256
#define XDMAC_GD_DI17 (0x1u << 17)
257
#define XDMAC_GD_DI18 (0x1u << 18)
258
#define XDMAC_GD_DI19 (0x1u << 19)
259
#define XDMAC_GD_DI20 (0x1u << 20)
260
#define XDMAC_GD_DI21 (0x1u << 21)
261
#define XDMAC_GD_DI22 (0x1u << 22)
262
#define XDMAC_GD_DI23 (0x1u << 23)
263
/* -------- XDMAC_GS : (XDMAC Offset: 0x24) Global Channel Status Register -------- */
264
#define XDMAC_GS_ST0 (0x1u << 0)
265
#define XDMAC_GS_ST1 (0x1u << 1)
266
#define XDMAC_GS_ST2 (0x1u << 2)
267
#define XDMAC_GS_ST3 (0x1u << 3)
268
#define XDMAC_GS_ST4 (0x1u << 4)
269
#define XDMAC_GS_ST5 (0x1u << 5)
270
#define XDMAC_GS_ST6 (0x1u << 6)
271
#define XDMAC_GS_ST7 (0x1u << 7)
272
#define XDMAC_GS_ST8 (0x1u << 8)
273
#define XDMAC_GS_ST9 (0x1u << 9)
274
#define XDMAC_GS_ST10 (0x1u << 10)
275
#define XDMAC_GS_ST11 (0x1u << 11)
276
#define XDMAC_GS_ST12 (0x1u << 12)
277
#define XDMAC_GS_ST13 (0x1u << 13)
278
#define XDMAC_GS_ST14 (0x1u << 14)
279
#define XDMAC_GS_ST15 (0x1u << 15)
280
#define XDMAC_GS_ST16 (0x1u << 16)
281
#define XDMAC_GS_ST17 (0x1u << 17)
282
#define XDMAC_GS_ST18 (0x1u << 18)
283
#define XDMAC_GS_ST19 (0x1u << 19)
284
#define XDMAC_GS_ST20 (0x1u << 20)
285
#define XDMAC_GS_ST21 (0x1u << 21)
286
#define XDMAC_GS_ST22 (0x1u << 22)
287
#define XDMAC_GS_ST23 (0x1u << 23)
288
/* -------- XDMAC_GRS : (XDMAC Offset: 0x28) Global Channel Read Suspend Register -------- */
289
#define XDMAC_GRS_RS0 (0x1u << 0)
290
#define XDMAC_GRS_RS1 (0x1u << 1)
291
#define XDMAC_GRS_RS2 (0x1u << 2)
292
#define XDMAC_GRS_RS3 (0x1u << 3)
293
#define XDMAC_GRS_RS4 (0x1u << 4)
294
#define XDMAC_GRS_RS5 (0x1u << 5)
295
#define XDMAC_GRS_RS6 (0x1u << 6)
296
#define XDMAC_GRS_RS7 (0x1u << 7)
297
#define XDMAC_GRS_RS8 (0x1u << 8)
298
#define XDMAC_GRS_RS9 (0x1u << 9)
299
#define XDMAC_GRS_RS10 (0x1u << 10)
300
#define XDMAC_GRS_RS11 (0x1u << 11)
301
#define XDMAC_GRS_RS12 (0x1u << 12)
302
#define XDMAC_GRS_RS13 (0x1u << 13)
303
#define XDMAC_GRS_RS14 (0x1u << 14)
304
#define XDMAC_GRS_RS15 (0x1u << 15)
305
#define XDMAC_GRS_RS16 (0x1u << 16)
306
#define XDMAC_GRS_RS17 (0x1u << 17)
307
#define XDMAC_GRS_RS18 (0x1u << 18)
308
#define XDMAC_GRS_RS19 (0x1u << 19)
309
#define XDMAC_GRS_RS20 (0x1u << 20)
310
#define XDMAC_GRS_RS21 (0x1u << 21)
311
#define XDMAC_GRS_RS22 (0x1u << 22)
312
#define XDMAC_GRS_RS23 (0x1u << 23)
313
/* -------- XDMAC_GWS : (XDMAC Offset: 0x2C) Global Channel Write Suspend Register -------- */
314
#define XDMAC_GWS_WS0 (0x1u << 0)
315
#define XDMAC_GWS_WS1 (0x1u << 1)
316
#define XDMAC_GWS_WS2 (0x1u << 2)
317
#define XDMAC_GWS_WS3 (0x1u << 3)
318
#define XDMAC_GWS_WS4 (0x1u << 4)
319
#define XDMAC_GWS_WS5 (0x1u << 5)
320
#define XDMAC_GWS_WS6 (0x1u << 6)
321
#define XDMAC_GWS_WS7 (0x1u << 7)
322
#define XDMAC_GWS_WS8 (0x1u << 8)
323
#define XDMAC_GWS_WS9 (0x1u << 9)
324
#define XDMAC_GWS_WS10 (0x1u << 10)
325
#define XDMAC_GWS_WS11 (0x1u << 11)
326
#define XDMAC_GWS_WS12 (0x1u << 12)
327
#define XDMAC_GWS_WS13 (0x1u << 13)
328
#define XDMAC_GWS_WS14 (0x1u << 14)
329
#define XDMAC_GWS_WS15 (0x1u << 15)
330
#define XDMAC_GWS_WS16 (0x1u << 16)
331
#define XDMAC_GWS_WS17 (0x1u << 17)
332
#define XDMAC_GWS_WS18 (0x1u << 18)
333
#define XDMAC_GWS_WS19 (0x1u << 19)
334
#define XDMAC_GWS_WS20 (0x1u << 20)
335
#define XDMAC_GWS_WS21 (0x1u << 21)
336
#define XDMAC_GWS_WS22 (0x1u << 22)
337
#define XDMAC_GWS_WS23 (0x1u << 23)
338
/* -------- XDMAC_GRWS : (XDMAC Offset: 0x30) Global Channel Read Write Suspend Register -------- */
339
#define XDMAC_GRWS_RWS0 (0x1u << 0)
340
#define XDMAC_GRWS_RWS1 (0x1u << 1)
341
#define XDMAC_GRWS_RWS2 (0x1u << 2)
342
#define XDMAC_GRWS_RWS3 (0x1u << 3)
343
#define XDMAC_GRWS_RWS4 (0x1u << 4)
344
#define XDMAC_GRWS_RWS5 (0x1u << 5)
345
#define XDMAC_GRWS_RWS6 (0x1u << 6)
346
#define XDMAC_GRWS_RWS7 (0x1u << 7)
347
#define XDMAC_GRWS_RWS8 (0x1u << 8)
348
#define XDMAC_GRWS_RWS9 (0x1u << 9)
349
#define XDMAC_GRWS_RWS10 (0x1u << 10)
350
#define XDMAC_GRWS_RWS11 (0x1u << 11)
351
#define XDMAC_GRWS_RWS12 (0x1u << 12)
352
#define XDMAC_GRWS_RWS13 (0x1u << 13)
353
#define XDMAC_GRWS_RWS14 (0x1u << 14)
354
#define XDMAC_GRWS_RWS15 (0x1u << 15)
355
#define XDMAC_GRWS_RWS16 (0x1u << 16)
356
#define XDMAC_GRWS_RWS17 (0x1u << 17)
357
#define XDMAC_GRWS_RWS18 (0x1u << 18)
358
#define XDMAC_GRWS_RWS19 (0x1u << 19)
359
#define XDMAC_GRWS_RWS20 (0x1u << 20)
360
#define XDMAC_GRWS_RWS21 (0x1u << 21)
361
#define XDMAC_GRWS_RWS22 (0x1u << 22)
362
#define XDMAC_GRWS_RWS23 (0x1u << 23)
363
/* -------- XDMAC_GRWR : (XDMAC Offset: 0x34) Global Channel Read Write Resume Register -------- */
364
#define XDMAC_GRWR_RWR0 (0x1u << 0)
365
#define XDMAC_GRWR_RWR1 (0x1u << 1)
366
#define XDMAC_GRWR_RWR2 (0x1u << 2)
367
#define XDMAC_GRWR_RWR3 (0x1u << 3)
368
#define XDMAC_GRWR_RWR4 (0x1u << 4)
369
#define XDMAC_GRWR_RWR5 (0x1u << 5)
370
#define XDMAC_GRWR_RWR6 (0x1u << 6)
371
#define XDMAC_GRWR_RWR7 (0x1u << 7)
372
#define XDMAC_GRWR_RWR8 (0x1u << 8)
373
#define XDMAC_GRWR_RWR9 (0x1u << 9)
374
#define XDMAC_GRWR_RWR10 (0x1u << 10)
375
#define XDMAC_GRWR_RWR11 (0x1u << 11)
376
#define XDMAC_GRWR_RWR12 (0x1u << 12)
377
#define XDMAC_GRWR_RWR13 (0x1u << 13)
378
#define XDMAC_GRWR_RWR14 (0x1u << 14)
379
#define XDMAC_GRWR_RWR15 (0x1u << 15)
380
#define XDMAC_GRWR_RWR16 (0x1u << 16)
381
#define XDMAC_GRWR_RWR17 (0x1u << 17)
382
#define XDMAC_GRWR_RWR18 (0x1u << 18)
383
#define XDMAC_GRWR_RWR19 (0x1u << 19)
384
#define XDMAC_GRWR_RWR20 (0x1u << 20)
385
#define XDMAC_GRWR_RWR21 (0x1u << 21)
386
#define XDMAC_GRWR_RWR22 (0x1u << 22)
387
#define XDMAC_GRWR_RWR23 (0x1u << 23)
388
/* -------- XDMAC_GSWR : (XDMAC Offset: 0x38) Global Channel Software Request Register -------- */
389
#define XDMAC_GSWR_SWREQ0 (0x1u << 0)
390
#define XDMAC_GSWR_SWREQ1 (0x1u << 1)
391
#define XDMAC_GSWR_SWREQ2 (0x1u << 2)
392
#define XDMAC_GSWR_SWREQ3 (0x1u << 3)
393
#define XDMAC_GSWR_SWREQ4 (0x1u << 4)
394
#define XDMAC_GSWR_SWREQ5 (0x1u << 5)
395
#define XDMAC_GSWR_SWREQ6 (0x1u << 6)
396
#define XDMAC_GSWR_SWREQ7 (0x1u << 7)
397
#define XDMAC_GSWR_SWREQ8 (0x1u << 8)
398
#define XDMAC_GSWR_SWREQ9 (0x1u << 9)
399
#define XDMAC_GSWR_SWREQ10 (0x1u << 10)
400
#define XDMAC_GSWR_SWREQ11 (0x1u << 11)
401
#define XDMAC_GSWR_SWREQ12 (0x1u << 12)
402
#define XDMAC_GSWR_SWREQ13 (0x1u << 13)
403
#define XDMAC_GSWR_SWREQ14 (0x1u << 14)
404
#define XDMAC_GSWR_SWREQ15 (0x1u << 15)
405
#define XDMAC_GSWR_SWREQ16 (0x1u << 16)
406
#define XDMAC_GSWR_SWREQ17 (0x1u << 17)
407
#define XDMAC_GSWR_SWREQ18 (0x1u << 18)
408
#define XDMAC_GSWR_SWREQ19 (0x1u << 19)
409
#define XDMAC_GSWR_SWREQ20 (0x1u << 20)
410
#define XDMAC_GSWR_SWREQ21 (0x1u << 21)
411
#define XDMAC_GSWR_SWREQ22 (0x1u << 22)
412
#define XDMAC_GSWR_SWREQ23 (0x1u << 23)
413
/* -------- XDMAC_GSWS : (XDMAC Offset: 0x3C) Global Channel Software Request Status Register -------- */
414
#define XDMAC_GSWS_SWRS0 (0x1u << 0)
415
#define XDMAC_GSWS_SWRS1 (0x1u << 1)
416
#define XDMAC_GSWS_SWRS2 (0x1u << 2)
417
#define XDMAC_GSWS_SWRS3 (0x1u << 3)
418
#define XDMAC_GSWS_SWRS4 (0x1u << 4)
419
#define XDMAC_GSWS_SWRS5 (0x1u << 5)
420
#define XDMAC_GSWS_SWRS6 (0x1u << 6)
421
#define XDMAC_GSWS_SWRS7 (0x1u << 7)
422
#define XDMAC_GSWS_SWRS8 (0x1u << 8)
423
#define XDMAC_GSWS_SWRS9 (0x1u << 9)
424
#define XDMAC_GSWS_SWRS10 (0x1u << 10)
425
#define XDMAC_GSWS_SWRS11 (0x1u << 11)
426
#define XDMAC_GSWS_SWRS12 (0x1u << 12)
427
#define XDMAC_GSWS_SWRS13 (0x1u << 13)
428
#define XDMAC_GSWS_SWRS14 (0x1u << 14)
429
#define XDMAC_GSWS_SWRS15 (0x1u << 15)
430
#define XDMAC_GSWS_SWRS16 (0x1u << 16)
431
#define XDMAC_GSWS_SWRS17 (0x1u << 17)
432
#define XDMAC_GSWS_SWRS18 (0x1u << 18)
433
#define XDMAC_GSWS_SWRS19 (0x1u << 19)
434
#define XDMAC_GSWS_SWRS20 (0x1u << 20)
435
#define XDMAC_GSWS_SWRS21 (0x1u << 21)
436
#define XDMAC_GSWS_SWRS22 (0x1u << 22)
437
#define XDMAC_GSWS_SWRS23 (0x1u << 23)
438
/* -------- XDMAC_GSWF : (XDMAC Offset: 0x40) Global Channel Software Flush Request Register -------- */
439
#define XDMAC_GSWF_SWF0 (0x1u << 0)
440
#define XDMAC_GSWF_SWF1 (0x1u << 1)
441
#define XDMAC_GSWF_SWF2 (0x1u << 2)
442
#define XDMAC_GSWF_SWF3 (0x1u << 3)
443
#define XDMAC_GSWF_SWF4 (0x1u << 4)
444
#define XDMAC_GSWF_SWF5 (0x1u << 5)
445
#define XDMAC_GSWF_SWF6 (0x1u << 6)
446
#define XDMAC_GSWF_SWF7 (0x1u << 7)
447
#define XDMAC_GSWF_SWF8 (0x1u << 8)
448
#define XDMAC_GSWF_SWF9 (0x1u << 9)
449
#define XDMAC_GSWF_SWF10 (0x1u << 10)
450
#define XDMAC_GSWF_SWF11 (0x1u << 11)
451
#define XDMAC_GSWF_SWF12 (0x1u << 12)
452
#define XDMAC_GSWF_SWF13 (0x1u << 13)
453
#define XDMAC_GSWF_SWF14 (0x1u << 14)
454
#define XDMAC_GSWF_SWF15 (0x1u << 15)
455
#define XDMAC_GSWF_SWF16 (0x1u << 16)
456
#define XDMAC_GSWF_SWF17 (0x1u << 17)
457
#define XDMAC_GSWF_SWF18 (0x1u << 18)
458
#define XDMAC_GSWF_SWF19 (0x1u << 19)
459
#define XDMAC_GSWF_SWF20 (0x1u << 20)
460
#define XDMAC_GSWF_SWF21 (0x1u << 21)
461
#define XDMAC_GSWF_SWF22 (0x1u << 22)
462
#define XDMAC_GSWF_SWF23 (0x1u << 23)
463
/* -------- XDMAC_CIE : (XDMAC Offset: N/A) Channel Interrupt Enable Register -------- */
464
#define XDMAC_CIE_BIE (0x1u << 0)
465
#define XDMAC_CIE_LIE (0x1u << 1)
466
#define XDMAC_CIE_DIE (0x1u << 2)
467
#define XDMAC_CIE_FIE (0x1u << 3)
468
#define XDMAC_CIE_RBIE (0x1u << 4)
469
#define XDMAC_CIE_WBIE (0x1u << 5)
470
#define XDMAC_CIE_ROIE (0x1u << 6)
471
/* -------- XDMAC_CID : (XDMAC Offset: N/A) Channel Interrupt Disable Register -------- */
472
#define XDMAC_CID_BID (0x1u << 0)
473
#define XDMAC_CID_LID (0x1u << 1)
474
#define XDMAC_CID_DID (0x1u << 2)
475
#define XDMAC_CID_FID (0x1u << 3)
476
#define XDMAC_CID_RBEID (0x1u << 4)
477
#define XDMAC_CID_WBEID (0x1u << 5)
478
#define XDMAC_CID_ROID (0x1u << 6)
479
/* -------- XDMAC_CIM : (XDMAC Offset: N/A) Channel Interrupt Mask Register -------- */
480
#define XDMAC_CIM_BIM (0x1u << 0)
481
#define XDMAC_CIM_LIM (0x1u << 1)
482
#define XDMAC_CIM_DIM (0x1u << 2)
483
#define XDMAC_CIM_FIM (0x1u << 3)
484
#define XDMAC_CIM_RBEIM (0x1u << 4)
485
#define XDMAC_CIM_WBEIM (0x1u << 5)
486
#define XDMAC_CIM_ROIM (0x1u << 6)
487
/* -------- XDMAC_CIS : (XDMAC Offset: N/A) Channel Interrupt Status Register -------- */
488
#define XDMAC_CIS_BIS (0x1u << 0)
489
#define XDMAC_CIS_LIS (0x1u << 1)
490
#define XDMAC_CIS_DIS (0x1u << 2)
491
#define XDMAC_CIS_FIS (0x1u << 3)
492
#define XDMAC_CIS_RBEIS (0x1u << 4)
493
#define XDMAC_CIS_WBEIS (0x1u << 5)
494
#define XDMAC_CIS_ROIS (0x1u << 6)
495
/* -------- XDMAC_CSA : (XDMAC Offset: N/A) Channel Source Address Register -------- */
496
#define XDMAC_CSA_SA_Pos 0
497
#define XDMAC_CSA_SA_Msk (0xffffffffu << XDMAC_CSA_SA_Pos)
498
#define XDMAC_CSA_SA(value) ((XDMAC_CSA_SA_Msk & ((value) << XDMAC_CSA_SA_Pos)))
499
/* -------- XDMAC_CDA : (XDMAC Offset: N/A) Channel Destination Address Register -------- */
500
#define XDMAC_CDA_DA_Pos 0
501
#define XDMAC_CDA_DA_Msk (0xffffffffu << XDMAC_CDA_DA_Pos)
502
#define XDMAC_CDA_DA(value) ((XDMAC_CDA_DA_Msk & ((value) << XDMAC_CDA_DA_Pos)))
503
/* -------- XDMAC_CNDA : (XDMAC Offset: N/A) Channel Next Descriptor Address Register -------- */
504
#define XDMAC_CNDA_NDAIF (0x1u << 0)
505
#define XDMAC_CNDA_NDA_Pos 2
506
#define XDMAC_CNDA_NDA_Msk (0x3fffffffu << XDMAC_CNDA_NDA_Pos)
507
#define XDMAC_CNDA_NDA(value) ((XDMAC_CNDA_NDA_Msk & ((value) << XDMAC_CNDA_NDA_Pos)))
508
/* -------- XDMAC_CNDC : (XDMAC Offset: N/A) Channel Next Descriptor Control Register -------- */
509
#define XDMAC_CNDC_NDE (0x1u << 0)
510
#define XDMAC_CNDC_NDE_DSCR_FETCH_DIS (0x0u << 0)
511
#define XDMAC_CNDC_NDE_DSCR_FETCH_EN (0x1u << 0)
512
#define XDMAC_CNDC_NDSUP (0x1u << 1)
513
#define XDMAC_CNDC_NDSUP_SRC_PARAMS_UNCHANGED (0x0u << 1)
514
#define XDMAC_CNDC_NDSUP_SRC_PARAMS_UPDATED (0x1u << 1)
515
#define XDMAC_CNDC_NDDUP (0x1u << 2)
516
#define XDMAC_CNDC_NDDUP_DST_PARAMS_UNCHANGED (0x0u << 2)
517
#define XDMAC_CNDC_NDDUP_DST_PARAMS_UPDATED (0x1u << 2)
518
#define XDMAC_CNDC_NDVIEW_Pos 3
519
#define XDMAC_CNDC_NDVIEW_Msk (0x3u << XDMAC_CNDC_NDVIEW_Pos)
520
#define XDMAC_CNDC_NDVIEW(value) ((XDMAC_CNDC_NDVIEW_Msk & ((value) << XDMAC_CNDC_NDVIEW_Pos)))
521
#define XDMAC_CNDC_NDVIEW_NDV0 (0x0u << 3)
522
#define XDMAC_CNDC_NDVIEW_NDV1 (0x1u << 3)
523
#define XDMAC_CNDC_NDVIEW_NDV2 (0x2u << 3)
524
#define XDMAC_CNDC_NDVIEW_NDV3 (0x3u << 3)
525
/* -------- XDMAC_CUBC : (XDMAC Offset: N/A) Channel Microblock Control Register -------- */
526
#define XDMAC_CUBC_UBLEN_Pos 0
527
#define XDMAC_CUBC_UBLEN_Msk (0xffffffu << XDMAC_CUBC_UBLEN_Pos)
528
#define XDMAC_CUBC_UBLEN(value) ((XDMAC_CUBC_UBLEN_Msk & ((value) << XDMAC_CUBC_UBLEN_Pos)))
529
/* -------- XDMAC_CBC : (XDMAC Offset: N/A) Channel Block Control Register -------- */
530
#define XDMAC_CBC_BLEN_Pos 0
531
#define XDMAC_CBC_BLEN_Msk (0xfffu << XDMAC_CBC_BLEN_Pos)
532
#define XDMAC_CBC_BLEN(value) ((XDMAC_CBC_BLEN_Msk & ((value) << XDMAC_CBC_BLEN_Pos)))
533
/* -------- XDMAC_CC : (XDMAC Offset: N/A) Channel Configuration Register -------- */
534
#define XDMAC_CC_TYPE (0x1u << 0)
535
#define XDMAC_CC_TYPE_MEM_TRAN (0x0u << 0)
536
#define XDMAC_CC_TYPE_PER_TRAN (0x1u << 0)
537
#define XDMAC_CC_MBSIZE_Pos 1
538
#define XDMAC_CC_MBSIZE_Msk (0x3u << XDMAC_CC_MBSIZE_Pos)
539
#define XDMAC_CC_MBSIZE(value) ((XDMAC_CC_MBSIZE_Msk & ((value) << XDMAC_CC_MBSIZE_Pos)))
540
#define XDMAC_CC_MBSIZE_SINGLE (0x0u << 1)
541
#define XDMAC_CC_MBSIZE_FOUR (0x1u << 1)
542
#define XDMAC_CC_MBSIZE_EIGHT (0x2u << 1)
543
#define XDMAC_CC_MBSIZE_SIXTEEN (0x3u << 1)
544
#define XDMAC_CC_DSYNC (0x1u << 4)
545
#define XDMAC_CC_DSYNC_PER2MEM (0x0u << 4)
546
#define XDMAC_CC_DSYNC_MEM2PER (0x1u << 4)
547
#define XDMAC_CC_SWREQ (0x1u << 6)
548
#define XDMAC_CC_SWREQ_HWR_CONNECTED (0x0u << 6)
549
#define XDMAC_CC_SWREQ_SWR_CONNECTED (0x1u << 6)
550
#define XDMAC_CC_MEMSET (0x1u << 7)
551
#define XDMAC_CC_MEMSET_NORMAL_MODE (0x0u << 7)
552
#define XDMAC_CC_MEMSET_HW_MODE (0x1u << 7)
553
#define XDMAC_CC_CSIZE_Pos 8
554
#define XDMAC_CC_CSIZE_Msk (0x7u << XDMAC_CC_CSIZE_Pos)
555
#define XDMAC_CC_CSIZE(value) ((XDMAC_CC_CSIZE_Msk & ((value) << XDMAC_CC_CSIZE_Pos)))
556
#define XDMAC_CC_CSIZE_CHK_1 (0x0u << 8)
557
#define XDMAC_CC_CSIZE_CHK_2 (0x1u << 8)
558
#define XDMAC_CC_CSIZE_CHK_4 (0x2u << 8)
559
#define XDMAC_CC_CSIZE_CHK_8 (0x3u << 8)
560
#define XDMAC_CC_CSIZE_CHK_16 (0x4u << 8)
561
#define XDMAC_CC_DWIDTH_Pos 11
562
#define XDMAC_CC_DWIDTH_Msk (0x3u << XDMAC_CC_DWIDTH_Pos)
563
#define XDMAC_CC_DWIDTH(value) ((XDMAC_CC_DWIDTH_Msk & ((value) << XDMAC_CC_DWIDTH_Pos)))
564
#define XDMAC_CC_DWIDTH_BYTE (0x0u << 11)
565
#define XDMAC_CC_DWIDTH_HALFWORD (0x1u << 11)
566
#define XDMAC_CC_DWIDTH_WORD (0x2u << 11)
567
#define XDMAC_CC_SIF (0x1u << 13)
568
#define XDMAC_CC_SIF_AHB_IF0 (0x0u << 13)
569
#define XDMAC_CC_SIF_AHB_IF1 (0x1u << 13)
570
#define XDMAC_CC_DIF (0x1u << 14)
571
#define XDMAC_CC_DIF_AHB_IF0 (0x0u << 14)
572
#define XDMAC_CC_DIF_AHB_IF1 (0x1u << 14)
573
#define XDMAC_CC_SAM_Pos 16
574
#define XDMAC_CC_SAM_Msk (0x3u << XDMAC_CC_SAM_Pos)
575
#define XDMAC_CC_SAM(value) ((XDMAC_CC_SAM_Msk & ((value) << XDMAC_CC_SAM_Pos)))
576
#define XDMAC_CC_SAM_FIXED_AM (0x0u << 16)
577
#define XDMAC_CC_SAM_INCREMENTED_AM (0x1u << 16)
578
#define XDMAC_CC_SAM_UBS_AM (0x2u << 16)
579
#define XDMAC_CC_SAM_UBS_DS_AM (0x3u << 16)
580
#define XDMAC_CC_DAM_Pos 18
581
#define XDMAC_CC_DAM_Msk (0x3u << XDMAC_CC_DAM_Pos)
582
#define XDMAC_CC_DAM(value) ((XDMAC_CC_DAM_Msk & ((value) << XDMAC_CC_DAM_Pos)))
583
#define XDMAC_CC_DAM_FIXED_AM (0x0u << 18)
584
#define XDMAC_CC_DAM_INCREMENTED_AM (0x1u << 18)
585
#define XDMAC_CC_DAM_UBS_AM (0x2u << 18)
586
#define XDMAC_CC_DAM_UBS_DS_AM (0x3u << 18)
587
#define XDMAC_CC_INITD (0x1u << 21)
588
#define XDMAC_CC_INITD_TERMINATED (0x0u << 21)
589
#define XDMAC_CC_INITD_IN_PROGRESS (0x1u << 21)
590
#define XDMAC_CC_RDIP (0x1u << 22)
591
#define XDMAC_CC_RDIP_DONE (0x0u << 22)
592
#define XDMAC_CC_RDIP_IN_PROGRESS (0x1u << 22)
593
#define XDMAC_CC_WRIP (0x1u << 23)
594
#define XDMAC_CC_WRIP_DONE (0x0u << 23)
595
#define XDMAC_CC_WRIP_IN_PROGRESS (0x1u << 23)
596
#define XDMAC_CC_PERID_Pos 24
597
#define XDMAC_CC_PERID_Msk (0x7fu << XDMAC_CC_PERID_Pos)
598
#define XDMAC_CC_PERID(value) ((XDMAC_CC_PERID_Msk & ((value) << XDMAC_CC_PERID_Pos)))
599
/* -------- XDMAC_CDS_MSP : (XDMAC Offset: N/A) Channel Data Stride Memory Set Pattern -------- */
600
#define XDMAC_CDS_MSP_SDS_MSP_Pos 0
601
#define XDMAC_CDS_MSP_SDS_MSP_Msk (0xffffu << XDMAC_CDS_MSP_SDS_MSP_Pos)
602
#define XDMAC_CDS_MSP_SDS_MSP(value) ((XDMAC_CDS_MSP_SDS_MSP_Msk & ((value) << XDMAC_CDS_MSP_SDS_MSP_Pos)))
603
#define XDMAC_CDS_MSP_DDS_MSP_Pos 16
604
#define XDMAC_CDS_MSP_DDS_MSP_Msk (0xffffu << XDMAC_CDS_MSP_DDS_MSP_Pos)
605
#define XDMAC_CDS_MSP_DDS_MSP(value) ((XDMAC_CDS_MSP_DDS_MSP_Msk & ((value) << XDMAC_CDS_MSP_DDS_MSP_Pos)))
606
/* -------- XDMAC_CSUS : (XDMAC Offset: N/A) Channel Source Microblock Stride -------- */
607
#define XDMAC_CSUS_SUBS_Pos 0
608
#define XDMAC_CSUS_SUBS_Msk (0xffffffu << XDMAC_CSUS_SUBS_Pos)
609
#define XDMAC_CSUS_SUBS(value) ((XDMAC_CSUS_SUBS_Msk & ((value) << XDMAC_CSUS_SUBS_Pos)))
610
/* -------- XDMAC_CDUS : (XDMAC Offset: N/A) Channel Destination Microblock Stride -------- */
611
#define XDMAC_CDUS_DUBS_Pos 0
612
#define XDMAC_CDUS_DUBS_Msk (0xffffffu << XDMAC_CDUS_DUBS_Pos)
613
#define XDMAC_CDUS_DUBS(value) ((XDMAC_CDUS_DUBS_Msk & ((value) << XDMAC_CDUS_DUBS_Pos)))
614
/* -------- XDMAC_VERSION : (XDMAC Offset: 0xFFC) XDMAC Version Register -------- */
615
#define XDMAC_VERSION_VERSION_Pos 0
616
#define XDMAC_VERSION_VERSION_Msk (0xfffu << XDMAC_VERSION_VERSION_Pos)
617
#define XDMAC_VERSION_VERSION(value) ((XDMAC_VERSION_VERSION_Msk & ((value) << XDMAC_VERSION_VERSION_Pos)))
618
#define XDMAC_VERSION_MFN_Pos 16
619
#define XDMAC_VERSION_MFN_Msk (0x7u << XDMAC_VERSION_MFN_Pos)
620
#define XDMAC_VERSION_MFN(value) ((XDMAC_VERSION_MFN_Msk & ((value) << XDMAC_VERSION_MFN_Pos)))
621
623
624
625
#endif
/* _SAMV71_XDMAC_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
XdmacChid
XdmacChid hardware registers.
Definition
component_xdmac.h:41
Xdmac
Definition
component_xdmac.h:60
Xdmac::XDMAC_VERSION
__IO uint32_t XDMAC_VERSION
(Xdmac Offset: 0xFFC) XDMAC Version Register
Definition
component_xdmac.h:81
